Upgrade from 4 15" to 4 18"?? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By squiers007
post #1 of 5 Old 05-04-2016, 09:58 AM - Thread Starter
04rex's Avatar
Quoted: 330 Post(s)
Liked: 64
Hey guys, I currently have 4 15" Ultimax subs in sealed boxes. I like sealed boxes better. Would it be a noticeable difference if I upgraded to 4 18" Ultimax subs in sealed boxes?
Power being equal (I am running a CV-5000), room being equal, placed in the same spot and all that, would it be worth it? Would it hit lower, louder and harder?
Any input is appreciated.
04rex is offline
post #2 of 5 Old 05-04-2016, 10:10 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
I'm going to go ahead and assume that the 15's are in 3.0cuft boxes and you'd planned on using 4.0cuft boxes for the 18's? If this isn't right let me know.
If so then you'll only be gaining ~1-2db of max output due to the increase in total Sd. If you upgrade the amps as well, then that could bump up a bit higher, but honestly I don't think it would be worth it unless you can go with a lot larger sealed boxes in the 6 cuft range so that you would have added efficiency in the lower octaves. Going from a 4 to 6 cuft. box nets you +2db of output at 20hz for the same amp output.
jshadzi likes this.
Check out my End-Table Marty Build
squiers007 is offline
post #3 of 5 Old 05-04-2016, 10:24 AM
jshadzi's Avatar
Quoted: 110 Post(s)
Liked: 456
Agreed, you'd be better off adding to the current system, 1 ported 18" will give you a lot more gain.
You can even do what was suggested above with your 15" to get more out of them
jshadzi is offline
post #4 of 5 Old 05-04-2016, 11:32 AM - Thread Starter
04rex's Avatar
Quoted: 330 Post(s)
Liked: 64
You are correct in the box size assumptions.
Thanks for the info guys. I will probably just leave it the way it is then. I can't fit boxes that are too big.
Thanks for the help.
04rex is offline
post #5 of 5 Old 05-04-2016, 12:13 PM
Liked: 39
Are you not happy with the current setup?
Autocado is offline
