Time to seriously consider speakers for my dedicated HT - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #1 of 179 Old 10-12-2016, 11:04 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
*** Updated 12/6/17 - Including final results and links to projects along the way ***
Project completed a few months ago, the final results are listed below:
LCR: Fusion-15s - BUILD THREAD
Surrounds and Rear (added): Volt-6 - BUILD THREAD
Atmos: Triad In Ceiling Silver
Front sub: 2 Custom Marty - BUILD THREAD
Side sub: 2 shallow form factor - BUILD THREAD
Gear ended up being:
Denon 6300
(2x) MiniDSP 8x8HD
Marantz 8077
Marantz 7055
Behringer iNuke 6000DSP
Behringer iNuke 3000
Final Pics:
Fusion-15s and Custom Martys
Before
After
Surrounds and rears
Shallow form factor subs
Original post - 10/12/16
Hey all. I've been working for the last couple of years on a dedicated HT, mostly focusing on the room. As that is nearing completion, I'm planning to turn my soon-to-be-available time and budget to electronics and speakers. The plan all along has to open up the theater with existing speakers and electronics, and upgrade as I go along. You can see the room specifics and dimensions here.
Opening day there will be a combination of speaker sets used:
LCR & WL&R will be an old set of Cambridge Soundworks Ensemble (2?) system
4 surrounds will be an old set of Bose Lifestyle (28?) speakers
4 ceilings will be new (to me) Triad In-Ceiling bronzes
2 sub are Klipsch 12'
I haven't bought the electronics yet, but I'm leaning towards:
Denon AVR X7200
External power amplifier (undecided) for the last couple of channels, to get to 13
External sub amps, leaning towards iNUKE 3000s
Soooo, lets talk DIY speakers
I've built most everything you see in my HT thread, and would like to build DIY speakers. I've read a lot of good info in these stickys, and a lot of cool build threads, and I think I have more questions than I started with! As a DIY speaker nubie, I've decided to stick to known speaker configurations and flatpacks. Here's what I'm thinking:
LCR - Elusive 1099s
WL&R - Cohesive 893s
4 Surrounds - Volt 6s
Ceilings - Keep the Triads
Subs - 2x 3cu ft w/Dayton RSS390 & Bash 500w amps
Now the questions:
- Are those speakers sufficient for a strong HT movie sound?
- Are they well matched as a set?
- Is that enough for the room?
- Can I keep the same electronics?
- What am I missing?
Thanks in advance for the comments!
SuperFist and Daniel Chaves like this.
DougUSMC is offline
post #2 of 179 Old 10-12-2016, 11:33 AM
kbclamper's Avatar
Quoted: 106 Post(s)
Liked: 32
i would look at some 18s to keep up with the fronts you are planning. i have 1099s and lms ultras with a clone and the ultras barely keep up
kbclamper is offline
post #3 of 179 Old 10-12-2016, 11:57 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
Hmmm, I tried to find those 18s and it looks like they're discontinued and out of stock everywhere? Also, I don't know what a clone is?
DougUSMC is offline
post #4 of 179 Old 10-12-2016, 12:01 PM
kbclamper's Avatar
Quoted: 106 Post(s)
Liked: 32
i would look at stereo integrity 18s or uxl or um18. a clone is a knock off of the fp14000 amp that puts out about 8000 watts
post #5 of 179 Old 10-12-2016, 12:04 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
Why X7200? Definitely plan on four 18's, you really need that for the proper output and bass smoothing in a room of that size. I'd look at either DS4's or HST18's
Bassment is offline
post #6 of 179 Old 10-12-2016, 12:07 PM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
Thanks! How do I find a clone?
It's pretty much the only receiver I can find that's capable of handling the 13 channels. It's either that or straight separates, which I can't quite afford right now.
DougUSMC is offline
post #7 of 179 Old 10-12-2016, 12:20 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
If you skip the wide channels you can get an X4300, save a pile of money, and with proper waveguide speakers you really don't need wide channels IMO.
ahblaza, dtsdig, rhapsodee and 2 others like this.
Bassment is offline
post #8 of 179 Old 10-12-2016, 12:32 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
Or you can get the X6300 instead which has 11 Ch of built in amplifiers. Also I don't believe the X7200 can do 13 channels (11 channels + 2 subs), it only does 9 channels + 2 subs, so you would have to go to either 2 surrounds or 2 ceiling, not 4 of both if you have wides.
Bassment is offline
post #9 of 179 Old 10-12-2016, 12:41 PM
dtsdig's Avatar
Quoted: 1121 Post(s)
Liked: 1382
I agree with the comments above. Skip the wides, just focus on LCR, surrounds/surround backs, and ceiling (if you can go that way).
