AUTOTECH IWATA-600 & 300 Size Comparison - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #1 of 55 Old 11-06-2015, 09:32 AM - Thread Starter
dashpuppy's Avatar
Quoted: 434 Post(s)
Liked: 258
Just thought i would put this out there for you guys, and anyone thinking about buying these units. For now i'm just showing 2 videos of My Personal AUTOTECH IWATA-600's I have access to the 300's next week so i will post pictures and a short video of the size comparison of the two..
When researching mine, it was hard to find pictures to actually see the size and how they looked. A drawing was kinda, not life like.
And sound,
Hope this helps someone
dashpuppy is offline
post #2 of 55 Old 11-07-2015, 01:45 AM
chrapladm's Avatar
Quoted: 1105 Post(s)
Liked: 448
WOW, funny that I was just talking about these and now there is a video. Huge thanks for this thread and uploaded videos. I was looking at getting a pair of Iwata 600's possibly to go with my pair of 10's per side.
Was looking at using a BC CD. Possibly the DE500 or as Tux mentioned the DE550.
chrapladm is offline
post #3 of 55 Old 11-07-2015, 03:25 AM
Quoted: 566 Post(s)
Liked: 64
I have long lusted over the iWatta 300 with Radian 951BePB over a pair of AE TD 12's that I saw a while back.
Tip24/96 is offline
post #4 of 55 Old 11-07-2015, 08:38 AM - Thread Starter
dashpuppy's Avatar
Quoted: 434 Post(s)
Liked: 258
I'll be Running the DE550 on mine, he actually measured these last week with my Celestion CD's on them and they were pretty decent..
I'm hoping to run to his house this weekend and get some pictures of the 600 & 300 units together.
My 600's are going to be used with a pair of TD15m 15" units
Project starting soon
post #5 of 55 Old 11-07-2015, 03:44 PM
chrapladm's Avatar
Liked: 448
Sounds great. If I had more room width wise I would have used a bigger bass driver also. BUT for now I will just have to use my dual 10's per cab. Single 15M should be very nice. Sealed or ported cabinet?
post #6 of 55 Old 11-07-2015, 03:47 PM - Thread Starter
dashpuppy's Avatar
Quoted: 434 Post(s)
Liked: 258
Ported.. I'm not a fan of sealed..
post #7 of 55 Old 11-07-2015, 03:57 PM
chrapladm's Avatar
Liked: 448
And will you just be resting the 600 on the top of the cabinet?
Couldnt quite tell if there was a mounted support or not. I will most likely try and make a mounted support. I have children and while they dont mess with most of my stuff I need plan for prevention.
post #8 of 55 Old 11-07-2015, 03:59 PM - Thread Starter
dashpuppy's Avatar
Quoted: 434 Post(s)
Liked: 258
Couldnt quite tell if there was a mounted support or not. I will most likely try and make a mounted support. I have children and while they don't mess with most of my stuff I need plan for prevention.
You will have to make a mount mine are just sitting on top for now, but i'm getting a CNC machined bracket for mine..
kingpin111 likes this.
post #9 of 55 Old 11-07-2015, 04:50 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
Iwata 300 size.
Compared to a JBL 2226 15" driver.
gkf15 likes this.
kingpin111 is offline
post #10 of 55 Old 11-07-2015, 04:50 PM
chrapladm's Avatar
Liked: 448
OK. I will have to make one as I assumed. Look forward to your progress on your build.
I also will have to see how these will work in my room. I will have one speaker right up against the wall. So the right side of the speaker will only be about 1" away from the wall. SO I hope with a slight toe in things will be fine. I know it wont be perfect but its what I have to deal with anyways..
And Kingpin those 300's look big but not THAT big. BUT then you see the picture of the CD's in someones hands and then it starts to paint a clearer picture. Those CD's are massive.
post #11 of 55 Old 11-07-2015, 04:56 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
Would you mind sharing your design of the bracket?
Would you be able to add more to your order if people want to buy them?
post #12 of 55 Old 11-07-2015, 05:05 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
Here is a pretty cool looking one I found in a picture online. I think the guy custom made it though.
ID:	1044713   Click image for larger version
ID:	1044721   Click image for larger version
post #13 of 55 Old 11-07-2015, 05:10 PM - Thread Starter
dashpuppy's Avatar
Quoted: 434 Post(s)
Liked: 258
I'll make a drawing in a few hours of my simple idea It's pretty sweet i think !
I have lots of pictures of the 300's as Tux lives very close to me
post #14 of 55 Old 11-07-2015, 07:47 PM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2229
Both iwatas measure really nice and the shape is very smooth without any abrupt edges. I really like them.
