The V.B.S.S. DIY subwoofer design thread - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 813Likes
post #511 of 1499 Old 07-21-2017, 02:28 AM
Quoted: 566 Post(s)
Liked: 64
Originally Posted by mikeTRON250LM View Post
I built a pair of down firing ones to replace my hsu vtf15h. It's absurd how much more output these things have...
I attached a random few pictures and the "speaker" in the first photo on the wall is NOT mine.
I am curious to know if you mitered the corners on that dark trim you are using to cover the seams?
cdy2179 likes this.
Tip24/96 is offline
post #512 of 1499 Old 07-21-2017, 06:53 AM
mikeTRON250LM's Avatar
Quoted: 419 Post(s)
Liked: 343
Yep, just because I used plywood, otherwise I wouldn't have.
Sent from my SM-G935P using Tapatalk
mikeTRON250LM is offline
post #513 of 1499 Old 07-21-2017, 07:50 AM
corradizo's Avatar
Quoted: 1526 Post(s)
Liked: 1583
corradizo is online now
post #514 of 1499 Old 07-21-2017, 07:55 AM
Quoted: 419 Post(s)
Liked: 343
Mitering them was a pain in the ass, because none of them were level and it meant we had to poly them ON the boxes but it all looks nice now.
post #515 of 1499 Old 07-21-2017, 08:22 AM
Quoted: 419 Post(s)
Liked: 343
post #516 of 1499 Old 07-21-2017, 01:05 PM
Efalegalo's Avatar
Quoted: 29 Post(s)
Can these be used up to 250 - 300hz
I currently have a pair of BD-Design Oris 200 Horns with a Tang-band W8-1808 full range driver.
Technically, the Oris + TB combo is supposed to play down to 300hz (may be 250hz).
I need to build bins for this system to cover th 30hz- 300hz.
Would the VBSS be considered a viable option? This will only be a temporary rig so I don't want to spend a lot of money.
That being said, I don't want to go through all the woodwork and end up with something that does not perform well in the intended application.
Any thoughts?
Efalegalo is online now
post #517 of 1499 Old 07-21-2017, 01:57 PM
Samps's Avatar
Quoted: 1222 Post(s)
Liked: 901
I don't see why not if you have the ability to manage the crossover well enough. The posted full range response of the woofer looks great up to 500hz.
Name:	Screen Shot 2017-07-21 at 4.54.44 PM.jpg
biga6761 likes this.
Samps is online now
post #518 of 1499 Old 07-22-2017, 04:49 AM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
Hello I'm close to finishing my subs.... Is R-13 recycled denim/cotton insulation the only thing i can use inside the boxes because my local HomeDepot is out of stock until Aug 1 & I'm not trying to wait that long thanks.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #519 of 1499 Old 07-22-2017, 10:20 AM - Thread Starter
mtg90's Avatar
Quoted: 767 Post(s)
Liked: 1587
You can use the regular pink fluffy fiberglass which works about the same it's just more itchy. You can also use polyfill if you can find a way to line the walls with it.
joker927 likes this.
mtg90 is offline
post #520 of 1499 Old 07-22-2017, 10:24 AM
Quoted: 419 Post(s)
Liked: 343
You can use 1.5" foam mattress topper from Wal-Mart as well.
post #521 of 1499 Old 07-22-2017, 10:33 AM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
Thanks i found some actually in the store guess it's better to go inside the store vs looking online......So I'm lining the top & back of the box only ???? No sides walls ?
Wish i knew this hour ago i found some R13....Thanks
Nexgen76 is offline
post #522 of 1499 Old 07-22-2017, 09:19 PM - Thread Starter
mtg90's Avatar
Quoted: 767 Post(s)
Liked: 1587
Yeah, you start putting too much in there and you will loose output from the port.
LTD02 and Nexgen76 like this.
mtg90 is offline
post #523 of 1499 Old 07-25-2017, 12:55 PM
Quoted: 27 Post(s)
Hi guys,
How would changing the height from 31.5" to 25"-28" affect performance? I would like to build these into more waf friendly end tables. I plan on running these with the lowest tuning. Thanks for your help!
Jeffrey16 is offline
post #524 of 1499 Old 07-25-2017, 01:00 PM
Quoted: 419 Post(s)
Liked: 343
Originally Posted by Jeffrey16 View Post
Hi guys,
You can change the size of any dimension as long as you keep the internal volume the same. I made mine down firing end tables and it worked out well.
post #525 of 1499 Old 07-25-2017, 07:43 PM
Quoted: 27 Post(s)
Thanks for the reply. I like your build, your end tables really look good. What did they replace? How does it compare to your previous set up?
