Next Build - Planning Stage - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #91 of 122 Old 06-27-2016, 07:13 PM
LTD02's Avatar
Quoted: 2909 Post(s)
Liked: 3590
Originally Posted by NWCgrad View Post
I have looked at these parts long and hard over the past 9 months. The waveguide is used in many different categories of JBL speakers (installation, tour, portable) and seems very nice.
I think I will stick with the 7 Pi design as I already have most of the components.
What I will be doing is trying out several 10" JBL Pro drivers over the next couple of years to see if I can find one that works as well as the Eminence Delta 10. I have 5 part numbers as of now. I have the Hornresp parameters and will feed in the JBL T/S parameters to narrow the field.
Will also replace the Eminence H290 horn and B&C DE250 with the JBL VTX waveguide and one of the 4" JBL compression drivers as time and funds allow.
Thanks for the suggestion, I was close to going with these parts a few months ago.
oh, my bad then. so many builds going on I can't recall who all has considered what. :-)
Listen. It's All Good.
LTD02 is offline
post #92 of 122 Old 06-28-2016, 07:22 AM
beastaudio's Avatar
Quoted: 5482 Post(s)
Liked: 5287
Once built I may just veg out and do nothing. Who knows.
I got 5 on it.
beastaudio is offline
post #93 of 122 Old 06-28-2016, 07:44 AM - Thread Starter
NWCgrad's Avatar
Quoted: 1283 Post(s)
Liked: 1331
I don't know how you keep them all straight, I have been known to post stuff in the wrong thread.
______________________________________
Home Theater:
https://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #94 of 122 Old 06-28-2016, 07:45 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
I got 5 on it.
Is that 5 for or against me not upgrading?
Home Theater:
NWCgrad is offline
post #95 of 122 Old 06-28-2016, 08:06 AM
beastaudio's Avatar
Liked: 5287
haha. $5 on you getting something built out completely and then getting complacent.... at least for a little while. Unless you screw it all up and it sounds like poo.
NWCgrad likes this.
post #96 of 122 Old 06-28-2016, 08:54 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
You are probably right...
Home Theater:
NWCgrad is offline
post #97 of 122 Old 06-29-2016, 02:03 PM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Been looking at the Radian Beryllium CD's. The one inch horn throat models (such as the Radian 475BePB) should work on the 7 Pi waveguide. They are not JBL, but I don't think JBL has a 1" diameter beryllium option (and let's face it with all the firings at JBL they really are a different company than they were just a few short years ago).
For home usage I don't think the greater output capacity is terribly important, and with the midhorn they don't need to run down low (at least down low for a tweeter).
Upgrade path just got easier, and cheaper!!!!
http://www.usspeaker.com/radian%20index-1.htm
Home Theater:
NWCgrad is offline
post #98 of 122 Old 06-29-2016, 02:15 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5985 Post(s)
Liked: 5114
Are you planning to mate these other parts with Wayne's passive crossover? Or you going full active?
Scott Simonian is offline
post #99 of 122 Old 06-29-2016, 03:01 PM - Thread Starter
NWCgrad's Avatar
Liked: 1331
At first passive with Wayne's XO. Once I start playing around with the design then will most likely have to go active. In a thread on the Pi speaker forum Wayne posted that the TAD beryllium CD was a drop in replacement with the current XO. He also stated it seemed likely that the Radian Beryllium CD's would also work as is, my have to tweak the L-pad section of the XO.
Who knows really. I am unlikely to do any serious mods until I move from the townhouse. The 7 Pi XO is the same as the 4 Pi for the HF, so I am buying two blank XO's to build the midhorn XO's. Will have independent input to each driver, but all are passive.
The point of this thread was to think out loud and gain perspective from the community. I do this process all the time at work when developing new funding streams. The iterative process can be messy, chaotic, and frustrating but it is a solid methodology.
I am ready to turn from planning to building. Once I place an order with Wayne the fun begins.
Scott Simonian likes this.
Home Theater:
NWCgrad is offline
post #100 of 122 Old 06-29-2016, 08:21 PM
FriscoDTM's Avatar
Quoted: 417 Post(s)
Liked: 387
I got 5 on it.
stackola
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #101 of 122 Old 06-30-2016, 06:53 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Now that it seems the design is somewhat set, I am attaching a tentative project timeline:
I think when coupled with my subs and surround speakers should be pretty awesome.
I recently picked up a vintage McIntosh Amp/Preamp to power the speakers when listening to two channel music (my primary utilization).
What we have here is a C27 Pre-Amp and a MC2105 Power Amp, both are in need of a good cleaning and will probably send to a McIntosh Service technician for revitalization.
Name:	Project Timeline.png
ID:	1521794   Click image for larger version
d_c likes this.
