AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   Convert active sub (dead amp) to passive sub (https://www.avsforum.com/forum/155-diy-speakers-subs/2255754-convert-active-sub-dead-amp-passive-sub.html)
zevonrocks 12-21-2015 10:57 AM
Thanks in advance for any assistance.
Old Klipsch RSW-10D. A meter tells me the amp is getting power. But nothing happens. So I don't believe it's the power supply.
Regardless. Without buying repair costs, I'm exploring connecting an external amp.
This model sub has the active driver plus the passive driver, that's why I can't just plug in a new plate amp - the existing amp sits on the completely enclosed bottom of the sub; the power plug is on the back of the sub, with wiring inside the sub to the plate amp on the bottom.
So, with my incredibly limited knowledge, it seems like one hurdle will be routing the speaker wires to the outside of the enclosure.
So I'm looking for guidance. Do I drill a hole in the MDF, route the wires through, and seal the hole with, I don't know, silicone or something like that?
Or I could modify the plate that holds the power plug: remove the plug or fuse for example, (I could even drill a hole through that plate I suppose), route the wires through that, and then seal with something?
Again, I thank you for any guidance.
squiers007 12-21-2015 01:11 PM
Before we get into the details on how to wire it up, what size amp was the stock amp and what size plate amp were you thinking about? Depending on the cost to replace the amp it might make more sense to buy a completely new sub instead...
rsvr79 12-21-2015 01:19 PM
It was a 500w RMS amp with EQ capabilities. One 10" driver and one 10" passive radiator.
zevonrocks 12-21-2015 02:17 PM
Yes, the question is, how much money do I want to sink into it. Thank you for that feedback.
I already did buy a new one, a Hsu Research 15 inch sub. Very happy with it.
So my thinking is, if I can buy a used or low-priced 1000 watt amp - I've seen mentioned in these forums something such as Behringer iNuke, ~$150 - $200 - I could give myself a little project, learn a little, and end up with a functional subwoofer along the way.
As the other poster noted, it is a 500 watt amp in the original subwoofer.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
