Custom sealed SI 18 build - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 40Likes
post #61 of 86 Old 10-21-2015, 07:46 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
I'll be getting the 13 ply 3/4" Baltic Birch plywood on Friday. Unfortunately it only comes in 5' X 5' sheets so I think I'll need 3 sheets for the two 22" cubes. That sound right?
Front L&R: Polk RTi A3 (cherry finish)
Center: Polk CSi A6 (cherry finish)
Surrounds: Polk FXi A6 (black finish)
Subwoofer: Dual Sealed SI-HT 18" with iNuke 3000dsp
Receiver: Yamaha RX-V673
TV: 55" LCD
zpatter1 is offline
post #62 of 86 Old 10-21-2015, 08:01 PM
brian6751's Avatar
Quoted: 1707 Post(s)
Liked: 1704
try calling around. My local Lowes was getting me 4x8 sheets for around $75
I hate to be the one to tell you this but, youre going to do all that work making your sub match your speakers, and then youre going to sell the speakers. youll see
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #63 of 86 Old 10-21-2015, 08:06 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Lowes and Home Depot around here told me they couldn't get real Baltic Birch. And no, I love those speakers. When I get a house I may build some if I have a dedicated theater, but the Polk's will always be in a living room or bedroom system. They are near and dear to my heart lol.
brian6751 likes this.
TV: 55" LCD
zpatter1 is offline
post #64 of 86 Old 10-21-2015, 08:07 PM
brian6751's Avatar
Liked: 1704
Interesting. Maybe it depends on the supplier. They did have to special order it for me
FOR SALE:
post #65 of 86 Old 10-21-2015, 08:12 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Yea I asked about special order. A few people had luck with them so I tried them first. But the 5'x5' sheets are only $45 each so it's essentially the same price as two $75 sheets.
TV: 55" LCD
zpatter1 is offline
post #66 of 86 Old 10-21-2015, 08:14 PM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Real BB plywood (13 equal plys) is almost always 5'x5' sheets. That's just how it comes.
Sent from my SM-G900V using Tapatalk
PsychoM3 and zpatter1 like this.
Check out my End-Table Marty Build
squiers007 is offline
post #67 of 86 Old 10-21-2015, 08:17 PM
PsychoM3's Avatar
Quoted: 469 Post(s)
Liked: 457
True baltic birch ply is NEVER found in 4x8 sheets, it is standardized at 5x5 for the cabinet industry.
zpatter1 and Boxozaxu like this.
PsychoM3 is offline
post #68 of 86 Old 10-21-2015, 08:19 PM
brian6751's Avatar
Liked: 1704
oh thats not bad then
I know but I swear this was 4x8 sheets of real 13 ply BB. It did have footballs on one side. I have used the cheap stuff before and this was not that.
FOR SALE:
post #69 of 86 Old 10-21-2015, 08:22 PM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
You may be right. .. different importer maybe.
post #70 of 86 Old 10-21-2015, 08:24 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
I've got to use the cut list maker to figure out the cuts to make sure 3 sheets is enough. I'm planning to just use random scrap wood for the bracing. Not an issue if the braces are random pieces or random types of wood I assume?
TV: 55" LCD
zpatter1 is offline
post #71 of 86 Old 10-21-2015, 09:19 PM
PsychoM3's Avatar
Quoted: 469 Post(s)
Liked: 457
The 4x8 sheets sold as BB do NOT come from Russia or Finland, 99% of it can be traced to China. That said BB is not all the same and there are true BB suppliers that sell lower quality BB that is even lower quality than the Chinese "BB". The lowest quality BB tends to have better outer veneer layers than the best Chinese "BB" but the best Chinese "BB" has fewer voids than the low quality European BB.
The best way to find quality BB is find the supplier to the better custom cabinet shops in the area, it is usually better quality and lower in price than the lumber yards that stock it as a niche product.
PsychoM3 is offline
post #72 of 86 Old 10-22-2015, 07:18 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Quite annoyed that with the sheets being 5x5 I'm going to need 2 sheets per sub
TV: 55" LCD
zpatter1 is offline
post #73 of 86 Old 10-23-2015, 06:02 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
I'm getting either 9 ply birch or 9 ply cherry cabinet grade plywood. It rained today so I couldn't bring home the Baltic birch and have no desire to drive that far again to get it.
TV: 55" LCD
zpatter1 is offline
post #74 of 86 Old 10-24-2015, 11:36 AM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
And changed my mind again...I think I'm going for 3/4" cherry veneered MDF lol. But I can't buy anything until this stupid rain stops.
TV: 55" LCD
zpatter1 is offline
post #75 of 86 Old 10-30-2015, 09:40 AM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Big update: I just signed a lease for a new apartment! This means that the subs will have a nice large space to fill! And I only have a neighbor on one side, so I hopefully won't have noise complaints!
What does everyone do who uses plywood for the edges? I don't want the mdf center to show along the edges...should I veneer just the edges? Use scrap to put on there?
