The V.B.S.S. DIY subwoofer design thread - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 813Likes
Old 12-10-2017, 04:07 PM
Samps's Avatar
Quoted: 1223 Post(s)
Liked: 901
Not sure what the output looks like on the microcube. I'd guess the micros would be a little stronger under 25hz and the 460s a lot louder above 40hz. The micros may have lower distortion at moderate levels.
biga6761 likes this.
Samps is offline
Old 12-10-2017, 06:45 PM
Quoted: 36 Post(s)
So I finally got started
One things for sure, these things are huge and imposing! I have no idea how some of you guys have so many of them in a room
Obligatory clamp picture
ID:	2328846   Click image for larger version
winty82 is offline
Old 12-11-2017, 04:57 AM
hardeng's Avatar
Quoted: 73 Post(s)
Liked: 71
Yes, they're massive all right, I have two underneath my Fusion 12's to provide bottom end to the left and right mains. They remind me of the big wooden tea chests that we would use as moving boxes back in the UK.
By the way, how does your slot port open into the box? From the photos, looks like its a separate sealed chamber.
hardeng is offline
Old 12-11-2017, 06:17 AM
Quoted: 36 Post(s)
It's the angle of the photo, there's a 2" gap at the top
Blorton and bitmap42 like this.
winty82 is offline
Old 12-13-2017, 12:51 AM
mp3truck's Avatar
Quoted: 41 Post(s)
I was all set to do a dual JBL CS1214 build when I stumbled onto this.
How would one of these do with 800 rms? Would be powered by a Crest CKI800s bridged at 8 ohm.
I've seen mention of powering 2 of them with an inuke 1000 so I'm concerned that 800 rms would be too much power. Yay or nay?
mp3truck is online now
Old 12-13-2017, 07:02 PM
Quoted: 36 Post(s)
Well they're in!
Just got to pick up a XLR to RCA cable tomorrow then I can actually run them up.
LTD02, mp3truck, ORIF and 1 others like this.
winty82 is offline
Old 12-25-2017, 06:14 PM
Quoted: 139 Post(s)
Liked: 50
So I may be able to pick up a used PA460 in the near future. Would be working in conjunction with 2 Infinity 1260ws in a small 13x9x7 room all powered by an iNuke DSP3000.
Couple of questions for the VBSS experts here.
1) Is the PA460 a huge step up vs the Infinities, and should I try to get 2 of the PA460s instead of with the Infinities? I am possibly thinking of using the 1260s nearfield though.
2) What would you do in terms or porting or sealing these boxes? All 3. I am not sure I have room for a full VBSS in the room where the sub should go, based on where my current sub performs the best. Maybe a slightly smaller variant. Or would sealing all 3 boxes and using the iNukes DSP be best in this situation?
90% movie watching, not really looking to listen over 100 dBs.
Spectre55 is offline
Old 12-25-2017, 07:42 PM
asarose247's Avatar
Quoted: 1202 Post(s)
Liked: 1059
@mp3truck
i run 2 in 9.5 ft^3, ported, wired for 4 ohms on 1 channel of an inuke6K limiter set to just <1K.
set for MBM tuning, it never even sweats and I like pushing my set up . .
HTH
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
Old 01-07-2018, 06:18 AM
rayan1910's Avatar
Quoted: 50 Post(s)
Does anyone have plans for the slot port?? Do you still need to use bracing if you have the slot port?
rayan1910 is offline
Old 01-07-2018, 12:24 PM - Thread Starter
mtg90's Avatar
Quoted: 770 Post(s)
Liked: 1587
Originally Posted by mtg90 View Post
You can build it with a full width slot port that is 1.5" high x 28" long with a brace running down the middle of the port, This will allow for both the 20hz tune with both halves of the port open or the 15hz tune if one of the halves was closed off.
If just the 15Hz tune is desired then the slot port can be 1" high, full width (22") and 32" long.
The cabinet still requires bracing with the 4" precision ports or the slot port.
mtg90 is offline
Old 01-07-2018, 12:33 PM
mikeTRON250LM's Avatar
Quoted: 419 Post(s)
Liked: 343
Can someone explain how i set the inuke 6000dsp to TWO channels in and out? im stuck on one in and i cant figure it out. I have two RCA to XLR from my AVR to the Inuke.
Sent from my SM-G935P using Tapatalk
mikeTRON250LM is offline
Old 01-07-2018, 01:52 PM - Thread Starter
mtg90's Avatar
Quoted: 770 Post(s)
Liked: 1587
Should be the dual mono option.
mtg90 is offline
Old 01-07-2018, 02:41 PM
Samps's Avatar
Liked: 901
Make sure you don't have that channel link button turned on.
Samps is offline
Old 01-07-2018, 11:42 PM
Chris Young's Avatar
Quoted: 61 Post(s)
Liked: 138
Hi all,
I wanted to share this picture of the 4 finished V.B.S.S. cabs I made last May with Slot Ports with the help of mtg90 for the port size and length. I will be starting a build thread separate from this one as not to clog this one up and also make it longer.
Thank you again mtg90 for your design and help. I apologize for taking so long to post my cabs.
Name:	4 VBSS 20170528.jpg
Blorton, LTD02, DaleNixon and 7 others like this.
"The Boy has no patience" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
My attempt living room build The Story Time Theater
14 M&K S-100B, 2 Servodrive Contrabass. 2 SVS PB12/2 Plus(ForSale). 4 V.B.S.S., 2 Adire Tempest under riser Near field Fun all in one room.
Chris Young is offline
Old 01-08-2018, 08:07 AM
eng-399's Avatar
Quoted: 2420 Post(s)
Liked: 4971
Originally Posted by Chris Young View Post
Hi all,
The slot ported VBSS cabs look great Chris! Did you spray the boxes or roll them.
eng-399 is offline
Old 01-08-2018, 10:25 AM
Jungle Cruiser's Avatar
Quoted: 24 Post(s)
Liked: 36
Hi all,
Do you happen to have dimensioned drawings?
