Behringer NU3000DSP Volt mod 110v to 220v - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By marto2009
  • 1 Post By LTD02
post #1 of 20 Old 11-14-2015, 08:44 PM - Thread Starter
marto2009's Avatar
Quoted: 94 Post(s)
Liked: 7
Hi,
I just bought an iNuke NU3000DSP in United States, which uses 110V, but in my country we use 220V.
The mod is super easy, and it should help if you buy your iNuke online. I tested it on a NU3000DSP, it will probably work on NU1000DSP also. Do at your own risk.
1-. Open your amplifier
2-. Locate JP1
3-. Open Circuit
If you want to mod a 220V unit to 110V, just close the circuit.
Good luck
ID:	1058345   Click image for larger version
ID:	1058353   Click image for larger version
ID:	1058361   Click image for larger version
ID:	1058369   Click image for larger version
ID:	1058385   Click image for larger version
More is Better likes this.
marto2009 is online now
post #2 of 20 Old 11-14-2015, 09:52 PM
mtg90's Avatar
Quoted: 826 Post(s)
Liked: 1660
That's interesting, I wonder why Behringer didn't just install a 110-220v switch on the back?
mtg90 is offline
post #3 of 20 Old 11-14-2015, 10:03 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 216
Very nice series of pictures detailing where to find the jumper. Despite the popularity of this amp, I can't remember seeing a detailed pictorial or this mod before. On a 220v circuit you could run quite a few of these amps with this mod. Thanks for sharing with the community!!
michaelddd is offline
post #4 of 20 Old 11-15-2015, 10:02 AM
rhodesj's Avatar
Quoted: 1010 Post(s)
Liked: 600
Wow, this is totally awesome. Or it is if it can be applied to the 6K as well. I'd much rather run a 240V dedicated circuit for my amps than 120.
rhodesj is offline
post #5 of 20 Old 11-15-2015, 10:09 AM
More is Better's Avatar
Quoted: 620 Post(s)
Liked: 355
+1
Thanks for figuring this out.
More is Better is offline
post #6 of 20 Old 11-15-2015, 10:24 AM
LTD02's Avatar
Quoted: 2997 Post(s)
Liked: 3742
w a r r a n t y r e p a i r f o r u s e r e r r o r : - )
Listen. It's All Good.
LTD02 is offline
post #7 of 20 Old 11-15-2015, 02:15 PM
skipz's Avatar
Anyone know if this mod can be done to a NU6000?
skipz is offline
post #8 of 20 Old 04-08-2017, 05:10 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 642
Conversion is conversion, why would it be different on a more Powerful amp of the same brand, that is basically the same?
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #9 of 20 Old 12-16-2017, 05:22 AM
DrDyna's Avatar
Quoted: 168 Post(s)
Liked: 150
It's similar, but not nearly as easy.
There's a jumper to break just like in the 3000, but next to it there's another set of jumpers, and you have to break the 120/110v jumper and make the 220/240v jumper, so the power supply board has to be removed to solder it.
That would normally be an easy task, except Behringer in their infinite wisdom decided to heatsink all the parts on the BOTTOM of the chassis, so you've gotta deal with a dozen screws, nipping zip ties, unplugging headers and transistor goop everywhere.
DrDyna is offline
post #10 of 20 Old 02-04-2019, 08:54 AM - Thread Starter
marto2009's Avatar
Quoted: 94 Post(s)
Liked: 7
Hi,
Do you know if the NX3000 has the same jjumper to convert it to 220V?
post #11 of 20 Old 12-02-2019, 03:33 PM
RamKat's Avatar
Originally Posted by marto2009 View Post
Hi,
Did you get an answer to this question from any source?
Epson 8500UB (R); Elite Electric100 16:9; Yamaha RX-V671; Polk Monitor 60 x 2, Polk CS2, Polk Monitor 30 x 4
RamKat is offline
post #12 of 20 Old 12-02-2019, 03:36 PM - Thread Starter
marto2009's Avatar
Quoted: 94 Post(s)
Liked: 7
nope... could not get an answer... i assume it can be done, but its just a guess.
Sent from my ONEPLUS A3000 using Tapatalk
post #13 of 20 Old 12-02-2019, 05:53 PM
RamKat's Avatar
Thanks, I too think it is a 95% chance that it will work. The only concern that I have is that there may be another component that need to be changed too (such as the value of a resistor) to make it function as designed. Is your modded NU1000DSP still doing fine?
RamKat is offline
post #14 of 20 Old 12-02-2019, 06:04 PM - Thread Starter
marto2009's Avatar
Quoted: 94 Post(s)
Liked: 7
i modded a nu3000dsp and it works great after almost 5 years.
RamKat likes this.
post #15 of 20 Old 12-16-2019, 09:32 PM
rr14's Avatar
Quoted: 138 Post(s)
Liked: 32
hi all, I have some photos of the nx4-600 which should be the same as the nx6000d.
My first photo is probably the best for these purposes. Would I need to connect the j1 to j3 and the. Cut the one currently going over the 240 section?
edit... I'm trying to go the opposite way, from 240 v down to 120v.
ID:	2655030   Click image for larger version
ID:	2655032   Click image for larger version
rr14 is offline
post #16 of 20 Old 12-17-2019, 06:18 AM - Thread Starter
marto2009's Avatar
Quoted: 94 Post(s)
Liked: 7
Without making some simple test with a multimeter it's hard to say, but it all looks that you should proceed as you said... so, If you are going from 230v to 110v you should cut the jumper in the 230v position and bridge the other one.
Anyways, I would recommend you to get some help and do some measurements to avoid burning your amp, or worst yet getting yourself electrocuted.
post #17 of 20 Old 12-17-2019, 06:24 AM
notnyt's Avatar
Quoted: 3873 Post(s)
Liked: 3816
just adding a note that by making these changes, the amps will almost definitely be fused incorrectly. Going from 120 to 240 you'd have double the amperage in fuses, and going from 240 to 120, you'd have half.
notnyt is offline
post #18 of 20 Old 12-17-2019, 12:31 PM
rr14's Avatar
Quoted: 138 Post(s)
Liked: 32
Great point. For now I’ll probably just hook this up to my 240 dryer outlet
rr14 is offline
post #19 of 20 Old 12-24-2019, 06:37 AM
RamKat's Avatar
Good pictures! Is there a fuse on the board (or elsewhere)?
RamKat is offline
post #20 of 20 Old 12-24-2019, 08:51 AM
rr14's Avatar
Quoted: 138 Post(s)
Liked: 32
Fuse no, breaker yes. , on the third photo, there is the black box hanging off the back wall with the two blue wires coming out of it. That is the breaker
At least at a quick glance that’s what I saw. The 250v cord also had a fuse built in also.
rr14 is offline
