Alternatives to MDF and Baltic Birch - AVS Forum | Home Theater Discussions And Reviews
 11Likes
  • 1 Post By stegen
  • 1 Post By tuxedocivic
  • 1 Post By the-jessman
  • 1 Post By stegen
  • 1 Post By antisuck
  • 1 Post By A9X-308
  • 1 Post By dtmeyer
  • 1 Post By apilon
  • 1 Post By ItchyTasty42
post #1 of 27 Old 10-03-2015, 09:50 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Going to build a box for the SI 18 driver before ordering one to make sure I'm not a disaster building it. I don't want to use MDF (dust, health hazard, can't stain it, etc). I also can't find Baltic Birch anywhere near me. I've looked and asked for special order but no luck. Are there any other good solutions? I've looked at regular birch plywood or oak plywood. Any suggestions? I'll be using 3/4".
Front L&R: Polk RTi A3 (cherry finish)
Center: Polk CSi A6 (cherry finish)
Surrounds: Polk FXi A6 (black finish)
Subwoofer: Dual Sealed SI-HT 18" with iNuke 3000dsp
Receiver: Yamaha RX-V673
TV: 55" LCD
zpatter1 is offline
post #2 of 27 Old 10-03-2015, 09:58 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4796
Lowe's/Home Depot doesn't carry it? How about this place, anywhere near you? https://www.facebook.com/PickensHardwoods I did this search https://www.google.com/#q=baltic+bir...od+mississippi
I found a good supplier of BB, aside from the big boxes here where it was both poorer quality and more expensive; I was looking for hardwoods for another project when I discovered they had some nice choices in ply, too. Must be available somewhere....
I too don't want to mess with mdf but think if you're going to go to the effort of building a box, just find the right ply to begin with and go for it.
lovinthehd is offline
post #3 of 27 Old 10-03-2015, 10:13 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
First of all, thanks for doing a search! Unfortunately that place is a 6 hour total drive there and back. MS is a big state haha. I checked lowes and HD and a couple of local lumber yards. I tried to do my due diligence on locating Baltic Birch. Would the oak or birch ply also work? Any other ideas?
TV: 55" LCD
zpatter1 is offline
post #4 of 27 Old 10-03-2015, 10:24 PM
lovinthehd's Avatar
Liked: 4796
Where exactly are you? Maybe others will have some more ideas for you. I know little about ply except that BB tends to be the best....found this http://www.woodworkerssource.com/blo...hen-to-use-it/
Have you tried contacting cabinet makers? Or companies that specialize in supplying cabinet makers?
post #5 of 27 Old 10-03-2015, 10:29 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Tupelo...where Elvis was born ha. Yea, my parents recently redid their house and our cabinet guy used solid birch for our cabinets
TV: 55" LCD
zpatter1 is offline
post #6 of 27 Old 10-03-2015, 11:19 PM
stegen's Avatar
Quoted: 184 Post(s)
Liked: 119
I heard arouco (sp) is a decent alternative
zpatter1 likes this.
stegen is offline
post #7 of 27 Old 10-03-2015, 11:21 PM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2230
Cabinet grade plywood with the wood veneer of your choice. I prefer it over the BB I can get here.
tuxedocivic is offline
post #8 of 27 Old 10-04-2015, 09:30 AM
the-jessman's Avatar
Quoted: 30 Post(s)
Liked: 55
I use lots of Arauco plywood. There may be a supplier that carries it in your area. Boise-Cascade is a distributer for it in my area.
"Nothing prevents people from knowing the truth more than the belief they already know it."
"Making bass is easy, making music is the hard part!"
My Audio Facebook page - http://www.facebook.com/triticumaudio
Instagram: http://instagram.com/triticumaudio
the-jessman is offline
post #9 of 27 Old 10-04-2015, 09:35 AM
stegen's Avatar
Quoted: 184 Post(s)
Liked: 119
Hell, Menard carries it
stegen is offline
post #10 of 27 Old 10-04-2015, 10:40 AM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Thanks for the advice! I'll check into those options and hopefully start a build thread soon!
