Anyone else building DIYSG 1099s currently?? - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #1 of 62 Old 03-22-2016, 02:00 PM - Thread Starter
ddigler's Avatar
Quoted: 1102 Post(s)
Liked: 487
I am currently on crossover 3 of 3. Received them last week and hope to have them done this weekend! @mtg90 crossover boards are a Godsend.
Will post up some pics later!
LTD02 likes this.
ddigler is offline
post #2 of 62 Old 03-22-2016, 05:34 PM
LTD02's Avatar
Quoted: 2954 Post(s)
Liked: 3685
did you have a question or just look for moral support? ;-)~
ddigler likes this.
Listen. It's All Good.
LTD02 is offline
post #3 of 62 Old 03-22-2016, 05:54 PM - Thread Starter
ddigler's Avatar
Liked: 487
@LTD02 Haha you know that if I had a question you'd already have 4 or 5 PM's about it LOL
actually, I was under the impression these speakers were out of stock for a long time and that there was quite a backlog. They seemed to be relatively high demand and with him being back in stock I was surprised to not see any build threads on this particular speaker...
Nope the build are going pretty good. I'm going to test the second crossover now. The only thing I wish I could do is verify my crossovers are working somehow besides just listening to the different speakers for different frequencies which isn't very scientific...
LTD02 likes this.
ddigler is offline
post #4 of 62 Old 03-22-2016, 07:56 PM
Erich H's Avatar
Quoted: 1880 Post(s)
Liked: 2694
The parts came in about 1.5 weeks ago and they just started shipping again. I'm sure you'll see some 1099 builds soon.
ddigler and Bagua like this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #5 of 62 Old 03-23-2016, 04:50 AM - Thread Starter
ddigler's Avatar
Liked: 487
Thanks for checking in @Erich H This build is going great! I should have the crossovers complete tomorrow and then will mount them this weekend and dampen. In ref to damping, you still want me to use a handful of polyfil? Say one handful per section of speaker?
ddigler is offline
post #6 of 62 Old 03-23-2016, 05:15 AM
Erich H's Avatar
Liked: 2694
You will need a good amount more than that on the 1099's. I'll see if there are any pictures showing how much is needed.
ddigler likes this.
Erich H is offline
post #7 of 62 Old 03-23-2016, 05:33 AM - Thread Starter
ddigler's Avatar
Liked: 487
I also have loose foam out the wazoo if that can work...
ddigler is offline
post #8 of 62 Old 03-23-2016, 06:24 AM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2230
Is it open cell foam?
Put more in the mid chamber than the woofer chamber.
ddigler likes this.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #9 of 62 Old 03-23-2016, 06:38 AM - Thread Starter
ddigler's Avatar
Liked: 487
OK will do. Yes it is open cell.
For the price not opposed at all to use poly fil either. Will prob be less work as well.
Thanks Tux!
ddigler is offline
post #10 of 62 Old 03-23-2016, 07:05 AM
dm_rep's Avatar
Quoted: 61 Post(s)
I should be starting soon, just waiting for them to ship. I was going to use the UltraTouch Denim for damping like some others have used unless you guys would advise different. As for the terminals is there a benefit to using speakon connectors vs the other terminal cups?
ddigler likes this.
dm_rep is offline
post #11 of 62 Old 03-23-2016, 07:11 AM
Quoted: 93 Post(s)
Liked: 39
Not sure if there is a true advantage to using speakon connectors vs terminal cups. I plan on using speak on connectors to make it easier to connect wiring to. Also I believe the speakon connection is smaller compared to the terminal connections resulting in a smaller hole to drill out.
ddigler likes this.
Denon AVR-X4500
Pair of Volt 6's for surrounds
1099, Volt 6, Volt 6 Atmos builds
MBM 12s Build
Pair of Mini-Marty's with Dayton UM18-22
csmithny06 is offline
post #12 of 62 Old 03-23-2016, 07:30 AM
Girmic's Avatar
Quoted: 24 Post(s)
Liked: 37
I've been completely slacking (though I can blame work a bit), I only just recently finished gluing 1 box together of 3, just ordered crossover kits from mtg90 on monday and ive had the 1099's since august... I did however get my dual uxl build from the groupbuy done before x-mas so at least thats something..
ddigler likes this.
