Official SpeakerPower amplifier thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 209Likes
post #631 of 678 Old 02-23-2019, 09:14 PM
johnplayerson's Avatar
Quoted: 289 Post(s)
Liked: 70
You can always get the lingte Alpha 7 for 440 each plus shipping. Probably end up with four for the same price.
http://www.lingteaudio.com/bencandy-13-107-1.htm
For clone fans Sinbosan seems to be the new choice. Copper heat sinking and more of it, with an extended back on the transistors.
http://www.sinbosen.com/pid18180232/...-amplifier.htm
Voice your rant against higher amp prices, buy chinese...................
https://discuss.avscience.com/index.php?topic=459.60
A Good amplifier requires a adequate power supply, It does not matter what the amplifier is capable of if the power supply will not provide the power required. Most amplifiers have under rated power supplies. It is up to you to make sure you get the ones that are least under rated if at all.
johnplayerson is offline
post #632 of 678 Old 03-06-2019, 08:13 AM
NOLAGT's Avatar
Quoted: 56 Post(s)
Liked: 30
I am finally getting around to trying to tune my new sub setup (sp1 with 4 UM18s). I will be running a minidsp between my denon and my sp14k amp. Where do I set the knobs on the back of the amp? I have 1 plug going into the LFE input on the amp.
TIA!
NOLAGT is offline
post #633 of 678 Old 03-06-2019, 08:25 AM
MKtheater's Avatar
Quoted: 2374 Post(s)
Liked: 2327
Start with Gain to half, LFE adjust to 0, crossover all the way to the right(off), and delay or phase off.
Audio Design Associates/Outlaw
Speakerpower SP1-4000
subs-Re audio XXX 18 IB(LT).
DIY speakers-mktheater-S10/S12s
MKtheater is online now
post #634 of 678 Old 03-06-2019, 08:29 AM
NOLAGT's Avatar
Quoted: 56 Post(s)
Liked: 30
Thanks! I'll have to check the gain/freq knob but I am pretty sure I ahd phase off and the cross over to the right. I had to almost turn the gain knob all the way off for when I ran the calibration...the subs are nearfield behind the sofa. I like them hot so I adjusted it up and its a good step in the right direction...but I want to make sure the knobs are set right.
Thanks...now to see if I want to try to fit in some front heights in my entertainment center being built...didnt realize the Denon I have has amps for some lol.
NOLAGT is offline
post #635 of 678 Old 03-06-2019, 08:32 AM
MKtheater's Avatar
Liked: 2327
For my audyssey to work I needed to have my gain at 9 oclock. I then added gain to my desired level.
post #636 of 678 Old 03-06-2019, 08:34 AM
NOLAGT's Avatar
Quoted: 56 Post(s)
Liked: 30
Yea it was about that bad lol.
NOLAGT is offline
post #637 of 678 Old 03-06-2019, 09:19 AM
MKtheater's Avatar
Liked: 2327
I used to run my amp gains all the way up but adding the LFE adjust brings up the low end enough to back the main gain down for a nice balance.
post #638 of 678 Old 03-06-2019, 09:22 AM
NOLAGT's Avatar
Quoted: 56 Post(s)
Liked: 30
Yea after Audissy had its way I used my rat shack meter to see where things were. It had all the mains showing 71db so I bumped to 75 and I bumped the sub to I think 85-90 at 0 ref using pink noise.
I absolutely have been loving this amp and sub setup with the old audissy calibration from the last subs. Dims lights on breaker (pretty much dedicated 20amp with LED lamps on it) but has not tripped anything.
NOLAGT is offline
post #639 of 678 Old 03-24-2019, 10:21 PM
Pultzar's Avatar
Quoted: 200 Post(s)
Liked: 117
On SpeakerPower's facebook page I see some new models in the photos? SP2-12000-HCR. Does anybody know anything about this? Their website doesn't have anything on them.
Pultzar is offline
post #640 of 678 Old 03-27-2019, 11:39 AM
dsl1's Avatar
Quoted: 201 Post(s)
Liked: 417
Question on the plate amps before I call in.
If I run one sub off the internal wiring and a second off the neutrik out connector, does it put those subs in parallel?
________________________________________
DIY Mid Hi Speakers Build - SKHorn Build - Gjallarhorn Build SOLD - Othorn Build SOLD - SEOS 12 Build - Other Gear: JVC NX5 - Seymour Matinee Black - QSC CX4.5Q amps x 5 - QSC Q-sys 110f - Speakerpower 6000 x2
dsl1 is offline
post #641 of 678 Old 03-27-2019, 11:57 AM
STL D's Avatar
Quoted: 408 Post(s)
Liked: 476
They are wired in parallel.
STL D is offline
post #642 of 678 Old 04-02-2019, 03:39 PM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
Which amp do you guys recommend? The 700 or the 1200 for a UM18? I'll use two distributed UM 18's with two other subs for SBIR.
Motorola Modem sb6141> Emo Systems EN-70HD > (5) eero > Synology 1813+ (DSM 6.2), 4TB Seagate NAS Drives, 4GB RAM & Zero Surge & APC XS BX1000G/backup to Synology DX513) > Emo Systems EN-60KDS  > Roon > Mola Mola Tambaqui > BSS BLU 50 > (2) Hypex NCore NC502MP > JBL M2 Master Reference
jtwrace is offline
post #643 of 678 Old 04-03-2019, 07:48 AM
beastaudio's Avatar
Quoted: 5505 Post(s)
Liked: 5323
Are you dead set on internal amps? If doing two um18's I'd just get an sp2-4000 rack amp and put one on each channel at 4 ohm.
beastaudio is online now
post #644 of 678 Old 04-03-2019, 07:53 AM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
Hello! Long time no talk!