I also agree with the sub comments. I own 1099's and 2-18's do not keep up. If you've got a large room, I would look at 4-18's. Stereo Integrity DS4 or HST-18, Dayton Ultimax or Dayton H.O., Mach 5 audio UXL are a couple of options for subs.
dtsdig is online now
post #10 of 179 Old 10-12-2016, 12:51 PM
kbclamper's Avatar
Quoted: 106 Post(s)
Liked: 32
there is a thread in this section dedicated to the clone amps if you search. if you go with 4 hst18s nick usually gives a bulk discount
91clone likes this.
post #11 of 179 Old 10-12-2016, 01:00 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Now the questions:
1099 is more than sufficient, it's one of the loudest speakers I've heard that size. You won't be able to tolerate it anywhere near the point it might distort or damage.
Matched as a set I would say no. Different models, different speaker designers, and different branded parts. But EQ could help negate.
It's plenty for the room.
You might want to add a sub or two and consider the placement relative to bass response. Multiple subs and locations tends to have a postive effect on response - and more important allows you to EQ it for multiple seats.
If you really want wides I would use matching ones so perhaps 5x 1099. The 893 actually has better bass response but I don't see that being an advantage in that application so the matching might trump that in importance.
Mfusick is offline
post #12 of 179 Old 10-12-2016, 01:07 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
Bassment is offline
post #13 of 179 Old 10-12-2016, 08:01 PM
BassThatHz's Avatar
Quoted: 3626 Post(s)
Liked: 4091
Oh come on now...
A pair of LMS's output 130db of mid-bass @ 1m, and THX level to 15hz @ 1m (if you port them... otherwise 20hz.)
Unless you are using RF-19's or SI-24's then that's pretty much: as loud as it gets.
Neither the LMS or 19 or 24 are "cheap".
The problem is that the LMS doesn't distort and the human ear is insensitive to bass. 80db @ 30hz = 1db @ 4khz
That's a LARGE difference to make up for, regardless of which sub you use... (if you do the actual math, 1db vs 80db is like 100million times the power-level required to match it.)
If the roles were reversed, if treble were insensitive, the SEOS's would sound just as weak in that same scenario.
It has nothing to do with the device and everything to do with how human ears work...
The solution is to buy more 18's. But you already knew that...
ahblaza likes this.
BassThatHz is offline
post #14 of 179 Old 10-12-2016, 08:11 PM
kbclamper's Avatar
Quoted: 106 Post(s)
Liked: 32
Originally Posted by BassThatHz View Post
Oh come on now...
my ultras will be getting put into some lowarhorns soon so hopefully wont need anymore
post #15 of 179 Old 10-13-2016, 04:52 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
Wow, a lot of awesome stuff here, THANKS everyone for the awesome feedback! I'm already mentally changing up my plans, but some of the responses have me scratching my head a bit...
The manual shows how to do 13: Use the 11 output leads, and pre-out for 12 & 13 to an external amp. I plan to output the subs to external amps, and from there to (4-6) subs in the room.
Wow, not a lot of folks interested in the wides. I'm wondering why this concensus? I'm thinking I want maximum flexibility for making my movie experience what I'm looking for. Is there just the belief that they're unnecessary, or something else here?
Thanks MUCH for the list of 18's to check out. I think they run the full field from ~$250 - 600 ea!?!? Is there anywhere that someone as new to this as I am can "reasonably" compare them?
Thanks for this, it cleared up a lot. I understand what you're saying about mixing the models, and think that makes sense. Since I'm looking to expand the subs from 2 to (at least) 4, what's the pros/cons of changing up from 5x1099 to 5x893? This will free up just a little for more subs, but every bit helps!
Oh come on now...
Yup, I'm now leaning towards 4x18s, and starting to research what I'd need to make that happen. I was thinking about (2) 2x18s cabinets, but can't find a flatpack for those anywhere? Is this just because everyone picks up a couple of 4 cuft packs and just stacks them?
DougUSMC is offline
post #16 of 179 Old 10-13-2016, 05:35 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
1099 has better dynamics and plays louder, 893 gives more low end in less space. I'd go 1099.