Girmic is offline
post #13 of 62 Old 03-23-2016, 07:33 AM - Thread Starter
ddigler's Avatar
Liked: 487
In a sense I envy your pace. I on the other hand find it difficult to pull back when I"m anxious for something. In the last month I've built (2) Volt 8 LX, (6) large subs and will be complete with (3) 1099's by weeks end lol
ddigler is offline
post #14 of 62 Old 03-23-2016, 08:54 AM
Quoted: 93 Post(s)
Liked: 39
I have the same drive. I completed my first DIY build in Jan, a 15" sub. I have received the 1099 preorder and will be working on those soon. While waiting on a the preorder I ordered another sub. I also ordered and built a pair of Volt 6's. I am already thinking of what my next project will be once I am done with the 1099's and Sub.
ddigler likes this.
Denon AVR-X4500
MBM 12s Build
post #15 of 62 Old 03-23-2016, 01:18 PM
thebedbeard's Avatar
Quoted: 57 Post(s)
Just getting started
thebedbeard is offline
post #16 of 62 Old 03-23-2016, 01:58 PM
sigma722's Avatar
Quoted: 614 Post(s)
Liked: 381
I finished mine about a week and a half ago. Center is only horizontal temporarily. Eventually it will be vertical behind AT screen.
sigma722 is offline
post #17 of 62 Old 03-23-2016, 02:25 PM - Thread Starter
ddigler's Avatar
Liked: 487
Nice! How do they sound then?
ddigler is offline
post #18 of 62 Old 03-23-2016, 02:40 PM
sigma722's Avatar
Quoted: 614 Post(s)
Liked: 381
I like them a lot. Certainly can get quite loud, and seem to reproduce sound accurately. With respect to the center, I sit pretty on axis to the center, so I don't think I'm losing too much sound quality there, but people to the left and right are probably missing out a bit. Been meaning to try to measure them to see how "well" I did with my build. I used Restore max/10x on these, and I wish I had read a bit more before going with that, as it is quite rough. It still looks nice, but I think I should have gone with 4x to get the more duratex looking finish. Will likely do 4x on the Marty's I'm currently building. It doesn't really matter for any of them since they'll all be hidden in the end though.
I ended up using a second speaker terminal post separate from where you tie your signal wires in to connect the limiter resistor. If I bridge those two terminals together, then that sets the limiter "on", or leaving it open is off. Figured that way I could test them both ways. Didn't want to deal with trying to find a switch that goes through 3/4" correctly and maintains a seal.
Right now I'm using a fancy iNuke box and travel books as my center channel stand, lol.
ddigler likes this.
sigma722 is offline
post #19 of 62 Old 03-23-2016, 08:01 PM - Thread Starter
ddigler's Avatar
Liked: 487
Great information here I appreciate this. Why the comment about sitting left to right and a problem with the center Channel SQ? Assume it's because of the horizontal orientation of the center, and not in reference to off axis SQ problem with the speakers?
That is an awesome idea in regards to the limiter. Not sure I fully understand how you wire this up can you explain this in more detail to me? To verify, this is in regards to the 10 ohm padding resistor correct? Any initial impressions in regards to which sound you prefer?
LoL on the fancy center speaker stand. I know the feeling I truly do... Boxes everywhere and chaos at the moment...
ddigler is offline
post #20 of 62 Old 03-23-2016, 08:08 PM - Thread Starter
ddigler's Avatar
Liked: 487
Two crossovers down and one to go! Pretty awful soldering skills but getting better from the 1st to the 2nd, gotta focus on the positives.
