Bracing again - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 87Likes
post #181 of 337 Old 02-27-2016, 03:30 PM
JackNC's Avatar
Quoted: 146 Post(s)
Liked: 40
Nevertheless, quoting from p15 in "On the Design of Loudspeakers for Broadcast Monitoring",
" The approach adopted by H.D. Harwood and now an established BBC tradition is to contruct cabinets of thin plywood backed by a layer of highly damped bituminous sheet"
download the doc at:
http://www.bbc.co.uk/rd/publications/rdreport_1988_14
JackNC is offline
post #182 of 337 Old 02-27-2016, 05:35 PM
corradizo's Avatar
Quoted: 1537 Post(s)
Liked: 1603
How do you test to see if you have too much vibration? If I put my hand on my 4cuft flatpack SI HT18 sealed sub that I have 4 lbs of r13 fiberglass insulation inside, I feel something when the sub is pumping, but I have no idea if it's bad or good. Do you put a quarter on top and if you can see it bounce it's bad? A glass of heavy cream and if it turns to whip cream your in trouble?
Javs likes this.
corradizo is online now
post #183 of 337 Old 02-27-2016, 07:09 PM
Bill Fitzmaurice's Avatar
Liked: 5777
You measure it. Audible vibrations will show up on the response chart. Of course you'd measure at expected listening levels, not just 1 or 2 watts.
Bill Fitzmaurice is offline
post #184 of 337 Old 02-27-2016, 07:11 PM
corradizo's Avatar
Liked: 1603
Thanks Bill, I have REW and a umm6 mic. Would I take reference sweeps nearfield? At the mlp? What would I look for in the measurements?
post #185 of 337 Old 02-27-2016, 07:15 PM
Liked: 5777
You have to measure outdoors, otherwise anything in the room that vibrates will show up. With a sub measuring at 4 meters with at least 100 watts input will reveal box vibrations as narrow spikes above the pass band.
post #186 of 337 Old 02-27-2016, 08:34 PM
corradizo's Avatar
Liked: 1603
Got it. Thank you. If any subs leave my house, I'm afraid my wife would not allow them back in.
kutlow likes this.
post #187 of 337 Old 02-27-2016, 11:17 PM - Thread Starter
bob_m10's Avatar
Quoted: 88 Post(s)
It's not. The only place where mass damping is the better option is when bracing isn't an option. Sheet metal car doors, for example.
Hope I am getting this, the damping is mostly there for distortion (Harmonic) in the back wave so it does not come out through the cone? The fundamental we want to hit the back of the cone so it brings the cone back to zero when the signal changes?
bob_m10 is offline
post #188 of 337 Old 02-28-2016, 06:48 AM
Liked: 5777
That's something different. Mass damping is intended to reduce panel vibrations. Acoustical damping, using open cell foam, cotton or polyester batting or Type 700 rigid fiberglass, is intended to reduce internal reflections. Stuffing a sealed cab with acoustical damping lowers system Qtc.
post #189 of 337 Old 02-28-2016, 07:38 AM - Thread Starter
bob_m10's Avatar
Quoted: 88 Post(s)
so we are talking about three items,
1) There is damping that can be applied to a panel to reduce panel vibration
2) Then we have damping for integral waves which uses soft material like foam, this is generally a inch or so on the inside panels.
3) Then we have "stuffing" which is when we add even more soft material and is used to lower Qtc if required by design.
bob_m10 is offline
post #190 of 337 Old 02-28-2016, 01:47 PM
corradizo's Avatar
Liked: 1603
http://home.earthlink.net/~ralphmeister/subbox.htm
I'm going to put 4.26lbs if r13 into a 2.8cuft box per the link above. That's 1.5lbs/cuft. I need to get a dats kit or figure out how to measure impedance with REW to figure out the actual QTC.
And from the cookbk:
post #191 of 337 Old 02-28-2016, 05:48 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 47
Do you guys think this is good enough with bracing? The two rear panel braces are 1 3/4 inch wide 3/4 MDF.
