VBBShaker - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1 of 60 Old 09-18-2016, 02:50 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
VBBShaker
After living with mtg90s excellent VBSS design (I have a pair and am VERY happy). I have decided on a variation.
I will call this the Value Buster Butt Shaker build.
This will serve 3 purposes:
1) A near field sub, 2) Butt shaker duty for my 2 MLPs, and, 3) a foundation for a back row bar.
Photos to follow
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #2 of 60 Old 09-18-2016, 02:53 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
This will go in this area, the "Sub-table" and chairs will go away. Also a rough sketch (overhead view)
Name:	Back Row Area.jpg
ID:	1668345   Click image for larger version
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #3 of 60 Old 09-18-2016, 02:57 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
And a few photos
ID:	1668393   Click image for larger version
Name:	Woofer test fit.jpg
ID:	1668401   Click image for larger version
Name:	Grill Test Fit.jpg
ID:	1668409   Click image for larger version
Name:	Port Location.jpg
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #4 of 60 Old 09-18-2016, 03:09 PM
eng-399's Avatar
Quoted: 2404 Post(s)
Liked: 4947
I like it Craig the box looks great! The brace you have at the top by the angles cut will help hold the wood together a little bette with more surface area to bond to. The hardest part I had when I built my angles wedge boxes for the 8-12's nearfield was trying to figure out how to brace it. I ended up using screws and backing them out once the pl dried and filled the hole up. Keep the pictures coming.
eng-399 is offline
post #5 of 60 Old 09-18-2016, 05:12 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Thanks Mike,
The hardest part on this one was ripping angles on the edges of these large panels.
I think I saw someone commenting on your thread about making an extra tall fence? Which I did and tilted the blade (34degrees) then running a panel thru vertically on edge against the fence - actually worked pretty well.
The 56 degree cut was with the same blade tilt, but running the panel thru laying flat.
cuzed2 is offline
post #6 of 60 Old 09-18-2016, 05:18 PM
eng-399's Avatar
Liked: 4947
Thanks Mike,
I remember that, the cuts were hard but once you get going and figure it out things start moving along. I used scrap pieces first to make sure I had the right angles. Did you do the same.
eng-399 is offline
post #7 of 60 Old 09-18-2016, 05:43 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Yep used scrap wood, and even then, measured about 5 times before cutting.
No major mistakes - so far ray:
This thing is huge - when finished I will have 2 - 4x8 sheets of MDF, and 2.5 sheets of plywood (that's before the bar top)
cuzed2 is offline
post #8 of 60 Old 09-19-2016, 12:58 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
@eng-399
I am intending to cover this with a black carpet (or heavy black fabric).
I'm thinking you might have a recommendation?
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #9 of 60 Old 09-19-2016, 01:54 PM
eng-399's Avatar
Liked: 4947
Joann fabrics check out the eco-line of fabrics should be 5.99 a yard. Then once you're there there's a sign where you can text to get a 20% off coupon on top of it. Watch some YouTube videos for installing carpet and always have the seem on the bottom of the box where no one will see it.
eng-399 is offline
post #10 of 60 Old 09-19-2016, 03:15 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Thanks Mike!
I'll check out the eco-line options at Joanne's.
Will also be looking into some of the thinner black carpets they have in stock (on the rolls) at Menards / HD.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #11 of 60 Old 09-19-2016, 03:16 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Did you staple or glue the eco-line fabric ?
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #12 of 60 Old 09-19-2016, 03:45 PM
RTROSE's Avatar
Quoted: 200 Post(s)
Liked: 176
Oh, I think this was worth the wait. Going to be very cool!
RTROSE
cuzed2 likes this.
RTROSE is offline
post #13 of 60 Old 09-19-2016, 05:01 PM
eng-399's Avatar
Liked: 4947
I used the 3m adhesive spray I sprayed the box 1st then the carpet and slowly aligned everything in place. I did one panel at a time with the 3m adhesive spray that you can find next to the tight bong glue at menards.
cuzed2 likes this.
eng-399 is offline
post #14 of 60 Old 09-19-2016, 05:22 PM
asarose247's Avatar
Quoted: 1177 Post(s)
Liked: 1041
'tight bong glue"
always something new with the DIY crowd . .
cuzed2 likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #15 of 60 Old 09-19-2016, 06:35 PM
eng-399's Avatar
Liked: 4947
eng-399 is offline
post #16 of 60 Old 09-19-2016, 07:03 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Mike,
Got it - the bong glue part ;-)
So you actually bought carpet (or econo-fabric) from Joanne's?