Do you think the response would be drastically different if I made it shorter? Or just less spl? I would add two of the modified end tables and one to size VBSS.
post #526 of 1499 Old 07-25-2017, 07:47 PM
Quoted: 419 Post(s)
Liked: 343
Your question is somewhat ambiguous, so I will follow up with a blanket statement. If you change the internal volume then yes it changes the design. If you just change the shape but maintain similar internal volumes then it doesn't matter much, aside from making sure you have enough room for the ports. If you want to change the design then I would suggest running simulations in WinISD to compare the different internal volumes and such. If you want something smaller a Marty cube would work as well. Personally I wanted a VBSS pair as it is cheaper and I didn't care that these weren't the absolute best under 20hz.
post #527 of 1499 Old 07-25-2017, 07:59 PM
Quoted: 27 Post(s)
Yeah, I'll probably just build them to size. Momma will get over it. I'm sure a few of the flex 12 would work great too, but when I can get the 18 for less...
post #528 of 1499 Old 07-25-2017, 08:02 PM
Quoted: 419 Post(s)
Liked: 343
I built mine to spec, and added legs to make them about 24 or 25 inches tall, which was about the height of the all black HSU it replaces.
I can't imagine having a better bang for the buck than these things.
post #529 of 1499 Old 07-25-2017, 10:28 PM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
Can someone help me to make sure i got my wiring right..... Box one with the single Neutrik four pole connector I'm using +1 & -1...... The second box with duel Neutrik four pole connector bottom coming from Box 1 I have +1 & -1 & Also the top Neutrik four pole connector i have that one +1 & -1 is this correct as it appear on the picture @mtg90
Nexgen76 is offline
post #530 of 1499 Old 07-26-2017, 03:52 PM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 713
Can someone help me to make sure i got my wiring right..... Box one with the single Neutrik four pole connector I'm using +1 & -1...... The second box with duel Neutrik four pole connector bottom coming from Box 1 I have +1 & -1 & Also the top Neutrik four pole connector i have that one +1 & -1 is this correct as it appear on the picture ?
That will be running them in parallel and give you a 4ohm load. I saw you have an Inuke 6000 so yes that will work. Set a limiter as that will be way over what they can take for power.
LTD02 likes this.
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #531 of 1499 Old 07-26-2017, 06:42 PM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
I actually purchase Inuke3k dsp last week.... So wiring stay the same ?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Purenv likes this.
Nexgen76 is offline
post #532 of 1499 Old 07-26-2017, 07:00 PM
Quoted: 36 Post(s)
We'll after multiple other projects to earn me some good points with the wife, I've just been out and purchased all the mdf needed for two of these subs.
Can't wait to get started!
Nexgen76 likes this.
winty82 is offline
post #533 of 1499 Old 07-26-2017, 07:08 PM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 713
That depends are you running them both off of one channel or bridged?
bscool is offline
post #534 of 1499 Old 07-26-2017, 07:12 PM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
I'm trying to run two off each channel....... I have total of four subs.
Nexgen76 is offline
post #535 of 1499 Old 07-26-2017, 07:16 PM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 713
That will work how you have it wired.
mikeTRON250LM likes this.
bscool is offline
post #536 of 1499 Old 07-28-2017, 09:46 AM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
Well the only holdup now is new Inuke3k dsp. For some reason the last one blew & it was brand new(Sweetwater replaced it no problem ). Making sure my wiring is correct which make me kinda nervous. Missing ports for my other two boxes which going to make total of four.
Nexgen76 is offline
post #537 of 1499 Old 07-28-2017, 08:54 PM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 713
It blew? Do you have an ohm meter or multi meter? I wouldn't hook another amp up without checking to see what you actually have for a load at the speakon terminals. What if you have a bad sub and it is shorted. Probably not but I wouldn't risk it. I don't think they would send you another amp no questions asked.
Even cheap one will work https://www.amazon.com/INNOVA-3320-A.../dp/B000EVYGZA there might be a better one cheaper that is just one that came up and is rated good and I have it and it works ok for what I need.
bscool is offline
post #538 of 1499 Old 07-29-2017, 08:40 PM
Quoted: 1018 Post(s)
Liked: 352
oh man this graph put some bad thoughts in my head. with that frequency response im thinking this sub paired with a 500hz lecleach horn would make one SICK main speaker.
THANK YOU!!! for your selfless contribution to the audio world
Anders Torger for Brutefir
Thomas Drugeon for Rephase
John Mulcahy for room eq wizard
Denis Sbragion for DRC room correction
Juha Hartikainen for Winisd
1201 is offline
post #539 of 1499 Old 08-01-2017, 09:17 PM
Liked: 352
Can someone, anyone kindly measure the response in REW up to about 2khz?
Im interested in knowing if this can be used as the woofer for a fullrange speaker crossing over to a horn around 1k to 2khz.
THANKS !!!!!
1201 is offline
post #540 of 1499 Old 08-01-2017, 09:36 PM
corradizo's Avatar
Liked: 1583
THANKS !!!!!
I am no speaker designer but I think you might want to Google how to figure out when a speaker begins to beam. When beaming begins is based on the size of the driver. Also the center to center distance of the tweeter and the woofer play a role in crossover point selection too.
LTD02 and biga6761 like this.