The enclosure is for HST-18 with 2200 watts @4ohm pushing them. I was thinking about adding a brace to go from the rear panel to the center brace on the top and bottom but don't know if I need it or not. Let me know what you think.
kutlow is offline
post #192 of 337 Old 02-29-2016, 05:10 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 47
I added 4 braces that goes from the rear panel to the center brace. Do I still need to add the same to the front part of the enclosure even though it has a double front baffle? Here is a current picture.
kutlow is offline
post #193 of 337 Old 03-04-2016, 10:30 AM
Quoted: 259 Post(s)
Hello @Bill Fitzmaurice and @bitmap42 :
I wish I had read this thread before I glued the top panel of my cabinet (now its fairly hard to add more bracing). I am building a dual opposed 3.5 CF cabinet for a pair of Infinity 1260s. I have depicted the existing bracing in the attached picture. It’s basically 3 lengths of 1” x 0.75” mdf (2 horizontal and 1 vertical) ; the internal box dimensions are 16.5 x 16.5 x 23.25 (height). The speaker hole on the front baffle is actually closer to the top of the box (such that the cut is ~5” from the top and ~8” from the bottom). The MDF I used is 0.75” throughout.
When I glued the front and side walls to the base panel the cabinet seemed very sturdy so I was lazy to add more bracing. How bad is my situation? Can I get away with this or do I absolutely need more bracing?
Speakers: Boston Acoustics VS260, VS325C
Subwoofers (sealed): Dayton UM18, 2x Infinity 1260 dual opposed + iNuke6000DSP
AVR: Yamaha RX-A2000
madhuxs is offline
post #194 of 337 Old 03-04-2016, 11:20 AM
Liked: 5777
Even with that minimal bracing it increases the stiffness to close to that of 1.5" unbraced, so it maybe fine. I'd use at least double that amount, but I also use 1/2" plywood for my cabs.
madhuxs likes this.
post #195 of 337 Old 03-06-2016, 09:41 PM
noah katz's Avatar
Quoted: 2017 Post(s)
Liked: 735
Resonance is moot. I thought I already covered that point.
It's not moot; it's the crux of the problem.
If a box "sings", it's at a panel resonant frequency.
This has been shown many times in speaker tests where they put accelerometers on the panels and link observed response issues to these resonances.
Vibration, which isn't the same thing, will detract from the performance of any speaker. If the speaker panels don't vibrate you're good to go. If they do then it's back to the old drawing board time.
By definition, resonance is vibration; it's the frequency at which mass and stiffness produce the highest vibration amplitude.
Wood-product panels that aren't heavily damped will have many times the vibration amplitude at resonance than any other freq.
Noah
noah katz is offline
post #196 of 337 Old 07-15-2016, 01:13 AM
Ferroll Givens's Avatar
Liked: 7
Great Idea for Bracing
That does happen, but it's a by-product of what bracing really does, which is to make the cab stiffer.
Pretty much, although you'll also hear any resonances inside the box unless it's well damped.
You're using at least three times the necessary material. This scheme gives as good a result as you can get but with the minimum of material:
It shows round dowels, but square or rectangular are OK as well.
Seems pretty sturdy to me, not exactly the same as the example. Didn't take much effort to do. Thanks Bill.
Name:	Internal Bracing Complete.jpg
Ferroll Givens is offline
post #197 of 337 Old 07-21-2016, 01:23 AM
Quoted: 676 Post(s)
Liked: 138
You could still have had twice as many reinforcement points if you simply hacked the sticks in 45 degree angles and applied them such:
But people will stick to what they have already done, or already think is right. Just human nature.
cms, aka driver diaphragm suspension mechanical compliance: 0.000065 meter/Newton or in standard form 6.5e-05 m/N. (smaller number is better)
rms, aka driver diaphragm suspension mechanical resistance: 6.41 Newton.sec/meter. (higher number is better)
ronny31 is offline
post #198 of 337 Old 07-21-2016, 05:30 AM
Liked: 5777
The reason why that scheme is less than optimal is clear: the braces themselves will flex. When the braces are perpendicular to the panels they can't flex.
Or what experience has proven to work.
post #199 of 337 Old 07-21-2016, 11:34 AM
16hz lover's Avatar
Quoted: 55 Post(s)
Liked: 70
There's always concrete enclosures
http://www.concrete-audio.com/en/
I'm not talking about the kind of speakers you just listen to, I'm talking about the kind of sound you can feel.
16hz lover is offline
post #200 of 337 Old 07-22-2016, 01:01 AM
Liked: 7
Heavy Concrete Enclosures
Might work very well, but not practical in home audio, especially DIY.
They might as will be made out of lead.
post #201 of 337 Old 07-22-2016, 02:53 AM
Quoted: 676 Post(s)
Liked: 138
The flexing of the bracing is insignificant in either case, because the difference in panel flex is very small with the two schemes. Only one scheme uses HALF the amount of material, so you can brace twice as many points on the sheets with the same amount of wood pole material. Furthermore, the bracing can be applied when the enclosure is completed, because all the parts fit through the driver hole.