cuzed2 is offline
post #17 of 60 Old 09-20-2016, 06:59 AM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
@RTROSE @eng-399 @asarose247
Thanks for the tips, comments & following along guys!
eng-399 likes this.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #18 of 60 Old 09-20-2016, 07:01 AM
eng-399's Avatar
Liked: 4947
Mike,
Yep I bought the fabric from Joanne fabrics there's so many to choose from at that store. Hey Craig how about being the first avs diy guy to use zebra fabric on the box
cuzed2 and corradizo like this.
eng-399 is offline
post #19 of 60 Old 09-20-2016, 07:42 AM
EndersShadow's Avatar
Quoted: 1167 Post(s)
Liked: 1429
If your gonna go all out, go all out.
Hello Kitty Flannel
*Boom* Mic Drop
cuzed2, corradizo and eng-399 like this.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #20 of 60 Old 09-20-2016, 08:09 AM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
RTROSE
RT,
With the "colorful" suggestions from others above; I have a feeling it is only a short time before our old-friend "Hanes" will find this thread. Also; there may be room in here for a "certified carpet consultant', unless of course you have retired from that responsibility .
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #21 of 60 Old 09-20-2016, 11:01 AM
asarose247's Avatar
Liked: 1041
Long term historical and even current research shows that while looking into and qualifying to assume all the variously available and necessary positions as a "certified carpet cunsultant', may, at times, as a necessary part of the hole job, require steeling oneself to summons up unprecedented above and beyond the known call of duty , desire, drive and imagination , knowing full well in advance there will be times when unavoidably forced to face "that which cannot be unseen" in the quest of : does the carpet match the drapes.
In the 'retired' and "responsible" crowd, "decorating" becomes an ever growing challenge.
YMMV
cuzed2 and DKVBSEATTLE like this.
post #22 of 60 Old 09-21-2016, 07:06 AM
hanesian's Avatar
Quoted: 37 Post(s)
Liked: 86
RT,
The Un-Theater Un-Build
hanesian is offline
post #23 of 60 Old 10-02-2016, 02:20 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
rainy weekend progress photos, added bracing, extended the height of the "back wall" to allow for the bar/drink ledge, added some stuffing, fabricated and secured the end caps, then used a flush trim bit in my router to finish the edges.
ID:	1696889   Click image for larger version
Name:	Stuffing right side.jpg
ID:	1696897   Click image for larger version
Name:	Triiimng edges w-router.jpg
ID:	1696913   Click image for larger version
Name:	Ready for Carpet covering 1.jpg
Al Toid and eng-399 like this.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #24 of 60 Old 10-02-2016, 02:23 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Next up; pick a covering (black carpet from Menards, or a heavy "econo-fabric' from Joannes)...
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #25 of 60 Old 10-02-2016, 06:38 PM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
Some of the Chicago area guys have come up with some very nice nearfield designs. I can't wait to hear your impression once they are up and running. Keep on pushin'.
derrickdj1 is offline
post #26 of 60 Old 10-02-2016, 07:14 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Thanks Derrick !
cuzed2 is offline
post #27 of 60 Old 11-02-2016, 11:05 AM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Teaser:
I've been so busy with post-season Cubs baseball, and actually working on the VBSS', that I haven't taken time to post new photos
Hopefully updates before this next weekend slips by...
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #28 of 60 Old 11-02-2016, 02:01 PM
kevings's Avatar
Quoted: 324 Post(s)
Liked: 501
I'm looking forward to seeing how this develops/turns out!
kevings is offline
post #29 of 60 Old 11-06-2016, 12:33 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
OK back to progress photos:
I needed to build a removable vertical support that could be screwed to the backside once the unit is placed.
Name:	removable support 2.jpg
ID:	1757073   Click image for larger version
Name:	removable support.jpg
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #30 of 60 Old 11-06-2016, 12:42 PM - Thread Starter
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
At this point it was time to cover the unit with carpet. I went with the cheapest indoor/outdoor carpet that Menards sells it's called "auto-bond". simply took my time in trimming and gluing it on with ordinary carpet cement. Here is the finished result.
Name:	port end w-carpet.jpg
ID:	1757089   Click image for larger version
Name:	connector end carpeted -removable support.jpg
ID:	1757097   Click image for larger version
Name:	w-grill installed.jpg
brian6751 and eng-399 like this.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
