Marty Variant - Dual Ports - UM18 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
  • 2 Post By frogers935
  • 1 Post By frogers935
  • 3 Post By frogers935
  • 1 Post By Broke EF
  • 1 Post By squiers007
  • 1 Post By Fattykidd
  • 1 Post By asarose247
  • 4 Post By LTD02
post #1 of 17 Old 08-16-2016, 08:39 AM - Thread Starter
frogers935's Avatar
Liked: 46
I had been reading about DIY subs for months in preparation of building something to fit into my new theater. Of all the great builds I looked at I kept going back to the marty, the idea of 2 18's in my small room was just too good to pass up. Initially I had planned on a minimarty build as that would fit into my plans without modification but as I built my front stage I realized I needed to tweak the design. So if I was going to tweak it I may as well make something to my exact specs and use the full space. Being a beginner I read as much as I could and came up with a design I thought would work. Not wanting to mess anything up I reached out to the community to get some help.
Big thanks to @LTD02 for graciously checking out my design - what a great asset to the community!
Background/Equipment
Room Size: 9' (W) x 16' (L) x 8' (H)
Acoustical Treatments (Planned): 1st reflection absorbers & Linacoustic to listening height. May try riser bass trap.
Drivers x2: Dayton Audio UM18-22
Amp: iNuke 6000dsp
Calibration: REW planned and will take measurements as I proceed with room build to see the changes
Design/Location
Wood: 3 sheets 3/4" MDF
External Dimensions: 35" (W) x 30" (D) x 24" (H)
Volume ~ 11ft^3
Port Length: 36"
Port Size x2: 3" x 11.25"
Tune: 17Hz
Name:	Modified Marty_Front.jpg
ID:	1604945   Click image for larger version
Name:	Modified Marty_iso.jpg
ID:	1604953   Click image for larger version
LTD02 and azz7686 like this.
frogers935 is offline
post #2 of 17 Old 08-16-2016, 08:40 AM - Thread Starter
frogers935's Avatar
Liked: 46
MDF Prep
Cutting the MDF was not too bad with the track saw. I specifically bought this for my theater build. While the track made nice straight cuts the real benefit was the dust port on the saw.
All cut up and ready to go
Measuring port length
Full Disclosure. I f'ed up on one of my measurements. I actually had it right but put it into cutlist wrong. Now while I am new to DIY subs I am not new to construction so I was a bit upset with myself. Now I could have run out and got another sheet of MDF but that would have been a royal pain since I had these delivered and it is not easy for me to fit a sheet in my truck. So I ended up using a biscuit joiner to correct my mistake. I don't think there will be a strength issue since, besides the biscuits, I have the ports running perpendicular to the cut.
ID:	1604969   Click image for larger version
ID:	1604977   Click image for larger version
ID:	1604985   Click image for larger version
post #3 of 17 Old 08-16-2016, 08:40 AM - Thread Starter
frogers935's Avatar
Liked: 46
Assembly
Assembly was straight forward. I did use brad nails and some screws in a few locations.
I used screws in the back for the top section of the ports
Bit O black paint
https://www.avsforum.com/forum/attach...1&d=1471368528
I bought and used the jasper jig for the driver cutout. I am cheap and initially was just going to make my own but in the end spend the money for the jig - time wise was definitely worth it.
Front going on
ID:	1605073   Click image for larger version
ID:	1605081   Click image for larger version
ID:	1605089   Click image for larger version
ID:	1605097   Click image for larger version
LTD02 likes this.
post #4 of 17 Old 08-16-2016, 08:41 AM - Thread Starter
frogers935's Avatar
Liked: 46
Driver Test Fit
I used 1/4-20 tee nuts pressed into some scrap wood for driver attachment. I used wood glue to get the pieces tacked in then came back with some construction adhesive.
Driver test fit. I carefully glued in the wood with the driver in place to keep everything aligned.
ID:	1605113   Click image for larger version
ID:	1605129   Click image for larger version
LTD02 likes this.
post #5 of 17 Old 08-16-2016, 08:41 AM - Thread Starter
frogers935's Avatar
Liked: 46
Bracing
I used left over MDF cut to 1" strips for bracing.
I tried to cut the strips so they would friction fit into the box. I then tacked them in from the outside with nails. Initially I was measuring on the outside to get it exact but found it could be done fairly easily by just eye-balling it, I only missed a few times.
Bracing all in
Secured with construction adhesive
Final driver test fit
ID:	1605161   Click image for larger version
ID:	1605169   Click image for larger version
ID:	1605177   Click image for larger version
ID:	1605185   Click image for larger version
LTD02 likes this.
post #6 of 17 Old 08-16-2016, 08:42 AM - Thread Starter
frogers935's Avatar
Liked: 46
Foam & Paint
I used 2" bed topper to line the box and 3M spray adhesive to secure it.
