Athena micra sat1B blown? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-19-2016, 04:13 PM - Thread Starter
Liked: 0
I have 2 of these Athena speakers that have no sound output. When I put ohm meter leads across red and black the meter starts in meg ohm slowly rising until it shows open circuit.
I opened the enclosure and disconnected the 2 spade lugs attached to woofer. I put the meter leads across the woofer terminals and immediately shows a open circuit. Am I correct in assuming the woofer is blown? Is there a way to test the components on cross over to make sure that is okay? Where can I buy a replacement woofer?
Thanks in advance for an input.
Bstealth is offline
post #2 of 3 Old 03-21-2016, 09:52 PM
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
The best place to buy a replacement woofer is from parts express. They can try to match them as best as they can. By the way, I need to say, that I used to love Athena Speakers! They were great value on the market, especially their towers AS-f2. They sounded fantastic for how much they cost. Unfortunately Klipsch bought them out and seemed to bury the company. I guess you could see if Klipsch sells any replacements, but i doubt they would. I never saw another Athena speaker made after Klipsch bought them out, so I highly doubt they will have anything. Good luck resurrecting those Athenas!
Al Toid is offline
post #3 of 3 Old 03-22-2016, 03:29 PM - Thread Starter
Liked: 0
Thanks for the response. I will check out parts express.
Bstealth is offline
