The V.B.S.S. DIY subwoofer design thread - Page 66 - AVS Forum | Home Theater Discussions And Reviews
 1294Likes
post #1951 of 2604 Old 03-16-2020, 10:15 AM
DavidinGA's Avatar
Quoted: 625 Post(s)
Liked: 298
2 more 18's incoming!
Sent from my Pixel 2 XL using Tapatalk
tjambro, qguy, OJ Bartley and 2 others like this.
Epson 5040, 150" 16:9 1.1gain, Source: HTPC w/madVR, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofers: 1 MiniMarty um18 w/NX3000D. 4 diy Slim VBSS 18" Subs w/NX3000D.
DavidinGA is offline
post #1952 of 2604 Old 03-16-2020, 10:47 AM
Quoted: 1299 Post(s)
Liked: 397
Originally Posted by jevchance View Post
@harrisu you should really move this to a new thread with a descriptive title. By posting this in VBSS you have limited your audience to only those that follow this thread.
I replied to the questions that were asked. I don't want to make/post anything on this thread that isn't related to VBSS. Please see my initial post and its all about asking opinion about VBSS. Still waiting if someone can chime in and answer them.
harrisu is offline
post #1953 of 2604 Old 03-16-2020, 10:48 AM
Liked: 397
Are these VBSS Low Tuned?
harrisu is offline
post #1954 of 2604 Old 03-16-2020, 10:59 AM
DavidinGA's Avatar
Quoted: 625 Post(s)
Liked: 298
They're the slim design cabs tuned to 20hz
Name:	Slim VBSS 17in Cab Design.png
post #1955 of 2604 Old 03-16-2020, 11:10 AM
Liked: 397
Very nice. Which driver are you planning to use? Any build thread or cut sheet for this one? I'd like to build 2 as well. Less depth will work very well for me as well. I see you have Mini Marty as well. Are you going to replace it or integrate with it? Would be great to hear their comparison assuming you'd end up using same driver and location.
harrisu is offline
post #1956 of 2604 Old 03-16-2020, 11:27 AM
DavidinGA's Avatar
Quoted: 625 Post(s)
Liked: 298
Yes, I love having less floor space taken up by using a slimmer cab!
Check post 1674 of this thread for the info on the slim build - https://www.avsforum.com/forum/155-d...l#post58849884
I have already built 2 of the slim 18's and I am now building 2 more. They all will have the pa460 driver.
I still have the mini marty and have been using it with the 2 vbss I have already built. They complement each other very well. The marty with the um18 driver does most of the low-end work and the vbss subs really give me what the marty struggles with - mid-bass.
I'll end up have the one mini marty with the um18 driver and then 4 vbss with the pa460 drivers. Hopefully, I'll have enough and then I can finally stop building
post #1957 of 2604 Old 03-16-2020, 12:45 PM
Liked: 397
Thank you sir. Much appreciated. Yeah this PA460 driver is just an amazing gem specially for the price we pay. @LTD02 designed a NF box for me with 15 degree tilt on the front to place it NF to be used with PA460. Even though I don't use it anymore, I do clearly remember how impressed I was with its sound. It brings Music alive. Really good driver. I had exactly the same situation as yours. I had 2 Mini Marty but was missing a bit of Mid-Bass. I swapped 1 Mini Marty with this new PA460 box and the mid bass sounded so well. It had so much texture to its sound. Hard to explain but yeah PA 460 in that box worked very well with Mini Marty.
Its just crazy how amazing all these DIY subs are. Absolutely amazing stuff
LTD02 and DavidinGA like this.
harrisu is offline
post #1958 of 2604 Old 03-17-2020, 07:09 AM
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
From the EQ/crossover settings on the first post
Filter/crossover:
Highpass 20hz Butterworth 12dB
Lowpass 250hz Butterworth 12dB
Why is the low pass on the high side of this subwoofer (250hz), normally we cross the sub at around 80hz, right?
qguy is online now
post #1959 of 2604 Old 03-17-2020, 07:26 AM
AngryJeremy's Avatar
Quoted: 68 Post(s)
Liked: 40
Originally Posted by qguy View Post
Tried the VBSS earlier and I am thinking about selling my PB12-NSD Bass SLAM is tremendous. I thought the PB12 was loud enough for me and I even had second thoughts about building this subwoofer as the PB12 was already a very potent sub specially in the very near field position, but since I already had all the items except for the enclosure, I pushed through with the build . No regrets building this subwoofer, well worth the wait, 50 days for shipping for the driver as I live in Manila Philippines and numerous trips to hardware store to buy stuff for the enclosure, not to mention the body ache I am experiencing right now from sanding the enclosure.
A friend of mine just bought the SVS SB12 and is blown away - wants to buy more. I've never heard an SVS sub, I know they're nice, but I told him to come check out the PA460's before dropping another $1,000 on sealed 12's
John Dowty likes this.
Custom Statement II L/R/C & PA460 subs
AngryJeremy is offline
post #1960 of 2604 Old 03-18-2020, 12:48 PM - Thread Starter
mtg90's Avatar
Quoted: 905 Post(s)
Liked: 1740
Filter/crossover:
That lowpass is not for the crossover to the speakers, you still need to use your AVR to set the subwoofer/speaker crossover frequency. That 250hz lowpass does a few things, it flattens the top end response a little before providing a gradual roll-off and helps cut down on noise that gets picked up in the signal chain from being reproduced by the woofer.
LTD02 likes this.
mtg90 is offline
post #1961 of 2604 Old 03-18-2020, 01:16 PM
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
I am not using an AVR, I am using a vintage amp, MiniDSP and a power amp for the VBSS, so should I set the LPF to 80hz then ?
qguy is online now
post #1962 of 2604 Old 03-18-2020, 01:24 PM - Thread Starter
mtg90's Avatar
Quoted: 905 Post(s)
Liked: 1740
In your case yes you can drop that to 80hz to achieve the proper crossover frequency, you should also change it to a 24dB slope.
qguy likes this.
mtg90 is offline
post #1963 of 2604 Old 03-20-2020, 06:36 AM
John Dowty's Avatar
Liked: 9
I went ahead and took apart my nx3000d and added a decent amount of heatsinks on various warm components.
Probably doesn't 'need it' but I had a lot sitting around from old projects so might as well.
I've had a good week or two of listening and playing around with my 2 vbss units now.. and I'm still floored.
They are so fun, and really bring a lot more to movies. Wife loves them also, which is great.
Thanks again mtg90.
tjambro, qguy and asarose247 like this.
John Dowty is offline
post #1964 of 2604 Old 03-21-2020, 02:18 PM
Mashie Saldana's Avatar
Quoted: 1491 Post(s)
Liked: 1375
Is there a triangular corner version of the 15hz VBSS floating around?
alangsk likes this.
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is online now
post #1965 of 2604 Old 03-21-2020, 02:56 PM
Dbuns's Avatar
Quoted: 37 Post(s)
Liked: 1
I’m looking at getting a second hand iNuke 3000 or 6000 paired with a miniDSP HD to power 4 x VBSS.
Just wondering if I get the 3000, does that mean the miniDSP will only be able to DSP the two subs that are run in bridge? As opposed to the 6000 that can DSP all 4 subs separately?
Thanks!!
Dbuns is offline
post #1966 of 2604 Old 03-21-2020, 06:28 PM - Thread Starter
mtg90's Avatar
Quoted: 905 Post(s)
Liked: 1740
The Inuke 3000 can power eight subs total, four per channel but you only have those two channels of separate DSP to work with. The four channel version of the inuke 6000 is basically two 3000's in one unit, so you do have four separate channels to use and can add up to sixteen subs total (four per channel).
Usually if the subwoofers are colocated or symmetrically placed in the room (equidistant to MLP) they can be run on the same amplifier channel and share DSP settings.
mtg90 is offline
post #1967 of 2604 Old 03-21-2020, 06:52 PM
DavidinGA's Avatar
Quoted: 625 Post(s)
Liked: 298
Nx3000d setup question...
I have a NX3000D running 4 vbss.
2 sets are wired to output channel A and 2 sets are wired to output channel B.
I have ONE input from the avr to input channel A.
I want to be able to apply individually dsp to each set of channels, so I have it set in Biamp1 mode.
My issues is that I thought with this setup I would simply be able to turn the channel A attenuation knob off on the front when I wanted to run rew for channel B and vice versus for channel A, but this doesn't appear to work. Should it?
When I turn the attenuation knob of channel A off I get nothing being sent to the channel B vbss. It seems the channel A attenuation knob must be engaging for channel B to available. Is this right? Do I have to physically disconnect the channel A vbss set from the nx3000d to dsp channel B?
post #1968 of 2604 Old 03-21-2020, 06:57 PM
nbk13nw's Avatar
Quoted: 95 Post(s)
Liked: 60
Have you tried splitting the single sub out on the avr and running a separate input to both channels on the amp?
Sent from my SM-G988U using Tapatalk
Yamaha CX-A5200, Yamaha MX-A5000, Sanway DSP-6KQ, XBox One X, Panasonic DMP-UB900, NVIDIA Shield, D-Link 16-Port Gigabit Switch, Caavo, Control Center, 2 x JBL Studio 590 Mains, 1 x JBL Studio 520C Center, 2 x JBL 580's side surrounds, 2 x JBL 530's rear surrounds, 4 x RSL C34E's ATMOS, 4 x Chane SBE-118's
nbk13nw is offline
post #1969 of 2604 Old 03-21-2020, 07:49 PM
DavidinGA's Avatar
Quoted: 625 Post(s)
Liked: 298
That's what I'm going to do next if the biamp1 method doesn't work (I'll have to order another cable). I would then just run the amp in dual mode, right?
post #1970 of 2604 Old 03-23-2020, 06:01 AM
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Did not like the outcome of the stain, so BLACK it is
Been listening to this subwoofer for a week and it is AWESOME, This is my first DIY subwoofer build and I am now thinking of my second build, Why did I ever click the "DIY speaker and Subs" Link I HATE YOU ALL !!!
Thanks to @mtg90 !!!
qguy is online now
post #1971 of 2604 Old 03-23-2020, 07:25 AM
Liked: 1375
Very nice, what is the external size for this version?
post #1972 of 2604 Old 03-23-2020, 07:41 AM
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Height: 25.5
Depth: 26
Width: 21.5
Mashie Saldana likes this.
qguy is online now
post #1973 of 2604 Old 03-23-2020, 08:05 AM
Quoted: 248 Post(s)
Liked: 238
The gain knob works on the input, not the output. So, if you only have signal going into channel A, then only the channel A gain knob will be functional when in BIAMP mode. As @nbk13nw suggested, you'll want to split the signal if you want to run separate gains.
Denon X1300W/DIYSG Fusion 12 LCR/Volt-10 Rears/Micca M-8C Heights
2 @ VBSS End Tables - 2 More VBSS complete!
Epson 2030/DIY 110" AT Screen
Eosone RSF1000 for Enjoying Music
jevchance is online now
post #1974 of 2604 Old 03-23-2020, 08:08 AM
DavidinGA's Avatar
Quoted: 625 Post(s)
Liked: 298
Ok, thanks.
post #1975 of 2604 Old 03-23-2020, 08:27 AM
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Using a Parasound HCA 1200ii,Which would be a better setting for my amp using the Dayton Pa-450
Bridged mono at 625 watts at 8 ohms or I have the option of just using one channel of the amp for 250 watts at 8 Ω / 450 watts at 4 Ω.
qguy is online now
post #1976 of 2604 Old 03-23-2020, 08:32 AM
a77cj7's Avatar
Quoted: 1043 Post(s)
Liked: 1085
For a single sub, bridged 8ohm.
