RSS315HO-4 12 vs Ultimax 12 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By uniquepattern
  • 1 Post By Bill Fitzmaurice
  • 1 Post By BassThatHz
  • 2 Post By LTD02
  • 3 Post By LTD02
  • 1 Post By Mattcc22
post #1 of 13 Old 06-07-2016, 11:47 AM - Thread Starter
04rex's Avatar
Quoted: 330 Post(s)
Liked: 64
Hey guys, I am looking to build a small sealed enclosure for my living room. Looking at 12" as that will be enough. Between these 2 subs, what's the best option?
Pros and cons from what I see are the RSS is cheaper, has a smaller box and looks like it can handle more power.
The Ultimax I believe is just a better sub, but it needs a bigger box and its more expensive.
I am not looking for anything earth shattering or anything, just want some decent bass in a small sealed box.
OR are there any other options that are small and cheap?
Room size is 18x13 and open, but like I said, not looking for anything too crazy. I have a dedicated room for that already. Just looking for good as loud as I can get out of a small box bass if that makes sense. If I were to compare it, I would be looking at something like the JL subs which are small and have good output.
And in this instance, size does matter.
04rex is offline
post #2 of 13 Old 06-07-2016, 11:56 AM
uniquepattern's Avatar
Quoted: 808 Post(s)
Liked: 857
Don't know if this helps, but from what I understand the Reference line is a little better at the upper end of the scale, while the ultimax series really hits the low end....
So, movies Id say Ultimax, for music Id lean toward the Reference series....
LTD02 likes this.
uniquepattern is offline
post #3 of 13 Old 06-07-2016, 12:47 PM
Bill Fitzmaurice's Avatar
Liked: 5770
This is where speaker modeling software comes in.
uniquepattern likes this.
Bill Fitzmaurice is offline
post #4 of 13 Old 06-07-2016, 05:08 PM
BassThatHz's Avatar
Quoted: 3707 Post(s)
Liked: 4214
Beyond speaker modelling, the only thing that I'd add, is that the UM is made of a carbon fiber like substance, so if you did manage to bottom it out, it won't deform like a metal or paper cone would. (Assuming the voicecoil survives, of course...)
BassThatHz is offline
post #5 of 13 Old 06-07-2016, 06:12 PM
LTD02's Avatar
Quoted: 2934 Post(s)
Liked: 3652
the 390HO offers better sensitivity on the top end, costs about the same, and is probably about the same on the low end as the um12. it can work in a very small enclosure despite being a 15" driver. many folks have built using that sub with good effect. one won't be enough sealed to really "crush it" but a pair would be a great start for what you are looking for. if later you decide to go ported, then the same driver can be used an you will pick up a LOT of output. if you purchased two of those drivers and put them in a dual opposed cab of 4.5-5.0 cubic feet, you would have a close copy of one of the more famous subs. ;-) two separate enclosures would be best for bass response though, as cancellations and modes tend to be a big problem and multiple units help greatly in those areas.
http://www.parts-express.com/dayton-...4-ohm--295-469
btw, usable excursion on the driver is much more than the ~12mm indicated on the spec sheet. good inductance control will provide a clean top end for music applications as well. not the most excursion per dollar, but a great all around performer.
blue line is two sealed cabs with 1kw peak on each driver.
green line is two ported cabs, same driver, same power, 5 cubes each tuned to 20hz. <--that would actually be enough to satisfy most folks who are looking to have some fun with bass, but not go absolutely nutz.
Listen. It's All Good.
LTD02 is offline
post #6 of 13 Old 06-07-2016, 06:17 PM
LTD02's Avatar
Liked: 3652
a flat pack that will get you pretty close to that green line is here:
http://www.diysoundgroup.com/ported-...be/cube15.html
(and no, i don't get a commission)
this would be a decent option for the sealed version:
http://www.diysoundgroup.com/sealed-...flat-pack.html
if you need a flat pack or are just looking for a design idea.
LTD02 is offline
post #7 of 13 Old 06-07-2016, 10:03 PM
scotthal's Avatar
Quoted: 123 Post(s)
Liked: 69
Q: "size matters" - is it the cubic, or footprint? If you're looking at parts-express bundles, the Ultimax 12 is out_of_stock (ETA: late September). Downside: box is bigger, but the increased efficiency & low end extension probably moot the slightly higher power handling capabilities of the RSS315HO-4.
Small footprint pre-fab? I'd suggest going w/dual RSS315HO-4 (12"), or even RSS265HO-4 (10").
If you're building yr own (& unconstrained as to height), you might take a look at LTD02's I-Clʘps small footprint ported design.
scotthal is online now
post #8 of 13 Old 06-08-2016, 06:49 AM - Thread Starter
04rex's Avatar
Quoted: 330 Post(s)
Liked: 64
Thanks for all the input guys.
Essentially it will be used for everyday TV/movie/music listening at low-moderate volume. I just want more low end as my speakers right now are small and don't produce much, or any low bass.
By comparison I was thinking of getting the SVS SB-2000 but thought I can get more bang for my buck going DIY. I like the size and form factor of the SVS.
Thanks LTDO2 for the info. Although I would like to go ported, that is just too big. Height, width and depth all come into factor. That's why I was intrigued by the RSS because it is a smaller box than the Ultimax. If the output is very close, then being in a smaller box makes it good for me. Almost like the SVS.
I am ok with it not going as low as the Ultimax (although I guess that depends on how low the sub will go, like if it only goes down to 40, then yeah, that's a no go).
I would be looking at the Partsexpress Bundle for both the Ultimax and RSS.
Should I be looking at the HO or HF model? What is the difference between them?
04rex is offline
post #9 of 13 Old 06-08-2016, 07:37 AM
Bigus's Avatar
Quoted: 594 Post(s)
Liked: 558
If you intend to keep listening levels moderate, you can always go small sealed and use an amplifier with built in DSP or an outboard DSP to boost the low end. Great option for smaller listening spaces and/or more moderate output goals.
Bigus is offline
post #10 of 13 Old 06-08-2016, 08:38 AM
Quoted: 808 Post(s)
Liked: 857
You want the HO version! and it will kick the crap outta that SVS....
post #11 of 13 Old 06-08-2016, 09:19 AM
Mattcc22's Avatar
Quoted: 185 Post(s)
Liked: 173
I have two (2) RSS390HO drivers I could part with for a good price. One was barely used (practically new) and the other was used for about 1.5yrs in my living room. PM if interested.
chadsmith013 likes this.
Mattcc22 is offline
post #12 of 13 Old 06-08-2016, 10:09 AM
Quoted: 26 Post(s)
Liked: 5
So can everything in this thread also be said about the RSS460 vs UM 18? I've already asked the question in the Martysub thread but it seems a more specialized topic might do the trick.
Vossten is offline
post #13 of 13 Old 06-08-2016, 10:26 AM
Quoted: 808 Post(s)
Liked: 857
Pretty much the same, yeah.... Just bigger drivers....
I was debating these two drivers too and figured Id probably go with the RSS460HO as I listen to music on my setup more then anything else... then I discovered StereoIntegrity and that idea went out the window pretty quick...