Jungle Cruiser is offline
Old 01-08-2018, 01:27 PM
chadsmith013's Avatar
Quoted: 2116 Post(s)
Liked: 2146
I have a slot ported modified VBSS build in the works...designed by LTD02 of course...mine is using the Dayton 15 instead of the 18' sub.
Brazle and biga6761 like this.
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP
Nearfield: 2 Dayton HO 15's w/Inuke 6000DSP
chadsmith013 is offline
Old 01-09-2018, 05:02 AM
Quoted: 27 Post(s)
Did you guys figure out A box size and tuning? Thanks!
Jeffrey16 is offline
Old 01-09-2018, 05:26 AM
Liked: 2146
are you going to be running the 15 or 18? the one LTD02 sent me is for the 15..Im sure I can post it if anyone needs it.
Old 01-09-2018, 06:53 AM
Phonzo07's Avatar
Quoted: 93 Post(s)
Liked: 75
I actually need both of these. Please, Please post the build or measurements. I have 2 Ultimax 15's and 2 PA460s that need a home. Tuned to about 20 or so HZ. Maybe lower for another room or other family members.
If you KRANK it.. They will Listen..
Phonzo07 is offline
Old 01-09-2018, 07:15 AM
Liked: 2146
here is what I have.. courtesy of @LTD02
https://imgur.com/a/jeQKB
4.4 cubic footer tuned to ~38hz for PA380
Old 01-09-2018, 10:27 AM
Quoted: 27 Post(s)
I'm looking to build end tables with subs built into them. That's about the size I'm looking for so the 15" would work better for me. I would want to tuning around 20hz though.
chadsmith013 likes this.
Old 01-09-2018, 11:22 AM
Liked: 2146
i would send a PM to ltd02.. he is awesome and always willing to help out fellow members. he could shoot you some quick designs...
Old 01-09-2018, 07:24 PM
Quoted: 61 Post(s)
Liked: 138
Hey thanks Mike,
Yep I rolled them.
Behr Marquee interior paint. Color: Limousine Leather. The same a the walls/ceiling in my HT.
Such a nice paint to use and cleans easily from marks etc.
Old 01-09-2018, 07:41 PM
Quoted: 61 Post(s)
Liked: 138
I don't. I used the one mtg90 posted at the beginning of this thread and asked him for help on measurements for square ports.
He mentioned that I probably would not be able to cut each box out of a complete sheet of wood which was understandable. So I added 1 extra sheet to the purchase and figured I would use it on another project for sure.
Here is what mtg90 wrote me for slot ports below.
If you wanted to make the VBSS enclosure slot ported you can do so with a slot port that is full width, 22" with a brace down the middle and 1.25" high.
I don't have a cultist for the slot port but you just need three extra pieces to make it. A 22" wide x 17" long piece for the top of the slot port. An 18.5" x 1.25" piece for the brace that runs down the middle of the slot port and a 1" x 22" piece to glue onto the top of the inner end of the slot port creating a short 90 degree elbow at the back.( I used a router to round over this piece as to not leave a square sharp edge for the air to create possible noise on)
Unfortunately I don't think they can be cut entirely from the single 4x8' sheet with the rest of the parts unless you piece together two smaller panels to make up the 22" x 17" piece.
This should approximate the 20hz tuning with both sides of the slot port open and the 15hz tuning if you plugged one side.
I hope this help you and others,
LTD02 and biga6761 like this.
Old 01-09-2018, 07:57 PM
AudyoVidyo's Avatar
Quoted: 90 Post(s)
Liked: 136
Just had a look at your theater thread in your sig. Looks really good mate. Where are you planning to put the VBSS's?
AudyoVidyo is offline
Old 01-10-2018, 02:50 PM
Quoted: 61 Post(s)
Liked: 138
Thanks much. Nice setup you have as well but lots of pictures are missing. Got any updates? I have them flanking the center stacked one on one. May play with that way for awhile, then may change them using REW for guidance in the best response location behind the screen. Funny thing is they may already be in the best spot. For their size I just wanted to get them behind the screen at the time more importantly just to make sure they would fit.
Old 01-10-2018, 03:57 PM
joker927's Avatar
Quoted: 47 Post(s)
Liked: 27
I have one VBSS in a very large room and I love it but the plan was always to have it be targeted at midrange and have another sub for true lows. It's tuned to 20hz currently. I would like to get another sub for 40hz and under specifically. I'm curious about changing the VBSS to 15hz first since it's free. Not at home for a while. Has anyone switched between the two modes and compared with their ears? The test graphs looks very close.
joker927 is offline
Old 01-20-2018, 02:21 PM
Quoted: 66 Post(s)
Liked: 5
Vbbs
I plan to build one soon with one slot for 15HZ- does this need 1 or 2 sheets material? if its two- its almost same price but UM 15" kit--
as is driver is $100--Inuke 1000dsp $199 materials prob $100 with one sheet
CrazyCramers is offline
Old 02-03-2018, 12:33 PM
Thought I would share a couple of my build pics. Standard VBSS build. Was the first non flatpack build I've done. It was really fun, plus it sounds awesome. So ya, now I'm hooked on DIY. Thanks guys!
[IMG][/IMG]
[IMG][/IMG]
No picture with the driver in, had to manage 2 flights of stairs before that went in.
[IMG][/IMG]
If nothing else, my "garage" is a little different than most!
ID:	2355744   Click image for larger version
ID:	2355746   Click image for larger version
Blorton, Brazle, biga6761 and 1 others like this.
Twedter is offline