For two, stereo 8ohm, but the amp is somewhat underpowered.
Chris
qguy likes this.
a77cj7 is online now
post #1977 of 2604 Old 03-23-2020, 12:24 PM
BlueGhost's Avatar
Quoted: 82 Post(s)
Liked: 52
That Parasound HCA 1200ii should be pretty close power wise to what an Inuke 3000 does on a single channel.
I'll be using 2 of the 500 Watt Dayton DSP plate amps to power my 4 VBSS subs. I'm thinking it will be more than enough for my small 14 ft x 12 ft room.
BlueGhost is offline
post #1978 of 2604 Old 03-23-2020, 01:44 PM
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Why not just one Inuke 3000 ?
qguy is online now
post #1979 of 2604 Old 03-23-2020, 02:08 PM
BlueGhost's Avatar
Quoted: 82 Post(s)
Liked: 52
Mainly, because it makes life easier on a project that's already taking too long.
My "theater" is a spare bedroom, I had the room pre-wired when the house was built. They ran coax cable from the closet my equipment is in at the back of the room to where my subs will be at the front.
I actually have an Inuke I was planning to use. But, I would either have to run heavy gauge speaker cable from the back of the room to the front, or find a way to make the Inuke quiet and dim to put it up front near the screen. The plate amps are just way easier.
I picked up some of the JBL 12s, I'll put them in a box and hook the Inunke up in the garage.
post #1980 of 2604 Old 03-23-2020, 02:48 PM
Quoted: 33 Post(s)
Thanks to @mtg90 for this awesome design and everyone helping each other in this thread.
Finally got one VBSS complete along with AT screen and a free standing stand for it to use in my unfinished basement theater. Nothing fancy, just a plain old black box.
Quite impressed with the sound it produces but I expected a little more chest thump. I knew I would not get much in the lower frequency. The volume of basement is probably too much. Probably will build one more to use the inuke 1000 dsp to its max potential and have a little more output.
Currently 20Hz settings loaded with yamaha receiver crossed at 80 Hz and running the LFE signal at +6 from the receiver and the knob on inuke at 3/4th.
Specs:
- the original specs for the cuts.
- titebond II for glue.
- PL premium for glue and seal the gaps where cutting was not precise.
- Two coats of rustoleum satin black enamel.
- #6 1 1/4" drywall screws to mount the driver. Glued pieces of 3/4" plywood at the screw positions behind the mdf baffle to give more wood for the screw to bite.
- Used 1-1/4" foam mattress topper from walmart to line the top, back, bottom and sides adjacent to speaker driver.
- Used the baffle to mount neutrik female panel mount connector to keep my option open if I ever wanted to use it as end table.
- Had to use 14 guage wire to connect the driver to the neutrik female panel mount connector. Couldnt get the belden 12 gauge speaker cable to work with the soldering iron on the connector.
- Used +1 and -1 on the neutrik female panel mount connector to keep it simple. If I ever use another amp, I can bring +1 -1 from it without having to guess.
Here are the results:
With polk CSi5 on top and RTi8s as the front channels.
DavidinGA and Bnaan like this.
living room: 60" 4k TV | XBox one S | Apple TV 4k | Fire tv stick 4k | Sony BDP 6500| Yamaha rx-v7810 | Polk Audio 65RT 7 channels | Dayton Audio sub-120 | incomplete theater: 166" 2.40:1 AT screen | Epson 5040ub | Sony SACD player | Sony BDP 6500 | Yamaha rx-v667 | Adcom 5600->Polk audio RTi8 | CSi5 | FXiA3 | RTi4 | inuke nu1000dsp -> 2 VBSS subwoofer |Office: Denon 1930CI SACD player | Yamaha rx-a730 | Polk RTi4
trjn is offline
