What fasteners are you using for big drivers? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 56Likes
post #61 of 83 Old 01-04-2016, 11:08 AM
rhodesj's Avatar
Quoted: 1010 Post(s)
Liked: 600
While in still firmly in the wood screw camp, I definitely understand using those slab nuts on a commercial product. Little things like that go a long way toward giving an impression of quality in the product, and those slab nuts beat the sauce out of T nuts. Awesome that you're making them available on the forum.
dgage likes this.
rhodesj is offline
post #62 of 83 Old 01-08-2016, 07:44 AM
neo_2009's Avatar
Quoted: 354 Post(s)
Liked: 265
neo_2009 is online now
post #63 of 83 Old 01-08-2016, 09:31 AM
klipsch's Avatar
Quoted: 194 Post(s)
Liked: 100
All those t-nuts looks nice ... I just used what I had laying around for my 8 HT18s ... Simpson StrongTie #10 1.5" hex head structural screw ... think I bought them at a local HD
klipsch is online now
post #64 of 83 Old 02-06-2016, 11:19 PM
bob_m10's Avatar
Quoted: 88 Post(s)
Originally Posted by neo_2009 View Post
do you install these on the front or back of the baffle? See attached pic I saw on Amazon? Bob
bob_m10 is offline
post #65 of 83 Old 02-07-2016, 03:57 AM - Thread Starter
SpinMonster's Avatar
Quoted: 514 Post(s)
Liked: 315
I went the same route as NotNyt did since he runs the same TC sounds LMS drivers I have. They weigh 86lbs each. I just used wood screws and there is no issue in 7 weeks with the insane pounding I get from these subs. I didn't want to risk something stripping out on me.
SpinMonster is offline
post #66 of 83 Old 02-07-2016, 05:04 AM
neo_2009's Avatar
Quoted: 354 Post(s)
Liked: 265
On the back.
I've used this fasteners, that i managed to get locally after a lot o searching:
post #67 of 83 Old 02-07-2016, 12:00 PM
Iron Maiden's Avatar
Quoted: 575 Post(s)
Liked: 218
Building a pair of Ultimax 18's for someone. He bought everything from parts xpress, including the fastener kit with Tnuts.
I scuffed up the backside with an awl to really give the epoxy something to bite into. Then covered the area with epoxy, coated the portion of the tnut that inserts into the wood, and installed them. Used the bolts with washers to draw them in tight and square. Then, before the epoxy set, put a wood screw in to secure the tnut. Once all were done, I went back over them all with more epoxy to lock it all in place. Let it sit overnight before removing the bolts.
OJ Bartley likes this.
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #68 of 83 Old 11-02-2016, 11:33 AM
EndersShadow's Avatar
Quoted: 1269 Post(s)
Liked: 1539
I thought I would revist this thread to post a couple pictures of the slab nuts I purchased from @dgage for anyone interested. I used them on a Denovo Audio 4 cubic foot flatpack with a Dayton UM18 driver. I bought 30 of em total, 10 for this kit, 10 for the next kit (same one) leaving enough for another sub at a later date. They got shipped super quick and worked super easy. I'd HIGHLY suggest em, especially for the cheap cost.
I figured I should be able to swap drivers in and out to my hearts content and also really secure them down too.
Slab Nuts mounted to the back of the baffle.
I've also used furniture inserts (as shown in the pictures I posted earlier in the thread, and here again to save time). I used those on my Martycube (pictured below) as well as on the VBSS enclosure I'm working on.
PS I like the slab nuts better.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #69 of 83 Old 11-02-2016, 01:17 PM
NWCgrad's Avatar
Quoted: 1283 Post(s)
Liked: 1332
I have a bunch of slab nuts and socket head bolts if anyone needs any.
______________________________________
Home Theater:
https://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #70 of 83 Old 11-03-2016, 12:59 AM
Quoted: 105 Post(s)
Liked: 56
You all are overthinking it. Wood screws are very strong in 1 1/2" MDF. If you want to remove and reinstall the wood screw, you should run the screw in reverse till it drops into the old thread that was originally cut and then reinstall. The clamping force doesn't need to be that much to hold a speaker in either. I have a feeling people are over driving the wood screws which is causing the holes to strip out or the head of the screw to break.
I use 1 3/4 drywall screws. I hold a piece of wood over the driver so that I don't slip and run my bit into the driver. Pre drilling with the proper drill bit helps prevent this. Pan head wood screws are the best but you can't run out to the store and get them generally.
The force of a large sub isn't nearly enough to pull a set of dry wall screws out. The coarse thread work better if you can get a hold of them.
Michael Rodriguez is offline
post #71 of 83 Old 11-03-2016, 06:09 AM
Liked: 1539
Well this is AVS... what do you expect.
Plus an extra 10 bucks and 10 minutes of time to mount the slab nuts when your building the box isn't really that big a deal.
Is it overkill... ABSOLUTELY... Is 99.99% of what we talk about on this forum overkill to 99.99% of the population..... ABSOLUTELY!
