A builder for Gjallarhorns? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Mfusick
  • 3 Post By Mfusick
post #1 of 12 Old 10-04-2015, 05:23 PM - Thread Starter
SpinMonster's Avatar
Quoted: 486 Post(s)
Liked: 295
I recall seeing a list of cabinet builders floating around that one could contact to build sub boxes. Is one near Colorado that can build the Gjallarhorn sub boxes?
SpinMonster is offline
post #2 of 12 Old 10-04-2015, 05:26 PM
Archaea's Avatar
Quoted: 3743 Post(s)
Liked: 3518
There's a guy in KC who might build you a set if you reimburse for his time. @d_c
Archaea is online now
post #3 of 12 Old 10-04-2015, 05:40 PM - Thread Starter
Quoted: 486 Post(s)
Liked: 295
I have 4 of the TC 18's and can go with ported (Notnyt style) or the 2 Ghorns. I imagine output would be close between 4 ported and 2-Ghorns. Any opinions as I cultivate multiple options?
For amps right now I have 2- CS4080hz Peavey amps and would replace those with 4- Crest CC5500's which can be voltage limited to not over drive the subs. Amp options are open for discussion but I'm not keen on Chinese copies although I haven't ruled them out because of the voltage limiting flexibility.
The Crest amps are twice the price of a Sanway shipped.
post #4 of 12 Old 10-13-2015, 06:28 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Mmmmmmm Ghorn.
dRwOOD73 likes this.
Mfusick is offline
post #5 of 12 Old 10-13-2015, 07:01 AM
dRwOOD73's Avatar
Quoted: 20 Post(s)
Mfusick.. I was just reading an old thread that you had started comparing horn designs, did you ever decide on one?? I know the LilWrecker & the Ghorn were discussed, just curious if you ever built one and your impressions if so..
If I missed a build thread, please send me in that direction.. just doing some horn research/perusing at the moment.. LilWrecker is leading the pack ATM
thanks
dRwOOD73 is offline
post #6 of 12 Old 10-13-2015, 09:05 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
thanks
Lilmike and I are doing a horn project together. I have two LMS drivers sitting here with me now.
Think Ghorn, but a bigger so it's not so handicapped.
dRwOOD73, Patzig and zencarver like this.
Mfusick is offline
post #7 of 12 Old 10-13-2015, 10:02 AM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 173
So, mfusick, you two are finally taking an entire room and beginning the fold template on the floor, right?....go big or dont bother at all, eh?...
blah450 is offline
post #8 of 12 Old 10-13-2015, 10:03 AM
dRwOOD73's Avatar
Quoted: 20 Post(s)
Very nice.. I'll keep an eye out for it
dRwOOD73 is offline
post #9 of 12 Old 10-13-2015, 10:22 AM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2121 Post(s)
Liked: 3142
I believe Nathan Funk built the cabinet Josh used, so it might be worthwhile checking with him as well. He may still have the cutsheet, and if so could build you the exact same thing.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #10 of 12 Old 10-14-2015, 10:56 AM
N8DOGG's Avatar
Quoted: 1291 Post(s)
Liked: 1524
Before I had mine built, I had contacted Nathan, he wanted 1700 per cab in bare wood.....
I got both mine done for 1000$ and the guys did a really nice job.
N8DOGG is offline
post #11 of 12 Old 10-14-2015, 12:03 PM
lukeamdman's Avatar
Quoted: 1385 Post(s)
Liked: 1999
I think Nathan built the 12hz LLT used for the RE XXX 18" driver. If memory serves, a local cabinet maker built Josh's Othorns and Ghorns.
lukeamdman is offline
post #12 of 12 Old 10-14-2015, 12:22 PM
Writer & Reviewer
JimWilson's Avatar
Liked: 3142
I just double checked and you are indeed correct. I thought Nathan built the ghorn, but it turns out it was the RE XXX instead.