Home Theater:
NWCgrad is offline
post #102 of 122 Old 07-02-2016, 09:09 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Well, nothing is ever cast in stone.
Just ordered a Peavey VSX26 Crossover unit (used from Guitar Center). This is a 2x6 DSP unit that will serve as active XO/DSP.
Rationale for change: Cost and advantages of going active. This unit cost slightly less than the blank XO boards, inductors and capacitors to make the passive XO for the mid and low frequency unit.
Home Theater:
NWCgrad is offline
post #103 of 122 Old 07-02-2016, 09:11 AM
Bass Enabler
Liked: 5114
Oh snapples!
NWCgrad likes this.
post #104 of 122 Old 07-02-2016, 09:16 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
I was just getting ready to PM you. Yeah, I am audio fluid.
Home Theater:
NWCgrad is offline
post #105 of 122 Old 07-02-2016, 09:38 AM
Bass Enabler
Liked: 5114
Okay man.
Get ready to fight the 'Battle of the Hissy Amp'.
Good luck, I mean it!
post #106 of 122 Old 07-02-2016, 12:07 PM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Okay man.
That is the challenge of high efficiency speakers when going active. Optimizing the gain structure is critical to stopping hiss issues (without overly reducing sensitivity that will in turn cause clipping somewhere in the chain.) No free lunch in audio.
I likely will do a hybrid approach ala JBL. Passive XO for MF and HF, with active transition for LF (and MF/LF transition). Basically the processor will see a 2 way speaker.
Name:	Active + Passive XO Schematic.jpg
Home Theater:
NWCgrad is offline
post #107 of 122 Old 07-02-2016, 01:16 PM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Just read through a bunch of reviews on the Peavey unit. It was a mixed bag, many liked it's sound quality but others complained about its noise with standard gain structuring.
I have no intentions of this being my end all be all DSP, but for $149.00 it seems like a good starting point. At least I know the noise can be mitigated, just have to be flexible in the process.
Home Theater:
NWCgrad is offline
post #108 of 122 Old 07-02-2016, 03:44 PM
LTD02's Avatar
Liked: 3590
my sense is that user error/ignorance is the problem, more often than not, when hiss is a problem in active systems. simply blaming "noisy devices" or "bad amps" is a lot easier than really understanding all of the issues involved in system noise. gain structure is critical (and that doesn't just mean maximizing output) as is keeping circulating currents (of all types, not just ground loops, but even leakage currents) out of the system. then there are consumer amps with no attenuators and high fixed gain, which together can damage s/n by more than 10db in just one step. L-pads and autoformers to the rescue...
NWCgrad likes this.
LTD02 is offline
post #109 of 122 Old 07-02-2016, 03:55 PM - Thread Starter
NWCgrad's Avatar
Liked: 1331
True!
The noise floor of the unit is -107dB. That's pretty good.
Home Theater:
NWCgrad is offline
post #110 of 122 Old 07-02-2016, 04:54 PM
LTD02's Avatar
Liked: 3590
peavey actually has a decent bit. you may be familiar with the issues, so consider this a "for posterity" post. :-)
https://assets.peavey.com/literature...00420060_7.pdf
the manual indicates the input sensitivity is selectable, but it appears to be software based. that might be a weak point.
input sensitivity is +24dbu, which is about 12 volts, so that may be what is required to maximize s/n on the input.
any less than that may cause a reduction in s/n. it is unclear if the input software attenuator reduces s/n in -10dbv mode. my guess is since it is done in software, s/n would be lost. so coming in with a 2v signal, for example, would lose about 13db s/n or so right off the bat.
output is also +24dbu, so that may be what is required to maximize s/n on the output.
those are VERY hot signals relative to what most folks are use to working with. some consumer amps without gain controls may have input sensitivity of 1v, so that means coming in 12x too hot, which means the signal would have to be reduced by about 23db or so (which if done digitally kills 23db of s/n). whereas an amp with a lower gain (higher input sensitivity) and an analog attenuator could run with the hot signal and preserve the s/n ratio (not lose the 23db).
so with just two mis-steps, s/n could drop 36db or more. next thing 105db becomes 69db and on a horn with 109db 1w1m sensitivity, that could be 60db of noise coming out of the horn by inserting the device even though nothing is wrong with the device!
NWCgrad likes this.
LTD02 is offline
post #111 of 122 Old 07-02-2016, 05:14 PM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Very useful information....will definitely have my work cut out for me. I don't think I will be running my McIntosh amp on the horns, probably on the bass bin (JBL 2226H).