Enclosures coming along well! Missed a Nail in that one on the right that I have to pull haha
ID:	1333874   Click image for larger version
ID:	1333882   Click image for larger version
ddigler is offline
post #21 of 62 Old 03-23-2016, 08:20 PM
sigma722's Avatar
Quoted: 614 Post(s)
Liked: 381
Great information here I appreciate this. Why the comment about sitting left to right and a problem with the center Channel SQ? Is it because of the orientation of your Center Channel currently or because these speakers struggle with off axis sound quality? -- I'm just talking about the way the wave guide is oriented. If using center horizontally they have an optional baffle where they rotated the orientation of the waveguide/mids for people that watch it that way permanently. With the wave guide horizontal, the dispersion is better. So I'm watching these in a non optimal orientation until I get my center verticalized (made that word up) for behind my screen.
That is an awesome idea in regards to the limiter. Not sure I fully understand how you wire this up can you explain this in more detail to me? To verify, this is in regards to the 10 ohm padding resistor correct? Any initial impressions in regards to which sound you prefer? -- The core circuit for the crossover is the same with the limiter resister added in. The limiter is just on it's own little branch. So I put a "break" in that branch using those terminal posts, and if I connect them together it completes the branch, enabling the limiter. Most likely once I'm behind the AT screen I won't even need the limiter. I actually haven't even tested turning it on yet.
Answers above
sigma722 is offline
post #22 of 62 Old 03-24-2016, 05:14 AM - Thread Starter
ddigler's Avatar
Liked: 487
ddigler is offline
post #23 of 62 Old 03-24-2016, 11:48 AM
rondi's Avatar
Quoted: 69 Post(s)
Liked: 59
in post 3282 are some pix of a nice way to incorporate a switch for connecting the padding resistor.
https://www.avsforum.com/forum/155-di...l#post38236873
rondi is offline
post #24 of 62 Old 03-25-2016, 08:16 AM - Thread Starter
ddigler's Avatar
Liked: 487
Cool stuff and very professional! I need to look closer to see whether he mentions part numbers for the terminals and switch...
ddigler is offline
post #25 of 62 Old 04-12-2016, 09:04 PM
Liked: 7
Just received mine Saturday and since this is my first diy I'm taking my time, I don't want to make a mistake and I'm a little intimidated by the crossovers.
Sent from my XT1254 using Tapatalk
Bagua is offline
post #26 of 62 Old 04-13-2016, 08:21 AM
Quoted: 83 Post(s)
Liked: 32
what is the height of the tweeter and the midrange drivers from the ground? They look awfully low w.r.t. the level of a seated listener's ears. Also, is off-axis sound degradation a known thing with these speakers? I am asking as I am thinking of building a dedicated HT setup.
jwanck11 is offline
post #27 of 62 Old 04-14-2016, 07:54 AM - Thread Starter
ddigler's Avatar
Liked: 487
Pay attention to detail and you'll be fine IMO Bagua. Its not that difficult if you check and double check. As for the soldering, I am not good at it as I don't have many hours doing it. Again, slowly but surely with a good iron and good solder and you'll be fine.
Enjoy the build!
Bagua likes this.
ddigler is offline
post #28 of 62 Old 04-14-2016, 07:56 AM - Thread Starter
ddigler's Avatar
Liked: 487
Wanck - I am not sure whatsoever and will have to defer to the professionals on your questions... I know that when @LTD02 designed my speaker setup he was showing the 1099's on platforms to raise their height...
ddigler is offline
post #29 of 62 Old 04-14-2016, 09:44 AM
Quoted: 83 Post(s)
Liked: 32
That would make sense, based on my limited, growing understanding of the presentation and consumption of sound waves... and it's pretty easy to test, too - lol. Just lay on the floor and listen to a passage and then stand up and listen to the same passage. There is a marked difference. I just have never heard the waveguide so I don't know it's dispersion characteristics.
My current DIY set up is phenomenal for music (and the ribbon is at 38" surrounded above and below the mids) but I am thinking of using them just for music and having a dedicated HT - one of the high priority criteria for the houses we are looking at.
jwanck11 is offline
post #30 of 62 Old 04-14-2016, 11:05 AM - Thread Starter
ddigler's Avatar
Liked: 487
What is the ribbon?
Nice good luck on house hunting. I have waited many years in our current house to build my ht and now I'm doing it. Loving the build but massive project compared to what I was prepared for...
ddigler is offline
