Dayton Audio HO15 Build - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By ClevelandFreeman
post #1 of 13 Old 01-04-2016, 09:16 PM - Thread Starter
Building a box for my buddy. I've had this HO15 sitting around the house for about a year now. It is around 6.4 CUFT, tuning came to around 19.5 HZ. It will be powered by a BASH 300.
ID:	1162562   Click image for larger version
ID:	1162570   Click image for larger version
ID:	1162594   Click image for larger version
ID:	1162610   Click image for larger version
ID:	1162626   Click image for larger version
ID:	1162634   Click image for larger version
ID:	1162642   Click image for larger version
ID:	1162650   Click image for larger version
ID:	1162666   Click image for larger version
ID:	1162674   Click image for larger version
ID:	1162682   Click image for larger version
ID:	1162690   Click image for larger version
ID:	1162722   Click image for larger version
lovinthehd and doc5150 like this.
ClevelandFreeman is offline
post #2 of 13 Old 01-04-2016, 09:23 PM
asarose247's Avatar
Quoted: 1291 Post(s)
Liked: 1131
Looks clean, tight and very well groomed.
what are the chances he'll want another . . . ?
ya know, just to help smooth the room modes etc.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #3 of 13 Old 01-04-2016, 09:36 PM - Thread Starter
He just wanted an upgrade from the 10 inch commercial sub that he has. I had this Dayton in a 6 CUFT box, tuned to about 20 HZ for a little bit and it worked pretty good.
post #4 of 13 Old 01-04-2016, 09:56 PM
asarose247's Avatar
Liked: 1131
sounds like me . . .
I had 2 Klipsch Sub 10's , REW showed they died at about 37 HZ, no matter what,
i didn't have XT32 yet
so I've build a few "real" subs, 6 for myself in about 2 years,
ROCK ON!
post #5 of 13 Old 01-05-2016, 07:54 AM - Thread Starter
ROCK ON!
Same thing here, had this 15 HO powred by a Yung 300. When I finaly got a mike and REW, the sub was cutting out around 32 HZ.
post #6 of 13 Old 01-11-2016, 09:02 PM - Thread Starter
Finally done! Sub sounds pretty good. I'll get some REW sweeps done maybe this weekend.
ID:	1179522   Click image for larger version
ID:	1179530   Click image for larger version
post #7 of 13 Old 01-12-2016, 06:55 PM
Quoted: 34 Post(s)
Curious how this works out, that's not a whole lot of amp for that driver.
Prana Ferox is offline
post #8 of 13 Old 01-12-2016, 07:15 PM
wvu80's Avatar
Quoted: 435 Post(s)
Liked: 377
All of the Yung SD models have a built-in filter that is set at 30 Hz.
Curious how this works out, that's not a whole lot of amp for that driver.-Prana Ferox
Agree. I run the Yung 500wpc with bass boost for the sealed enclosure and it's a little light for the 15" HO, which can take 800 rms.
It still sounds pretty good.
wvu80 is offline
post #9 of 13 Old 01-13-2016, 02:27 PM
lknhomeaudio's Avatar
Quoted: 288 Post(s)
Liked: 152
It ought to. You're not even down 3db from max power!
lknhomeaudio is offline
post #10 of 13 Old 01-14-2016, 10:47 AM - Thread Starter
Yeah, but with the enclosure size, I am close to hitting xmax with 300 watts, this according to WinISD.
post #11 of 13 Old 01-14-2016, 06:22 PM
Quoted: 34 Post(s)
At what frequency? Are you including the BASH's high pass filter in your model? Are you assuming stock filter settings or are you adjusting it?
post #12 of 13 Old 01-14-2016, 07:45 PM - Thread Starter
The default HPF on the BASH 300 is 17.7 HZ with 1 dB of boost from 25-30 Hz. That is the filter settings I am using. WinISD is saying that at 14.5 HZ, xmax is 11 mm peak.
post #13 of 13 Old 01-14-2016, 07:48 PM
Quoted: 288 Post(s)
Liked: 152
I'm a huge fan of that Bash 300! More than enough for most people...