Not dead set on it but I don't want any fans and I'm going to use miniDSP 2 x 4 balanced for all sub integration anyway so from a cost standpoint, plate amps make sense.
jtwrace is offline
post #645 of 678 Old 04-03-2019, 08:01 AM
beastaudio's Avatar
Liked: 5323
NO fans on the rack amps either, just fwiw. They are dead silent. Even my sp2-8000 doesn't have any fans. A single 4000 watt amp I would think would have some cost savings over a pair of plate amps, as well as a much easier way of just having to run speaker wire to the two locations as opposed to long XLR runs and risking picking up some noise. Amp could also plug into same dedicated outlet for the rest of your excellent gear... Just throwing ideas out there
post #646 of 678 Old 04-03-2019, 08:07 AM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
jtwrace is offline
post #647 of 678 Old 04-03-2019, 08:18 AM
beastaudio's Avatar
Liked: 5323
I'm not sure what of that is upsetting?
post #648 of 678 Old 04-03-2019, 08:41 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1781 Post(s)
Liked: 1703
I believe the SP2-8000 amps do indeed have a fan but in the HT model, it is tuned to rarely come on except when absolutely needed. And if it is absolutely needed, you won’t be able to hear it over your system pounding.
And BeastAudio and I have put IPR2-7500 and SP2-8000 amps into protection pushing them so hard. So he definitely has the capability to make the fan power on but I ageee, I can’t remember hearing the fan in a SP2-8000.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #649 of 678 Old 04-03-2019, 11:15 AM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
the speakerpower rack mount amps have two fans. You can request whatever fan profile you want. I don't think I've gotten mine to spin up yet.
notnyt is offline
post #650 of 678 Old 04-03-2019, 11:34 AM
zeus33's Avatar
Liked: 1764
Slacker!
zeus33 is offline
post #651 of 678 Old 04-03-2019, 11:37 AM
notnyt's Avatar
Liked: 3705
Originally Posted by zeus33 View Post
Slacker!
Honestly, they probably have, I just haven't noticed. Under normal operation they're not moving. They have some beefy heat sinks. If I was pushing em, there's no way I'd hear the fans.
notnyt is offline
post #652 of 678 Old 04-03-2019, 11:42 AM
zeus33's Avatar
Liked: 1764
Just messin with ya. I know the power that they make. Things would be very loud to push them that hard.
zeus33 is offline
post #653 of 678 Old 04-03-2019, 11:51 AM
beastaudio's Avatar
Liked: 5323
Funny enough that I just though they may have been manifolds for other applications and not even real fans. Guess they are, but I sure as heck haven't ever seen them operating either...
post #654 of 678 Old 04-03-2019, 03:13 PM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
Just you trying to spend my money.
I thought they did! Glad I'm not going nutty. OK, I'm here so I am.
jtwrace is offline
post #655 of 678 Old 04-04-2019, 01:39 AM
Quoted: 35 Post(s)
Liked: 36
Hallo all,
I just got myself a SP12000HT amp. I will be using it to run 2 SI 24s mk2 that I built. My boxes are about 13cuft. Each will be running independently on its channel @4ohm
I don't have any kind of protection /limiter and I am wondering what the chances are of me blowing the sub on deep content without some form of limiter.
I have watched several movies with the setup and it gets quite scary sometimes.... 😂I guess I still haven't figured out the limits of the sub. I watch movies at mostly -10. I tried watching at reference once and it was too scary... Couldn't handle it. Got a little worried for the subs.
Any thoughts?
James Taylor 2 is offline
post #656 of 678 Old 04-04-2019, 09:01 AM
Deep Sea Sound
dgage's Avatar
Liked: 1703
Originally Posted by James Taylor 2 View Post
Hallo all,
Any thoughts?
A single channel of an SP2-12000 is way too much power for a single HS-24 driver, pretty much double the power. If I had an SP2-12000, I’d run both 24s off a single channel and then I’d use the second channel to drive a pair of HST-18s for the rear of the room. This would give you top 2-3% of bass systems in the world and you’d have more even bass in your room from having multiple subs assuming they’re configured properly. By configured properly I mean they are setup in pairs equi-distant from the main listening position since they are sharing the same signal from your system.
And a pair of HS-24s can easily run reference near 10Hz.
notnyt likes this.
David Gage
Deep Sea Sound
dgage is offline
post #657 of 678 Old 04-04-2019, 10:59 AM
Quoted: 35 Post(s)
Liked: 36
Thank you @dgage . That was my concern. My question is what real world content would be dangerous if I ran that much power? If I am not playing any sine waves etc and I am just listening to music and watching movies, can that still mess the sub? I don't think I can do reference for a whole movie, too powerful for my room. If I did volume -10 is that still unsafe? I don't have plans on adding any subs now since the 2 24s are More than enough for my room.
It feels like a shame that I would waste a whole channel of the amp....
post #658 of 678 Old 04-04-2019, 11:12 AM
Quoted: 35 Post(s)
Liked: 36
Pics or it didn't happen!
ID:	2548932   Click image for larger version
post #659 of 678 Old 04-04-2019, 11:20 AM
Quoted: 1012 Post(s)
Liked: 1261
A run thru Lone Survivor which has very high levels of basically a 7Hz sine wave during the chopper insertion scene will prob cause some issues.
Sent from my SM-N920V using Tapatalk
Pradeep2 is offline
post #660 of 678 Old 04-04-2019, 12:18 PM
beastaudio's Avatar
Liked: 5323
There's no certainty here regardless of content. Is your -10 a true -10 from reference? Do you run your subs dead flat with no house curve? Is your room EQ applying any filters to the subwoofer? All of these things play a major part in how the subwoofer will handle a situation. Being 13cuft boxes I would assume a small LT is still in use. This too affects the power consumption.