The 300 is an absolute giant. Pics don't do it justice. I think a comparison pic will really show people the difference.
chrapladm likes this.
tuxedocivic is offline
post #15 of 55 Old 11-08-2015, 06:32 PM
rhodesj's Avatar
Quoted: 1010 Post(s)
Liked: 600
How does the performance compare to the SEOS waveguide? Could an Iwata be substituted into one of the SEOS designs, or does it alter the CD performance significantly?
rhodesj is online now
post #16 of 55 Old 11-08-2015, 08:10 PM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 216
A new crossover will definitely be needed.
As for SEOS-24 vs Iwata 300, the Iwata looks cooler, but I would stick with the SEOS-24.
Face2 is offline
post #17 of 55 Old 11-08-2015, 08:16 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
@tuxedocivic
post #18 of 55 Old 11-08-2015, 09:04 PM - Thread Starter
dashpuppy's Avatar
Quoted: 434 Post(s)
Liked: 258
They sure look cool I am using mine for 2 channel Stereo listening.
post #19 of 55 Old 11-09-2015, 08:23 AM
Liked: 2229
Originally Posted by kingpin111 View Post
I don't feel like I got to hear the SEOS 24 at it's full potential. Going on technical merits on paper alone, the Iwata has a lot of horn loading at it's cut off (600 and 300hz) which makes getting a low XO much safer, though more difficult to do passively. Thankfully it also has the features of a "waveguide" (the seos is also a horn technically, but it is mostly about controlling directivity, guiding waves), such as a smooth throat, smooth edge termination, etc. It's also wider than it is tall (elliptical) which I like in a waveguide/horn.
OTOH, the SEOS is a little bigger if I'm not mistaken and it isn't as deep. It should have very uniform polar response and if it's like the smaller 1" SEOS waveguides it'll have basically text book perfect polars. That said, the Iwata polars are very good also (sorry, don't have presentable data on that yet. I keep getting rained out or pulled into real life before I can get final measurements outdoors).
It's really 6 in one, half dozen in the other afaik.
Face2 likes this.
post #20 of 55 Old 11-09-2015, 08:30 AM - Thread Starter
dashpuppy's Avatar
Quoted: 434 Post(s)
Liked: 258
Potato PATATO!
I guess it comes down to what you are trying to achieve. In my goal i want 2 channel stereo sound that's effort-less
post #21 of 55 Old 11-09-2015, 08:45 AM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 216
Potato PATATO!
That is something either will be able to achieve.
Face2 is offline
post #22 of 55 Old 11-09-2015, 08:54 AM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
So...I should sell you the Iwata's and go with the SEOS.
Kidding.
Way too much invested in those things. Plus they are damn sexy.
post #23 of 55 Old 11-09-2015, 08:59 AM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
I looked for comparisons between the 2 and the only thread I found that would have some info doing so was mtg90's thread where he was going to compare a whole bunch of the DIY soundgroup horns and waveguides. It doesn't look like he got too far though.
post #24 of 55 Old 11-09-2015, 09:16 AM
Nate Hansen's Avatar
Quoted: 262 Post(s)
Liked: 181
IMO it really comes down to the intended use. For an ht setting with multiple seating positions I'd take the SEOS. For a dedicated 2 channel rig I could go either way. Of course, the room is a factor as well, and you can argue the pros/cons of constant directivity vs a smoothly narrowing pattern.
Face2 likes this.
Nate Hansen is offline
post #25 of 55 Old 11-09-2015, 09:35 AM
rhodesj's Avatar
Liked: 600
Realistically, I was thinking more in the context of comparing the 600 to a SEOS10 or 12, wondering if they'd be reasonably interchangable, and only for the "it looks cool" factor.
post #26 of 55 Old 11-09-2015, 10:08 AM
Liked: 2229
Kidding.
Not sure where you got that idea. You're to senstive
Oh I see. Certainly not interchangeable.
post #27 of 55 Old 11-09-2015, 10:10 AM
Liked: 2229
Because it'll have a wider beamwidth? That's probably true, the Iwata is quite narrow (which has it's advantages in other ways). There's no perfect animal I guess.
post #28 of 55 Old 11-09-2015, 10:31 AM
Quoted: 262 Post(s)
Liked: 181
Yeah, purely from a coverage standpoint. I'd love to have a CD (or near CD) horn that is as smooth and efficient as a traditional horn.
kingpin - any reason you chose the Iwata over a le'Cleach?
post #29 of 55 Old 11-09-2015, 12:39 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
My decision was solely based on 2 things.
Reading how much Carl Huff likes them and felt they worked amazingly well with the Be diaphramed 2446 cd's.
Also because the look of them is so unique and sexy. To me they are just flat out gorgeous.
Other then that 95% of the stuff you guys talk about I don't understand that's why I have Tux designing everything.
So far so good even when he is taking digs at me.
rhodesj likes this.
post #30 of 55 Old 11-09-2015, 01:20 PM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 216
They do look like a pair of sexy lips...opposed to the large SEOS, which looks like a bathroom sink.
Face2 is offline