Mfusick is offline
post #17 of 179 Old 10-13-2016, 06:30 AM
esappy's Avatar
Quoted: 302 Post(s)
Liked: 283
The X7200WA has a total of 15 outputs (13 for speakers and 2 for subs). Of the 13 outputs available for the speakers, the receiver only has enough processing power to use 11 of those outputs at the same time. The 2 sub channels are always active. So even though you can connect 13 channels worth of amplifiers to all the speaker channels, you will be forced to select to use the wides and 1 pair of overheads/atmos enabled speakers, or you forgo the wides and use 4 overheads/atmos enabled speakers. Now I think the general consensus for those wanting to really get into the whole dolby atmos/dts-x thing, going with the 4 overheads is more desirable than just doing 2. Now I believe the X7200 is flexible enough to where you can opt to use wides and 4 overheads, BUT you will have to forgo surround back to keep it to 11 channels max. So your options are 9.2.2 (uses surr. backs and wides and 1 pair of overheads), 7.2.4 (uses surr. back and 4 overheads), or 7.2.4 (turns off surr. back, uses wides and 4 overheads). I believe the big appeal of the X7200 is that it will let you choose various combos for various surround modes. So it is very flexible (as it should be for a flagship unit). Bottom line, while it has 13 speaker outputs, only 11 are usable at a time and it is up to you to decide which combination you want to go. There is a whole thread dedicated to this receiver that should answer all your questions. Hope this helps. Semper Fi!
Eric
"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors." - Plato
esappy is offline
post #18 of 179 Old 10-13-2016, 06:34 AM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
The easiest way to see a general comparison of 18's is looking at the xmax and then the power handling. The HST18's are close to twice as much bass as the cheaper subs, but need more power too. You probably can't find 2x18 flatpacks because that would be too heavy to ship. Even a single 18 flatpack is like 100 pounds. Also in a room that size you should go ported, not sealed, unless you really want that 5-10 hz stuff.
For the Denon X7200, yes you can connect 13 speakers at one time, however it only has 11 channel processing, meaning you can only use 11 speakers at once. It's so you can switch between two different "configurations" of 11 speakers. "This system, which is based on a 5.1-channel system, plays back up to 11.1-channels at the same time.
You can connect speakers for up to 13-channels for MAIN ZONE by using an external power amplifier. When you connect speakers for 12 or more channels, the output speakers automatically switch according to the input signal and sound mode."
Bassment is offline
post #19 of 179 Old 10-13-2016, 06:42 AM
frankie2075's Avatar
Quoted: 467 Post(s)
Liked: 115
I owned the 1099s 3 of them. There's awesome speakers idk what size restrictions you have or the size of the room. But I would do 1299s if you can cause you can make them a litter bigger make them go a little lower. But the 1099s are a great speaker. Dynamic pretty loud. Just didn't have enough midbass for me.
frankie2075 is offline
post #20 of 179 Old 10-13-2016, 07:43 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
That brings up another question: I've read thru the sticky, and a couple of the resources on ported/sealed/horn, and still don't understand the difference. I've been leaning towards sealed because it looks like it'll be easier to place/tune the room with multiple sealed (4 behind screen, 2 on opposite end of room), but don't pretend to understand any other logic of one vs. the other?
Speaking of cabinet design: Is it a religious battle to ask about built-in vs. rack amps? When I wired the room I ran 2x COAX and speaker wire to behind the stage. I'm leaning towards building 4x 18" sealed cabinets, installing 2 rack amps, and splitting the COAX with a y-splitter. Any better suggestions?
So, that's the exact page I refer to in the manual when I say it'll handle all 13 channels for me. Am I misreading that, and it won't actually do it?
Looking at the diagram, to me it seems to show that adding an external amp for the last 2 ceiling speakers allows:
LCR + FWL&FWR
4 surrounds
4 ceiling
Sub out
What am I missing?
DougUSMC is offline
post #21 of 179 Old 10-13-2016, 07:52 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
I like a rack all over a plate amp. It's just easier and generally a better bang for the buck. You don't worry about power chords near your sub location which is nice - and if you need to get at it I think it's easier to get at it at the rack - a lot of amps you can use cat5 or USB to enter settings and it's much easier to use PC screen and see what you are doing IMO - I leave my amps wired to be remote into from laptop whenever so I don't need to go move stuff or get it at.
Mfusick is offline
post #22 of 179 Old 10-13-2016, 07:53 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Basically you can hide it away in a proper place (the rack) and tweak it without needing to get at it or much effort
Mfusick is offline
post #23 of 179 Old 10-13-2016, 07:58 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Sealed is easier to build, cheaper and smaller. Nothing wrong with that.
Ported is sometimes sloppier or less tight because a vented enclosure inherently has a worse transient response than a sealed enclosure does- (that rear wave thing) and most people don't spend the right amount of money and get a proper driver that's appropriate to vented. The trend is bigger is better and the lower price point 18" tend to have more cone mass and less motor control so they model great in winISD and make great spl - but the transient response isn't as good. Luckily most of the people doing this don't understand the problem so ignorance is bliss.
If ported I'd use a woofer with a proper motor to cone ratio - And go with a relatively larger enclosure and lower tune. That solves the problem. Notnyt did his ported enclosures properly. An ht18 in 4 cubic feet ported at 20hz wouldn't be what I'd do if you wanted ported.
