Room Size Quick Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-11-2016, 10:41 AM - Thread Starter
Phonzo07's Avatar
Quoted: 93 Post(s)
Liked: 75
What's up all..
Just a quick question to your opinions of room sizes..
In terms of Cubic or Square feet, ( however you measure,) what size is a Small room, Medium room, Large room or even Extra large room?
Is there a general standard number for each?? I remember reading on one of these websites a long time ago about room sizes, but cant seem to find it.
Thanks in advance....
If you KRANK it.. They will Listen..
Phonzo07 is offline
post #2 of 8 Old 08-11-2016, 10:52 AM
uniquepattern's Avatar
Quoted: 808 Post(s)
Liked: 857
My room is a little over 1450ft^3 and I figure its on the smaller side of things...
Not sure if that helps or not....
uniquepattern is offline
post #3 of 8 Old 08-11-2016, 10:58 AM
AVS ***** Member
mthomas47's Avatar
Quoted: 5381 Post(s)
Liked: 10067
I have heard some different rules of thumb, but the most common ones seem to treat rooms up to about 3000^3 (cubic feet), or perhaps a little less, as Small, with Medium going up to about 4500^3, or so, and Large, anything over that. Of course some HT's or mixed-use rooms, go over 10,000^3, so any of these standards will depend somewhat on your perspective.
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #4 of 8 Old 08-11-2016, 12:29 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
I would go a little smaller, say 2000ft3 as small, 2000 to 3500 as medium, and anything upwards as large. A 20 by 20 by 8 ft two car garage is 3200ft3, IMO most would consider that a decent sized room. YMMV
Sent from my LG-H830 using Tapatalk
manuetdeo is offline
post #5 of 8 Old 08-11-2016, 12:31 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
My listening room is only 720ft3 in comparison.
post #6 of 8 Old 08-12-2016, 05:03 AM
Quoted: 808 Post(s)
Liked: 857
Wow.... Im not sure I could even get my subs into a room that size...
...well, I could but nothing else would fit! lol
post #7 of 8 Old 08-12-2016, 05:59 AM - Thread Starter
Phonzo07's Avatar
Quoted: 93 Post(s)
Liked: 75
True... It would be a decent sized room. See.. My room is roughly 18 x 22 x 7.5 and It's a nice size to me. lol But for speaker purposes, I was wondering what was large, medium and small. It's probably just relative. lol Just looking for a baseline, so I can tell others I know and sound like a genius. You guys have taught me a lot. AVS is awesome.
Phonzo07 is offline
post #8 of 8 Old 08-12-2016, 11:34 AM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
Less than 1500 cu ft. is small. A room 1500-3000 cu ft. is medium. A large room is 3000 + cu ft. Extremely large room is greater than 5000 cu ft. http://www.audioholics.com/loudspeak...ofer-room-size
derrickdj1 is offline