I had a dilemma on finishing these. They are behind my screen so will not be seen but I did feel a need to properly finish them i.e. round over the edges, fill holes, prime, etc... In the end the weather (98° w/heat index 105+) dictated it and I ended up throwing on some flat black to the fronts.
Good 10' paint job
ID:	1605217   Click image for larger version
ID:	1605225   Click image for larger version
azz7686 likes this.
post #7 of 17 Old 08-16-2016, 08:43 AM - Thread Starter
frogers935's Avatar
Liked: 46
Wiring & Install
Speakon wired up and had my neighbor help me move these to the basement - probably last time he will offer to help me.
Final product
And firing them up...
I plan on getting a mic and taking measurements over the next month or so...hoping to get some local help in figuring it all out. Initial results with music are very impressive, I can't wait to get a movie going.
ID:	1605249   Click image for larger version
ID:	1605257   Click image for larger version
ID:	1605265   Click image for larger version
LTD02, clientnumber9 and azz7686 like this.
post #8 of 17 Old 08-16-2016, 09:22 AM
Broke EF's Avatar
Quoted: 235 Post(s)
Liked: 340
Broke EF is offline
post #9 of 17 Old 08-16-2016, 11:07 AM - Thread Starter
frogers935's Avatar
Liked: 46
Thanks @Broke EF I have been following both your sub and room build thread both are very inspiring.
Broke EF likes this.
post #10 of 17 Old 08-16-2016, 11:33 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Awesome setup! Should sound fantastic!
frogers935 likes this.
Check out my End-Table Marty Build
squiers007 is offline
post #11 of 17 Old 08-16-2016, 11:36 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 595
Great job. Love all the pics.
How do you like thr cinema 8 speakers? I keep wanting to get a pair for the living room.
Fattykidd is offline
post #12 of 17 Old 08-16-2016, 11:47 AM
asarose247's Avatar
Quoted: 1200 Post(s)
Liked: 1056
Thanks for great effort with the pics, should bring shiggles to anyone in front of it
also, a less than OCD garage shows a creative mind . . a little chaos is O.K!
my concern would be the "breathing room", ventilation, for your AVR and amp stack
the "'heatsink" for the inuke6k is the bottom sheet metal of the case.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #13 of 17 Old 08-16-2016, 01:46 PM
LTD02's Avatar
Quoted: 2919 Post(s)
Liked: 3624
awesome stuff frogers935
not sure if the 'final' pic is the final rig, but the sound will be much improved if that cavity can be filled up with some fiberglass or rockwool batting, speakers and subs moved to flush with front, and solid panels covered with some sort of absorption material on front inserted to keep all sound radiating forward. something like this:
Listen. It's All Good.
LTD02 is offline
post #14 of 17 Old 08-16-2016, 06:40 PM
Broke EF's Avatar
Quoted: 235 Post(s)
Liked: 340
WOW, Thank you for the kind words! Things like this make me want to upgrade just to keep it all going
Sean
Broke EF is offline
post #15 of 17 Old 08-16-2016, 11:18 PM
rhapsodee's Avatar
Quoted: 39 Post(s)
What's in the drywall soffit that's framing the speakers and subs? Are those bass traps or covering up some structural parts in the room?
Sent from my GT-I9505 using Tapatalk
rhapsodee is offline
post #16 of 17 Old 08-17-2016, 08:22 AM - Thread Starter
frogers935's Avatar
Liked: 46
Spoiler!
Spoiler!
From the limited use (music only) with the Cinema 8 I really like them. I am not an audiophile and my previous speakers were not that great so can't really compare them too much. I will say they are very clear and I was surprised at how much bass I got out of them. I will follow up with impressions once I get the room treatments up and do a full calibration. Also I am impressed with the volt 6.
Spoiler!
Thanks for the feedback I did not know the main heatsink was on the bottom. My current setup is not my final configuration not sure where I will have everything I get my other equipment in. I will be keeping the sides and back off of the rack and may possible install some fans in the top - being in my backroom it stays cool year round. I will probably end up putting some thermocouples in the racks at a few points too.
It's funny while I was never OCD with my garage it was much neater before I had kids, not that they make a big mess just my time is so limited I end up doing work and then minimal clean up.
Spoiler!
Thanks for dropping in and the feedback. It is not my final configuration but I was only planning on doing linacoustic on the walls of the cavity. I can easily fill the cavity with rockwool/rockboard if that will help.
Spoiler!
The area where the speakers are is structural. I needed access behind the front wall. Here is my build thread which has some pictures.
Spoiler!
Well deserved. Its cool builds and seeing others documented progress that really motivates me to keep moving through the less desirable parts of the build.
post #17 of 17 Old 08-28-2016, 11:56 AM - Thread Starter
frogers935's Avatar
Liked: 46
How does this look?
I lined the walls with Rockboard filled the cavity with regular roxul then used more Rockboard around the speakers.
