Need Recommendations on Speaker Mounting - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By groundedchevy
  • 1 Post By JohnDean
post #1 of 5 Old 08-14-2016, 05:24 AM - Thread Starter
groundedchevy's Avatar
I'm finally about to finish my Fusion 6 speaker boxes! It only took me 1.5 years to actually have some time to work on them....ughh. I'm going to mount the left and right speaker to the left and right of the bottom tv. I want them as close to the wall as possible. What type of bracket should I use to not have the speakers stick off the wall. Do you think a shelf would be better?
groundedchevy is offline
post #2 of 5 Old 08-14-2016, 05:41 AM - Thread Starter
post #3 of 5 Old 08-14-2016, 07:31 PM
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
A French Cleat will work fine for hanging your speakers, assuming it meets the weight of the speaker and you use it correctly.
Al Toid is offline
post #4 of 5 Old 08-16-2016, 06:25 AM
JohnDean's Avatar
Quoted: 542 Post(s)
Liked: 254
I a fan of these over the "French Cleat" style. I hang everything but pictures with them. Stick a couple small rubber bumpers on the bottom/back and they sit flush.
http://www.lowes.com/pd/The-Hillman-...1-5-in/3306352
manuetdeo likes this.
JohnDean is offline
post #5 of 5 Old 08-16-2016, 08:20 AM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
I 2nd these, amazing strong with correct anchor.
Sent from my LG-H830 using Tapatalk
manuetdeo is offline