TV: 55" LCD
zpatter1 is offline
post #11 of 27 Old 10-04-2015, 12:08 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
Is Arauco the same as the stuff Home Depot sells under the Columbia name? http://www.homedepot.com/p/Columbia-...2941/202887466
kingpin111 is offline
post #12 of 27 Old 10-04-2015, 12:17 PM
Quoted: 30 Post(s)
Liked: 55
No, that's different stuff. 3/4" Arauco has 7 equal-thickness plies and is made from pine. It is superior to the PureBond plywood IMHO.
kingpin111 likes this.
post #13 of 27 Old 10-04-2015, 02:30 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
I'm pretty sure this is what I'm going with. Hopefully I can get a cherry veneer on it to match my speakers
TV: 55" LCD
zpatter1 is offline
post #14 of 27 Old 10-04-2015, 05:22 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 92
why not just google lumber and hardwood and the city u are in and find a place real quick
cookieattk is offline
post #15 of 27 Old 10-04-2015, 06:30 PM
antisuck's Avatar
Quoted: 137 Post(s)
Liked: 180
If you're thinking about pre-veneered ply ready to finish, I've actually had good luck buying apple ply online. http://buyappleply.com/
Kinda spendy I suppose, but good quality and convenient. And it comes in a variety of precut panel sizes from 12"-48" wide and 24"-96" long if you don't feel like wrestling with entire sheets.
antisuck is offline
post #16 of 27 Old 10-04-2015, 07:51 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
That was definitely the first thing I did I called/went to the big box stores and local lumber yard. No one had any.
TV: 55" LCD
zpatter1 is offline
post #17 of 27 Old 10-04-2015, 09:46 PM
A9X-308's Avatar
Quoted: 1809 Post(s)
Liked: 1500
Arauco is fine. It's pretty much all I use as BB is incredibly expensive and with the extensive bracing I use, not worth it.
A9X-308 is offline
post #18 of 27 Old 10-06-2015, 02:55 PM
Quoted: 12 Post(s)
Liked: 2
I think Im going to give advantech a try on my next sub build. Ive used alot for construction but never for speakers before. Heavy, hard, solid(no voids), way stiffer than mdf.
Theres been some discussion on a few threads. If you search advantech on the forum, you should find it
dtmeyer is offline
post #19 of 27 Old 10-07-2015, 06:42 AM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
Funny Auracao here is $62 and BB is $55. This is pricing from a wood shop up the street.
I wanted to use some Walnut veneered Plywood but the grade of it being only 7 ply wasn't too appealing.
post #20 of 27 Old 10-07-2015, 08:00 AM
A9X-308's Avatar
Liked: 1500
I'm in Australia. Here its $45 and $250-300.
Brace it thoroughly (matrix) and the number of plies is not a factor.
A9X-308 is offline
post #21 of 27 Old 10-07-2015, 09:12 AM
Quoted: 30 Post(s)
Liked: 55
If it cost the same, BB is all I would use, its a superior material to Arauco in almost every way, other than price. For me Arauco is $48 for a 4'x8' sheet and BB is $60 for a 5'x5' sheet.
Face2 likes this.
post #22 of 27 Old 10-07-2015, 01:26 PM
cacophonix's Avatar
Quoted: 68 Post(s)
Liked: 41
BB comes in 5x5 as well. So that price is probably for a 5x5 as opposed to a 8x4 for the Arauco ply. Still $62 is fairly hefty. I remember when HD was selling it for under $30 before the factory that made the ply apparently burnt down. Now Lowes has something similar (not as nice) for under $40.
cacophonix is online now
post #23 of 27 Old 10-07-2015, 03:23 PM
apilon's Avatar
Quoted: 49 Post(s)
Home Depot carries Purebond. It is plywood use for furniture project you might want to check it out
Alain Pilon
Montreal, Quebec
apilon is offline
post #24 of 27 Old 10-09-2015, 08:02 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
I found Baltic Birch but it's a 3 hour round trip drive. Is it honestly worth that over cabinet grade plywood?
TV: 55" LCD
zpatter1 is offline
post #25 of 27 Old 10-09-2015, 08:42 PM
lovinthehd's Avatar
Liked: 4796
Which cabinet grade plywood? BB is too....
post #26 of 27 Old 10-09-2015, 08:48 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
3/4" 7 ply birch (not Baltic)
TV: 55" LCD
zpatter1 is offline
post #27 of 27 Old 10-12-2015, 06:01 PM
ItchyTasty42's Avatar
18mm marine plywood also works well, there is also OSB(oriented strand board) but is pretty ugly and can only be veneered or carpeted, but very hard to paint.
But OSB is fairly is strong unlike flimsy weak particle board/chipboard.
A good grade of WBP plywood such as BB/BB grade or better like B grade can also work well.
But not as good as birch plywood though.
ItchyTasty42 is offline