1st Cav likes this.
post #72 of 83 Old 11-03-2016, 06:31 AM
1st Cav's Avatar
Quoted: 301 Post(s)
Liked: 146
Not to mention the fact that extra 10 min & 10 bucks will give an invaluable piece of mind to the diy'er that may have to/want to change out drivers whenever the latest flavor of the month comes out.
Sent from my SM-N910V using Tapatalk
1st Cav is offline
post #73 of 83 Old 11-03-2016, 06:51 AM
Liked: 1539
Yup, that was my thought, especially since I keep waffling on going with a HST driver at some point, and that beast is heavy at 75lbs.
post #74 of 83 Old 11-03-2016, 07:25 AM
JohnDean's Avatar
Quoted: 551 Post(s)
Liked: 259
I use these exclusively now. Of course I also quit using MDF completely.
https://www.parts-express.com/m5-x-3...0-pcs--081-312
JayDee78 likes this.
JohnDean is offline
post #75 of 83 Old 11-03-2016, 07:47 AM
corradizo's Avatar
Quoted: 1550 Post(s)
Liked: 1608
As much as I'm usually for overkill I don't know that the size and hole patterns are the same from driver to driver. YMMV.
corradizo is offline
post #76 of 83 Old 11-03-2016, 07:54 AM
Liked: 1539
You are 100% correct but IIRC the PE site has the CAD drawings of the UM18 and I think Nick has emailed similar to folks on his HST in the past....
post #77 of 83 Old 11-03-2016, 12:33 PM
Quoted: 575 Post(s)
Liked: 218
Not sure why people think it is overkill to use any type of threaded option. Wood screws work perfectly fine, don't think many argue that it isn't. But I think most of us using inserts, tnuts, whatever..... simply like this better. I would much rather install my drivers using an allen wrench rather than a screw driver or drill. You don't have to use pressure to keep the fastener head from stripping. It's pleasurable to simply thread the bolts in and be able to torque them down properly.
A member on this site cnc'd these fasteners for me. 16 of them for the two FTW-21's I bought. By far the best method I've used so far. Used 1.25" wood screw to anchor the blocks in place, then used silicone to cover the screw heads and seal the mounting hole. The bolts I got only go about 3/4 of the way into the block so the silicone will simply prevent any air leaks. Very stout setup.
post #78 of 83 Old 11-03-2016, 02:15 PM
Bill Fitzmaurice's Avatar
Liked: 5778
Those are nice, so are these:
http://www.speakerhardware.com/recex...rew-1-12x8.php
+1. With screws if the hole pattern is different just rotate the new driver, drill new pilots and you're good to go.
notnyt and Iron Maiden like this.
Bill Fitzmaurice is offline
post #79 of 83 Old 11-03-2016, 02:23 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
Bassment is offline
post #80 of 83 Old 11-03-2016, 03:20 PM
Vince_B's Avatar
Quoted: 317 Post(s)
Liked: 214
Yup screws. Well technically these are all screws but pointy screws. The t nuts and slabs are a pain and can fail to line up perfectly and make it annoying to install. Also sometimes if not perfectly aligned they come loose inside while partially threaded and then it really sucks.
Edit - just drill the right size hole, and use some finesse. As mentioned you can reuse the same holes with just a small amount of care.
Vince_B is offline
post #81 of 83 Old 11-04-2016, 11:05 AM
jkhome's Avatar
Quoted: 115 Post(s)
Liked: 74
I overkilled it on the last build, but the subs are downfiring so wanted the extra insurance. Used the upgraded t-nuts from PE, and extra BB ply blocks for them to bite into. Added #8 screws on each side of the T-nuts and epoxy to prevent slip.
Glued and screwed the blocks into the inside of the cabinets with drywall screws and used bolts and washers to line the blocks up properly and secure until the glue was dry. Then later used 1/4-20 SS socket cap threaded screws for the drivers.
One thing I did to ensure the holes lined up is I used each driver that was going into it's box as a guide, and also marked the orientation of the driver on the box so the hole on the driver used to mark would hit the same hole on the box when mounting the driver later. Had no problems with misalignment.
jkhome is offline
post #82 of 83 Old 01-06-2018, 08:09 AM
NINaudio's Avatar
Quoted: 35 Post(s)
Can someone explain to me how you install the slab nuts? All the pictures are gone because photobucket... Do you mount them from the inside just like you would t nuts?
| Samsung UN55H7150 | NVIDIA Shield TV Pro | Denon AVR-X4000 | Boston Acoustics Lynnfield VR 950 mains, VR 10 center, NHT Superzero 2.1 surrounds | Ultimax 18" powered by a Crown XLS 1502 |
NINaudio is offline
post #83 of 83 Old 01-06-2018, 09:57 AM
Liked: 1539
This pictures is from the inside of the baffle
Sent from my iPhone using Tapatalk (so ignore any typos grammatical errors because my iPhone predictive text stinks)