Mfusick is offline
post #24 of 179 Old 10-13-2016, 08:05 AM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
LCR + FWL&FWR
4 surrounds
4 ceiling
Sub out
What am I missing?
Basically ported subs are a bigger box, but they are more sensitive (Think 93 dB/watt sensitivity vs 85 dB/watt). The most tangible benefit is at the "tuning frequency" which will typically be about 20 hz for a ported. You gain 12 dB over a sealed sub. 12 dB is equal to quadrupling the drivers, so a single ported at 20 hz is equal to 4 sealed. Of course ported need a high pass filter, so they lose the super low freq from 5-10 hz compared to sealed. As far as integration goes they are not any easier or harder to integrate. My suggestion for amps is rack amps, and you just run RCA from the receiver to the amp and then speaker wire to the sub. You minimize on unwanted noise that way.
The amp can have 13 speakers connected at once, like the picture, but it can only output to 11 of them at once.
Bassment is offline
post #25 of 179 Old 10-13-2016, 08:43 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
I think I dig what you're saying here, and I like the fact that I'll be able to put the amps in my rack, that's why I built it, and there's a HTPC already in there w/a network switch. Is there a max distance I have to worry about running my 10ga speaker wire before there's too much signal loss from the rack (back corner of the room) to the sub (front center)?
I think that the key is that these might be beyond my current skill level, and as Mfusick said above, my ignorance is bliss...
Sooo, since I only ran 2x copper for subs, I'll have to add 2 more runs? Or just highjack the 2 I ran for the Wides, *because*:
Your last sentence really cleared something up for me! I read "
When you connect speakers for 12 or more channels, the output speakers automatically switch according to the input signal and sound mode." to mean that it would automatically switch from amplifying the last 2 channels to automatically sending them to pre-out for amplification. NOW I understand that it really means that they're only sometimes active, depending on which sound mode I'm in?
DougUSMC is offline
post #26 of 179 Old 10-13-2016, 10:13 AM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
10 gauge is good for quite long runs for subwoofer power, like 50 feet.
A ported sub isn't any harder to build than a sealed, unless you just randomly build a box and guess at the size. There is a ton of software now so we know exactly how to build ported, so they are trivial to build. They involve two extra pieces of wood more than a sealed, that's it. Check out the "Martysub FAQ" they are really easy to build.
You might be fine with the two runs you have right now, depending on the location of your subs. If you are stacking subs, then you can run them in parallel off one channel of the amp. The FP14000 that you're looking into is great for four 18's (two per channel), and you'd only need the two 10 gauge wire runs you already have. Basically the positive would connect to the two positive terminals of the subs, and the negative would connect to the two negatives (parallel).
Yep, exactly that, it changes the speakers it outputs to based on the mode. It's a really gimmicky feature IMO, and verges on false advertising. I imagine a lot of people read it how you did when they bought it.
Bassment is offline
post #27 of 179 Old 10-13-2016, 10:47 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
I just don't know that I'm convinced I'll even notice a difference for the effort? Since I have like 9 boxes to build, I'm really leaning towards flatpacks. Anyone know if I can get a discount anywhere?
It look like DIYSoundgroup is out of them...
I didn't know that a single FP14000 could handle 4? I figured it was a pair per am?
Cool, then I can just use the two I've already run, and save the wides for when receivers eventually catch up to me.
I call shenanigans!
FriscoDTM likes this.
DougUSMC is offline
post #28 of 179 Old 10-13-2016, 10:53 AM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 631
For a given driver, the passband sensitivity of a vented box and a sealed box system are identical. Given a proper design for both, the vented box will be larger and its cutoff frequency lower.
Given a properly designed vented box and closed box system with the same cutoff frequency, the vented box system will have better sensitivity, but the two systems will require different drivers.
andyc56 is offline
post #29 of 179 Old 10-13-2016, 10:57 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
For clarification's sake (and because I just realized how messy my thread had gotten, here's my layout. The screen wall is to the right, the server rack is hidden by the swinging middle acoustic panel.
This one shows what the screen wall looks like. The total width is ~ 16ft, and it's about 22" deep up there.
ID:	1714177   Click image for larger version
DougUSMC is offline
post #30 of 179 Old 10-13-2016, 11:06 AM - Thread Starter
DougUSMC's Avatar
Quoted: 686 Post(s)
Liked: 557
To clarify what those wall plates you see on the back wall are:
The top row is (left to right): Wide Left Speaker, Left Speaker, Center Speaker, Backstage light switch, Right Speaker, Wide Right Speaker
Middle row is (left to right): Left Sub copper and COAX, Right Sub copper and COAX
Bottom row is (left to right): 20A power outlet, Ethernet jack, 20A power outlet, 20A power outlet
DougUSMC is offline
