Finally, bass upgrade - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Fatshaft
post #1 of 20 Old 10-24-2015, 08:11 AM - Thread Starter
Liked: 0
Well it's been 8-9 years lurking on this site finally upgrading my 12 in sub with 2 mini Marty's with um-18s. With a nu6000dsp. My receiver has two sub outs do I use both or use a splitter to go into amp? I'm not sure what the best way to hook these up any help would be appreciated
Bahack is offline
post #2 of 20 Old 10-24-2015, 08:57 AM
Fatshaft's Avatar
Quoted: 593 Post(s)
Liked: 921
First of all...congrats! You'll be amazed at the output compared to your 12" sub.
You need to know if your subs out are independently controllable.
If yes then more power to you and that's the way I would connect it.
Good luck and congrats on finally joining too!
LTD02 and brian6751 like this.
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #3 of 20 Old 10-24-2015, 09:13 AM
brian6751's Avatar
Quoted: 1705 Post(s)
Liked: 1703
What model is your receiver?
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is online now
post #4 of 20 Old 10-24-2015, 09:59 AM
EndersShadow's Avatar
Quoted: 1254 Post(s)
Liked: 1525
I'd connect each individually. That way if your AVR can EQ em differently your set, and even if it can't your still set, so with way it's a win win.
EndersShadow is offline
post #5 of 20 Old 10-24-2015, 10:48 AM - Thread Starter
Liked: 0
Thank you. My receiver is Yamaha rx-673. Any information on hook up from speaker to amp would help a lot
Bahack is offline
post #6 of 20 Old 10-24-2015, 11:10 AM
wasser's Avatar
Quoted: 120 Post(s)
Liked: 83
Do what EndersShadow said - use both outputs on the receiver. In the very least it is already a splitter. At the most your AVR can make individual adjustments.
So, you'll need two RCA to XLR cables to go from receiver to amp and then amp to subwoofers needs two Speakon to whatever matches your subwoofer hookups.
wasser is offline
post #7 of 20 Old 10-24-2015, 11:20 AM - Thread Starter
Liked: 0
Thank you, I'm good on that end now. How do I run the wires at the 4 pole Speakon connector to sub this part a little confusing?
Bahack is offline
post #8 of 20 Old 10-24-2015, 11:49 AM
wasser's Avatar
Quoted: 120 Post(s)
Liked: 83
If you're going speakon to speakon, then just use 1+ and 1-. You'll see it on the inside of the connector.
The video from the Marty FAQ can help you understand:
wasser is offline
post #9 of 20 Old 10-24-2015, 12:52 PM - Thread Starter
Liked: 0
Thank you, I'm sorry I meant do I need to run a jumper with this model um-18 22 bridge,parallel or what can't find many builds with this sub. This part I'm really a noob sorry.
Bahack is offline
post #10 of 20 Old 10-24-2015, 02:20 PM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4297
It will only be a tiny bit louder (Tiny like a billion x )
BassThatHz is offline
post #11 of 20 Old 10-24-2015, 03:03 PM
coolrda's Avatar
Quoted: 1391 Post(s)
Liked: 1506
Wait. So you've been covertly following along for nine years, then you go from lurking to thread starter to boom! I got two 18" M&M's?Well alright then. Welcome.
coolrda is offline
post #12 of 20 Old 10-24-2015, 06:13 PM
wasser's Avatar
Quoted: 120 Post(s)
Liked: 83
The UM-18 is a dual 2 ohm. You want to wire it in series for a 4 ohm load. Wire it just like in the picture.
wasser is offline
post #13 of 20 Old 10-24-2015, 11:24 PM - Thread Starter
Liked: 0
Thanks, 4ohms will give me how many watts per channel?
Bahack is offline
post #14 of 20 Old 10-25-2015, 03:31 AM
PsychoM3's Avatar
Quoted: 469 Post(s)
Liked: 455
The iNuke 6000 puts out ~1800 "real" watts per channel at 4 ohms.
PsychoM3 is offline
post #15 of 20 Old 11-12-2015, 04:25 PM - Thread Starter
Liked: 0
Ok,everything up and sounding good. Pics coming this weekend I hope. Is there any way to hook up 6000dsp to iPad? Trying to find adapter for this cable. My pc is Upstairs.
Bahack is offline
post #16 of 20 Old 11-12-2015, 04:31 PM
mlah384's Avatar
Quoted: 502 Post(s)
Liked: 229
When I connected my 6000dsp to my ipad, it sounded horrible... The ipad didnt provide a strong enough signal. Once I connected an AVR and a bluray, OMG... huge difference...
mlah384 is offline
post #17 of 20 Old 11-12-2015, 04:38 PM - Thread Starter
Liked: 0
No, just to run the dsp program that came with the 6000dsp
Bahack is offline
post #18 of 20 Old 11-12-2015, 04:43 PM
BSHuff's Avatar
Quoted: 79 Post(s)
Liked: 87
After I typed an answer... are you looking to feed signal from your iPad to your iNuke or configure your iNuke?
To configure you need a PC there are no options that I know of to use anything other than a PC. No Mac/IOS options
BSHuff is offline
post #19 of 20 Old 11-12-2015, 04:53 PM - Thread Starter
Liked: 0
Just trying to configure the 6000dsp ty
Bahack is offline
post #20 of 20 Old 11-12-2015, 05:27 PM
wasser's Avatar
Quoted: 120 Post(s)
Liked: 83
You can configure it right from the front panel.
wasser is offline