From the document:
Amplifier gain amplifies both the signal and quantization noise produced by the VSX 26. Attenuating the signal via the VSX's output controls only corrects the signal portion of the noise. To obtain the best case signal to noise ratio, two things must be done. The VSX's channel output should be at 0.0 dB (the default setting) and the signal applied to the amplifier must be attenuated so that the
full-scale output of the VSX matches the full scale output of the amplifier.
The formula is:
AMPLIFIER ATTENUATION(db) = AMPLIFIER SENSITIVITY(dbu) - 24(dbu)
Example: Crown XLS1500 - 1.4 Vrms [~5.25 dBu] requires 18.75 dB attenuation.
LTD02 likes this.
Home Theater:
NWCgrad is offline
post #112 of 122 Old 07-02-2016, 05:56 PM
chrapladm's Avatar
Quoted: 1099 Post(s)
Liked: 443
NO ......2242's for the bass bins. LOL I will just be following along ...
NWCgrad likes this.
chrapladm is offline
post #113 of 122 Old 07-03-2016, 06:39 AM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 215
I had a MC-2105 paired with a MX-115 a few years ago, a very smooth combination. If you're looking for any maintenance, check out Audioclassics in upstate NY.
NWCgrad likes this.
Face2 is offline
post #114 of 122 Old 07-03-2016, 06:50 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
I know...I have the plans for the 18" bass bin, but aesthetically it just doesn't look as nice as the 15" bass bin. But, I have the twin 2242's to pick up the low end from the 7 Pi's.
That is where my friend I picked them up from bought them. I think they would be the natural place for me to work with for maintenance. At their age may need some new components to be at peak performance.
Home Theater:
NWCgrad is offline
post #115 of 122 Old 07-09-2016, 09:23 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Well.....
I showed my wife my design and she did not like the looks of the 7 Pi at all, hated the stacked component look. So, I showed her an older design - dimensions based on the JBL Pro 4345 (except taller to account for the height of the Midhorn vie an 8" mid driver). She much preferred the enclosed design.
The port location is from the JBL design (bottom of the three original ports) but placed on both sides vice all on one. Going with two ports vice three as the 2242H is not as potent of low end driver as the 2245 driver. Final volume will be 9 cu ft (net) tuned to 32 Hz per replicating the 4345. As I am using all different drivers this is obviously not a clone build, and I am calling it the 1810 Monitor. WIll continue to use the 7 Pi XO for the HF and MF (not much to the MF as its a pseudo 1st Order Butterworth). Plan to transition the low/mid at 250 Hz (if supported in room by measurements, if not will adjust with DSP [man, DSP is so NICE!!!!!]), with a 1st order slope.
Note the 45 degree angled cabinet, which will allow me to corner load for constant directivity as designed by Wayne.
I received the Peavey DSP unit early this week, it looks very nice and should be more than sufficient.
Name:	M1810 Design Collage.png
Scott Simonian and Mfusick like this.
Home Theater:
NWCgrad is offline
post #116 of 122 Old 07-09-2016, 09:24 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
u win!!!!!! Ha Ha, funny how things always evolve with my builds, must be my ADHD.
chrapladm likes this.
Home Theater:
NWCgrad is offline
post #117 of 122 Old 07-17-2016, 02:26 PM - Thread Starter
NWCgrad's Avatar
Liked: 1331
Thumbs up
Looks like the building will commence soon:
Pi Speakers
Order Number: xxx
Detailed Invoice: https://www.pispeakers.com/xxx
Date Ordered: Sunday 17 July, 2016
Products
2 x Midhorn flat pack kit () = $330.00
Midrange driver Eminence Delta 10
Sub-Total: $330.00
United Parcel Service (UPS Ground): $56.04
Total: $386.04
Shipping Address
Let the adventure begin, build is being documented in the following thread: https://www.avsforum.com/forum/155-di...ld-thread.html
Home Theater:
NWCgrad is offline
post #118 of 122 Old 10-16-2016, 10:49 PM
Kwikas's Avatar
Quoted: 54 Post(s)
Pi Speakers
Order Number: xxx
Products
Sub-Total: $330.00
Total: $386.04
Shipping Address
NWCgrad, where are you at with this? Any updates?
Kwikas is offline
post #119 of 122 Old 10-17-2016, 08:53 AM - Thread Starter
NWCgrad's Avatar
Liked: 1331
The enclosure is nearly complete, just need to router the edges, add a second layer of baffles to front and back, run the internal wiring, and finally install the drivers and start tweaking.
The link for the build thread has a lot of progress pictures.
Home Theater:
NWCgrad is offline
post #120 of 122 Old 10-17-2016, 09:39 AM
Bass Enabler
Liked: 5114
Lots of updates.
This is the pre-planning thread. The actual progress/build thread was in the post you just quoted.
