Frequency Measurement - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By SeekingNirvana
  • 1 Post By dtsdig
post #1 of 7 Old 08-16-2016, 04:43 PM - Thread Starter
t6902wf's Avatar
Quoted: 16 Post(s)
Odd question. I own the original Omni Mic. I also own a company that has a large dust collector. It is very loud. The company that makes "silencers" wants a reading of the frequencies it is putting out. It has been a while since I have used REW and Omni mic. Can either of these give me a simple frequency/db reading?
Or is there someone who can do this for me quickly in SE Michigan. If you are a DIY speaker maker I am a very good friend to have from the cabinet side.
Bill
T6
Clearwave 4TSE and 4CC build thread
https://www.avsforum.com/forum/showt...1#post19489740
t6902wf is offline
post #2 of 7 Old 08-16-2016, 05:34 PM
asarose247's Avatar
Quoted: 1311 Post(s)
Liked: 1151
.02
this sounds like a quick question for Austin Jerry /and /or/ his REW guide
which many members here have as a link
and a search for REW and omni mike compatibility may prove a quick answer,
it may be good enough for dB and FR recording
it sounds like a reverse CS situation, i.e. backwards
you'd think they would walk in with a SPL meter for loud / FR and a laptop already to go,
how long could that take?
if you've ever made an REW sweep, you know . . . a quickie
and have an answer for your specific circumstance within their range of products
good luck
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #3 of 7 Old 08-16-2016, 06:28 PM
bwaslo's Avatar
Quoted: 71 Post(s)
Liked: 200
Put the omnimic in FFT/RTA mode (tab named "SPL/Spectrum"). Shoot the gun near the mic, look at the plot.
The difficulties will be:
1) Catching the shot on-screen and pausing the system at that point to freeze the graph, since there isn't any triggering in this mode. If you are using the most recent (v5.x) omnimic software, the space bar will pause/unpause it (don't forget there is about a second's delay). You may have to do a number of shots to be sure you've caught the highest amplitude graph.
2) Not overloading the mic. You'll see a readout at the top of the screen telling you to back off the sensitivity slider or move the mic further from the silencer if it overloads.
Your choice of FFT, RTA, smoothing or damping levels is up to you. Slower damping would make it easier to catch the shot, impulse mode would mean you'd have to catch it right-on..... I'd use "slow" or "slowest" if I were you.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #4 of 7 Old 08-16-2016, 08:58 PM
BassThatHz's Avatar
Quoted: 3969 Post(s)
Liked: 4488
There is a very good chance that the gun will be louder than what the mic can handle, you may have to put the mic at 3M or even 6M away, and then approximate the 1M value.
A TermLab or SPL Lab meter is capable of 180-190db which is more-than-enough to capture a gun shot, the problem is that I believe their sampling is only 1/4 of a second which might be too long for a gun shockwave.
I suppose if you put off 3 or so rounds in succession you'd get a "proper" reading of the SPL.
Most guns are in the 140-160db range unsilenced, and 110-130 with. I would imagine long-guns are still in the >130db range with a silencer, especially a 300.
BassThatHz is online now
post #5 of 7 Old 08-16-2016, 10:41 PM
SeekingNirvana's Avatar
Quoted: 258 Post(s)
Liked: 172
He has a dust collector that is loud in his shop. Sounds to me like there is a company that makes silencers for the dust collector, and he needs to take readings of the dust collector so that they can make a custom silencer for the frequency it is putting out.
That what I take from the post.....
dtsdig likes this.
SeekingNirvana is offline
post #6 of 7 Old 08-16-2016, 11:59 PM
Oliver Deplace's Avatar
Quoted: 39 Post(s)
Liked: 43
Seems like something SpecLab could do, but might be too much bother for a single measurement.
http://www.qsl.net/dl4yhf/spectra1.html
Dunno if your version supports RTA/Spectrum, but here's a link to the current tutorial:
http://www.daytonaudio.com/OmniMicV4/hs90.htm
Maybe your current mic is supported in the latest software.
http://www.daytonaudio.com/downloads/OmniMicInstall.zip
TrueRTA, in its free version, has a coarse rez (full octave), but it's probably good enough for this.
https://www.trueaudio.com/rta_down.htm
https://www.trueaudio.com/downloads/TrueRTA_Help_v3.pdf
Then there's REW.
http://www.roomeqwizard.com/
http://www.roomeqwizard.com/help/hel.../spectrum.html
Yo mama so fat, time slow when she near.
I don't wanna grow up, I'm an AVS kid.
Oliver Deplace is offline
post #7 of 7 Old 08-17-2016, 05:41 AM
dtsdig's Avatar
Quoted: 1135 Post(s)
Liked: 1400
Yes, me too. I am not sure how we got onto guns from the original post. He has a dust collector in a cabinet shop that he is getting a silencer (some sort of baffle) for.
SeekingNirvana likes this.
dtsdig is offline
