Volt 10 Atmos speakers and Paradigm Studio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-03-2016, 08:48 AM - Thread Starter
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
Hey guys, I currently have a full Paradigm Studio setup all v5 (100s, CC690, 10s for 4 rears). Looking at doing Atmos. Will the Volt 10s with the Atmos flat pack work well and match with the Studios? Would there be a big difference in sound quality or general sound?
I would be doing 7.4.1, so I would get 4 of them.
Thanks for any input.
04rex is offline
post #2 of 6 Old 06-03-2016, 08:53 AM
Quoted: 108 Post(s)
Liked: 99
I can't speak to the quality of the speakers, but do you mean 7.1.4? That middle number is usually number of subwoofers, and the third number is atmos. You're talking 4 volt 10's as atmos, not as subwoofers, correct?
mushroommunk is offline
post #3 of 6 Old 06-03-2016, 08:58 AM - Thread Starter
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
Lol sorry, yes. 7.1.4. My mistake. Typing too fast for my own good I guess. Although I do have 4 Subs. lol.
04rex is offline
post #4 of 6 Old 06-03-2016, 12:41 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
Bassment is offline
post #5 of 6 Old 06-03-2016, 12:56 PM
pmd918's Avatar
Quoted: 209 Post(s)
Liked: 158
Volt 10's would likely be overkill for your setup. I would consider the Volt 6's.
Just for a frame of reference, I had run a very similar setup - 100's, CC-690, and ADP-590's - for years and recently built 1099's for the fronts and Volt 10's for the surrounds.
pmd918 is offline
post #6 of 6 Old 06-03-2016, 05:06 PM - Thread Starter
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
You think the 6 is enough?
Are they good Atmos speakers?! Dispersion wise and all that.
Is going the route of the Atmos flat pack the best bet as well? Being sealed and all.
04rex is offline