Math tells us what is correct. The math says you are twice as well off by bracing diagonally, unless you wish to dispute the math then you are simply just disagreeing for the privilege to continue bracing in a less effective way. Why would you do that? I did the work because someone said to prove it and then the proof isn't enough to change existing opinion? Why do I even bother trying to improve your future?
PS: If you aren't familiar with models, the flex is exaggerated in the images or else you wouldn't be able to tell what flexed in what direction at all. its the numbers that matters.
ronny31 is offline
post #202 of 337 Old 07-22-2016, 05:07 AM
Liked: 5777
Experience tells me what works.
After you have designed, built and tested your first hundred speakers we can compare notes.
post #203 of 337 Old 07-22-2016, 05:53 AM
Quoted: 1247 Post(s)
Liked: 713
Math tells us what is correct. The math says you are twice as well off by bracing diagonally, '
I don't know the answer as to the optimal bracing configuration (though I expect it includes some sort of damping rather than rigid attachment) but your models only brace in 2D. How would you expand it to 3D?
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #204 of 337 Old 07-22-2016, 10:39 AM
Quoted: 676 Post(s)
Liked: 138
What do you mean? You don't have to brace a point twice. If the cross-section is looking through the longest dimension of the enclosure (height, lets say), it should be easy to tell how you brace it. The left side of the model would then be the double thickness baffle.
Of course, if you have a very large diameter driver in your baffle, the bracing to the baffle may need to be slightly different in spots. It would be rather cool to see someone use the driver basket for its strength.
I am perfectly willing to take your experience as argument enough on things I do not understand, if I do not want to take the time to learn about it for myself. But in this case argument from authority does not make me tip my hat. You can argue that your experience is the reason you do things the way you do them, but you can't make the argument that you are correct because you have experience.
ronny31 is offline
post #205 of 337 Old 07-22-2016, 11:18 AM
Liked: 713
What do you mean?
I mean a box is not a ring. Your scheme only accounts for four of the six sides. I'm having trouble seeing how it would work in a real box, where all six sides should be connected with bracing.
Serious Audio Blog
DS-21 is offline
post #206 of 337 Old 07-22-2016, 11:57 AM
Quoted: 676 Post(s)
Liked: 138
Well you should install google sketchup. Its free.
The bracing scheme depends on how many points you want to brace on each face (or rather, the max distance that can be unbraced). Draw up those points and begin planning your diagonal bracing. Remember to brace to your bracing instead of another side, if you already placed a brace nearby.
You can't really go wrong because however wrong you do, it still ends up being far stronger for less material (and only scrap material at that) than if you do window bracing or bracing between opposite sides.
ronny31 is offline
post #207 of 337 Old 07-22-2016, 12:06 PM
uniquepattern's Avatar
Quoted: 808 Post(s)
Liked: 857
My buddy used some fancy software to model the bracing for my 24's (He is a structural engineer and designs sky rise buildings)..
they are dead.... drivers moving full tilt - I can put a glass of water on top with few ripples across the surface......
Guess the science is there (obviously or else there would be a lot of buildings fall down during seismic events)
Please note: There is a COMBINATION of Braces..... One style only was not efficient according to the computer... and connection points are varied... Notice the lengths and placement of each brace point are not all the same...
DS-21 likes this.
uniquepattern is offline
post #208 of 337 Old 07-22-2016, 01:55 PM
Liked: 5777
And yet only a few months ago you stated that this was the best way to brace a cab:
Has your understanding of how speakers work and how to build them expanded all that much since you wrote post #51 in this thread?
Face2 and Augerhandle like this.
post #209 of 337 Old 07-22-2016, 05:03 PM
corradizo's Avatar
Liked: 1603
Looks like you have both "styles" Going on there. Cross opposing panels and the angled approach.
uniquepattern likes this.
post #210 of 337 Old 07-22-2016, 07:08 PM
Liked: 5777
I use angle braces where you can't use panel to panel braces, like where the driver would get in the way. I also use them where they can do double duty, as corner located ports. In a structural engineering situation they do have an advantage over panel to panel, as they will reduce the effects of rotational forces on the structure, whereas panel to panel won't. That tends not to be an issue with speakers, as they're not subject to rotational forces. This cutaway shows a Simplexx 18 sub that uses corner ports that double as braces, angle braces where there's no opposite panel to connect to, and panel to panel braces where they can be used:
