Little help here - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Yosh70
  • 1 Post By lovinthehd
  • 1 Post By manuetdeo
  • 1 Post By mobeer4don
post #1 of 12 Old 09-20-2016, 10:30 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Little help here
Good day all,
Had a little question for those in the know. I borrowed some JBL lsr308 from a friend to see how I liked horns and I wanted to see if these would be the kind of speakers that would compare with the what the DIY sound group Fusion stuff sounds like. So the question is are they pretty comparable or am I way off base. Thanks in advance
Sent from my LG-H830 using Tapatalk
manuetdeo is offline
post #2 of 12 Old 09-20-2016, 10:59 AM
Samps's Avatar
Quoted: 1223 Post(s)
Liked: 901
The 308 uses a soft dome tweeter. The diysg stuff mostly use a compression driver. The 308s might sound smoother at lower levels but I doubt they can hang with the diysg stuff at reference. At least not with the kits comparable in price. The 7 series jbls would be better but they are not cheap.
Samps is offline
post #3 of 12 Old 09-20-2016, 11:19 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Thanks for the reply. I have never owned a horn or CD before and wanted to see if I like the sound before I commit to the fusions. The price is not a concern in this regard as I am more interested in the sound of them. I like the 308s and have heard others say horns are harsh which I don't hear with these. Would you say the CD from the fusion series would sound similar to the domes of the jbls? I don't listen at more that 80-90db at the absolutely loudest.
post #4 of 12 Old 09-20-2016, 11:43 AM
Samps's Avatar
Liked: 901
If you have a guitar center near by, they should have both the JBL 308 and lots of CD speakers. You could compare them there. I personally like a dome tweeter better for casual listening. But I also love to crank it so I am all CDs now. Even a low end CD can get seriously loud with only a few watts.
Samps is offline
post #5 of 12 Old 09-20-2016, 11:52 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Doh! I never thought of that. So if I like the sounds of the CDs there, I am safe in assuming I will like the fusion ones?
post #6 of 12 Old 09-20-2016, 12:00 PM
Samps's Avatar
Liked: 901
Not necessarily, but that's as close as you can get. Unless you can find someone in the area that happens to have some diysg kits or maybe jbl cinema or JTR.
Samps is offline
post #7 of 12 Old 09-20-2016, 12:01 PM
Yosh70's Avatar
Quoted: 195 Post(s)
Liked: 142
Thats because....
manuetdeo likes this.
Yosh70 is offline
post #8 of 12 Old 09-20-2016, 12:04 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4791
The implementation of cd/horn still matters. Just like you can't judge all dome tweeters together. Many who have heard domes like the fusions. I recently went to JBL 590/530/520 across the front (all cd/horn) from domes and like it a lot. YMMV.
ps Can you please remove the tapatalk/phone ad from your tapatalk settings? Thanks....
lovinthehd is offline
post #9 of 12 Old 09-20-2016, 12:15 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
@lovinthehd can I do that without being vip?
post #10 of 12 Old 09-20-2016, 12:33 PM
lovinthehd's Avatar
Liked: 4791
Tapatalk vip I know nothing about. In tapatalk , the far right symbol (sort of a silhouette thing) will bring up settings, then signature-edit signature, none.
post #11 of 12 Old 09-20-2016, 01:20 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Thanks for that never realized I was doing that
lovinthehd likes this.
post #12 of 12 Old 09-20-2016, 08:11 PM
mobeer4don's Avatar
Quoted: 165 Post(s)
Liked: 154
Do not judge all horns based on what someone else heard at some other point in time under unknown conditions.
Poorly designed horns are harsh. Properly designed horns are not. It really is that simple. Similarly, crappy dome tweeters sound like crap....
Us your own ears and make your own evaluation. Your challenge, as noted above, is finding something similar to the DIY designs that you can demo in something like a home setting. You hear horns all the time in theaters and live music...some sound excellent and some sound horrible depending on implementation.
mobeer4don is offline