TV: 55" LCD
zpatter1 is offline
post #76 of 86 Old 10-30-2015, 10:03 AM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 216
45 degree miter joints.
zpatter1 likes this.
Face2 is offline
post #77 of 86 Old 10-30-2015, 12:54 PM
PsychoM3's Avatar
Quoted: 469 Post(s)
Liked: 457
I would use a lock miter joint but that requires a router table or shaper and they are somewhat difficult to setup. A 45 degree miter will work fine but increases the difficulty of the glue up. It would be really nice if you had a 23ga pinner to help as they basically disappear. Wide blue tape across the whole joint so that you can fold the sides up (like closing a book) into position to clamp them helps. Be very careful as you add clamp pressure that you don't slide the pieces out of position.
A lock miter joint
PsychoM3 is offline
post #78 of 86 Old 11-01-2015, 06:13 AM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Thanks @PsychoM3 and @Face2 but will that work with an MDF core? 45 degree mitre is no problem and I have a brad nailer so no need for clamping anyway. The locking mitre seems much much harder lol.
TV: 55" LCD
zpatter1 is offline
post #79 of 86 Old 11-01-2015, 10:09 AM
PsychoM3's Avatar
Quoted: 469 Post(s)
Liked: 457
[QUOTE=zpatter1;38561537but will that work with an MDF core? 45 degree mitre is no problem and I have a brad nailer so no need for clamping anyway. The locking mitre seems much much harder lol.[/QUOTE]
Usually veneered MDF is dense enough to hold a 45 and glue. I would try not to use brads from the front since they will be visible, that is why I mentioned a 23ga pinner. It will help if you have a way to use biscuits, dowels or Dominos. You should also glue in cleats behind each corner to reinforce them.
I would try to avoid using brads since you want to preserve the veneer, you can get a pinner at Harbor Freight that people seem to be able to get away with for about $20, but I think you can do it without any nail holed in the outside.
I think my approach (with no lock miter) would be to glue the cleats on the front baffle and each one of the sides, then use tape on the and fold them all up so that you can brad from the back side through the cleats. The I would use clamps. Once that is dried I would put the cleats on the back put it into place and brad through the cleats through the baffle hole. Then clamp the back on until it is dry.
This is what I am talking about with the tape, though you will need more tape for the heavy parts. I would not do the whole perimeter like this though. I would have the four sides taped to the baffle like a cross.
A cleat
gkf15, zpatter1 and Bagua like this.
PsychoM3 is offline
post #80 of 86 Old 11-01-2015, 06:28 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Thanks for the thorough response and pictures. I'm always impressed with how much everyone helps out on here. Can't wait to get finished with my move and get the subs finished.
TV: 55" LCD
zpatter1 is offline
post #81 of 86 Old 11-01-2015, 07:40 PM
PsychoM3's Avatar
Quoted: 469 Post(s)
Liked: 457
It just hit me if you make the bottom of the box so it fits INSIDE the side walls then they won't have to be mitered and can be a simple butt joint since the bottom will never show. This may make putting the first five sides together much easier and with less chance of the miter joints sliding.
zpatter1 and More is Better like this.
PsychoM3 is offline
post #82 of 86 Old 11-20-2015, 12:35 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Wood has been purchased. I went with 3/4" mdf that already has a cherry veneer on it. Let the building commence!
TV: 55" LCD
zpatter1 is offline
post #83 of 86 Old 02-05-2016, 04:18 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
The wood has finally been cut! Just have to cut the circular holes for the baffles and the speakon connector hole!
TV: 55" LCD
zpatter1 is offline
post #84 of 86 Old 02-29-2016, 09:48 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Sub build is going well thanks to my Dad! He has made very very nice boxes for me. I added pics to the first post but I have a question. Since the wood is cherry veneered MDF, you can see the MDF edges on some sides. We were thinking of handling this with some trim/something decorative. Any ideas? You can see what I'm talking about in the attached pic...
Name:	Sub Build 2.jpg
TV: 55" LCD
zpatter1 is offline
post #85 of 86 Old 03-30-2016, 12:41 PM - Thread Starter
zpatter1's Avatar
Quoted: 390 Post(s)
Liked: 229
Boxes are now built. What do I need to hook the iNuke 3000 dsp to the SI HT18 D4s? I'm planning to wire them to 2 ohms. I know I need a neutrik speakon connector, but which one? 2 or 4 prong? And what cable...xlr or ts? Don't know anything about these. Also my receiver that the iNuke will be connected to is a Yamaha RXV673. Should be up and running very soon!
TV: 55" LCD
zpatter1 is offline
post #86 of 86 Old 03-30-2016, 06:19 PM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 642
I'd run a bead of caulking on ALL the interior seams myself, run a bead along the seam, and smooth it into the joints with your finger, noone is gonna see it.
Polyfill? Most recommend 1lb per cu.
Most buy 4pole neutrik because it gives you wiring options later if you decide to change stuff up, only 2 pole is necessary.
Sent from my XT1575 using Tapatalk
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
