Few realized and future DIY projects - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #61 of 83 Old 04-30-2017, 09:08 AM - Thread Starter
jororaitchev's Avatar
Liked: 44
If you wanted actually measure, after completion, or taping on something as an outer skin, you could fill it with something granular and low density (cat litter maybe), and then measure its volume.
Why is more than an approximate volume necessary?
Congratulations!
Finally, the right person was found!
A method, discovered around 2300 years before the invention of the computer by a one great Bulgarian!
jororaitchev is offline
post #62 of 83 Old 04-30-2017, 09:28 AM - Thread Starter
Liked: 44
It's not cat's WC / in the time of Aristotle she don't exist / - H2O Is the right answer.
post #63 of 83 Old 04-30-2017, 11:27 AM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 210
I was thinking fill it but it would make such a mess in a nice cabinet, just not worth it.
Sent from my SM-N910V using Tapatalk
Vince_B is offline
post #64 of 83 Old 05-02-2017, 08:31 AM - Thread Starter
Liked: 44
Perhaps, you have not noticed the white color of the inside of the column. When I create a new project, with a complex vented interior, I always process inside of the column very carefully / impregnate it / with polyurethane varnish. Measuring with water is not a problem.At the moment I am committed to a customer, soon I will show you my method with photos.
post #65 of 83 Old 05-22-2017, 05:36 AM - Thread Starter
Liked: 44
Originally Posted by jororaitchev View Post
notnyt's Quote:
Now I want to show you my new project:
"J&N"
Speakers: "SEAS" Excel; TW-T25CF002;MW-18EX001;W 2x26 FX001
Nominal impedance- 8 Ohm
Free air resonance FS-21Hz
Sensitiviti /2,83V/m/-90db
Eguivalent volume/ VAS-170l/
Long Term Power Handling-150W
Ventilation is taken "B&W" Diamound800
Why and how should a beautiful project be changed at the outset?
The problem is in the frequency of around 5000Hz; There is a peak ,which strongly influences the average frequencies.There are two ways to solve this problem:
- Adding one more MW,
-More complicated construction of the filter I don't know the exact name , maybe (reager).
This project may be look beautiful, but will be changed.
As I wrote at the beginning of my post, everything is done by me, I do not use ready filters / and I do not recommend it to anyone unless it is a ready-made kit with cabinets /.Will try to explain why this project is changed at the very beginning.
post #66 of 83 Old 05-25-2017, 06:06 AM - Thread Starter
Liked: 44
Characteristics of the speaker in 55 liters closed volume:
What should I choose in this situation?
-1 option, add one more 18 FX001,
-2 option,remove one 26 FX001,
I chose a new progect with 4 identical speakers:1 х 26 FX001, 1х 22 FX001, 1х 18 FX001 , T 25 CF002.
Graphics - 1 Filter scheme; Graphics - 2 Transfer characteristic:
Without filter - reside
With a filter - burgundy
Name:	Сравнение АЧХ  2 W26FX001.jpg
ID:	2154762   Click image for larger version
Name:	Схема Фильтра.PNG
ID:	2154826   Click image for larger version
Name:	Передаточная х-ка фильтра.jpg
post #67 of 83 Old 06-09-2017, 10:26 AM - Thread Starter
Liked: 44
From waste material I made this gadget ,that takes part in the measurements and when assembling the cabinet:
ID:	2180537   Click image for larger version
ID:	2180545   Click image for larger version
ID:	2180553   Click image for larger version
ID:	2180561   Click image for larger version
post #68 of 83 Old 06-16-2017, 08:39 AM - Thread Starter
Liked: 44
Continue:
I fill the cabinet with water to the red line / there ends the front panel with the speakers /;
I find the volume - 43l, I deduct the weight of the internal ribbed - massa 3.4kg.
And the net volume of the cabinet is 39. 6l. More than I need, I need about 35l.
There is one more option, but for him later.
Modify message
ID:	2190865   Click image for larger version
post #69 of 83 Old 06-21-2017, 04:05 AM - Thread Starter
Liked: 44
The problem is that my investor likes the vision of the column.The decrease in volume must occur inside the construction of the cabinet.This sends the project in a more initial phase,we have a new requirement for the project, second W18 EX001.
The old project stayed in the past ...
ID:	2197337   Click image for larger version
post #70 of 83 Old 06-30-2017, 02:15 AM - Thread Starter
Liked: 44
A little progress;
With the new interior design, the volume is 35.2 l
ID:	2210817   Click image for larger version
ID:	2210825   Click image for larger version
post #71 of 83 Old 07-15-2017, 03:55 AM - Thread Starter
Liked: 44
I can now start collecting the cabinet , after the pretreatment of the ribbing;
ID:	2237441   Click image for larger version
ID:	2237449   Click image for larger version
post #72 of 83 Old 08-02-2017, 12:35 PM - Thread Starter
Liked: 44
I have an idea to make a new project to in the base there should be two 10" loudspeakers - just an idea. They look like animals, maybe dinosaurs, but important are 20Hz.
bscool likes this.
post #73 of 83 Old 08-20-2017, 12:33 AM - Thread Starter
Liked: 44
And the original model will look like this;
post #74 of 83 Old 08-30-2017, 11:38 PM - Thread Starter
Liked: 44
I continue with the collection of the cabinet;
Now I can make the exact measurement of the volume. And that's 31.5l, just as much as I need!
Oh, l forget to show you what I did to get that volume!
I maked a filter compartment (for the MW and TW), the W section will be in the box;
post #75 of 83 Old 09-12-2017, 08:45 AM - Thread Starter
Liked: 44
Several steps to the moment with measurements ...
bmkev likes this.
post #76 of 83 Old 09-14-2017, 11:11 AM - Thread Starter
Liked: 44
I noticed changes in the requirement for uploading for pictures - I do not like it!
post #77 of 83 Old 10-10-2017, 11:56 AM - Thread Starter
Liked: 44
After the measurements, this is are Technical data:
Frequence Range; 33-25000 Hz
Long term Max Power; 200 W
Crossover Frequency; 2800 Hz
Impedance; 4 Ohms
Sensitivity; 90 db SPL
Cabinet Volume; 31 L
Gross weight / without stand /; 27kg.
This is the project of the rear speakers, will finish it with "Bird's eye view". There will be a sequel ...sometime..
Joro Raitchev
Sofia- Bulgaria
post #78 of 83 Old 11-29-2017, 05:55 AM - Thread Starter
Liked: 44
A very underestimated moment - work with multilayer MDF!
There's still a lot of work on the stands.
I show you a few pictures of the front speaker bases, the rear speaker stands will look like the same;Always been a problem with the MDF, especially when we have a multilayer construction. Over time, individual parts are beginning to show up - all of this is the result of improper processing. Soon I will show you how to deal with this problem.
ID:	2322814   Click image for larger version
ID:	2322816   Click image for larger version
ID:	2322818   Click image for larger version
post #79 of 83 Old 06-21-2018, 05:24 AM - Thread Starter
Liked: 44
A very, very underestimated moment - work with multilayer MDF!
I show you a German site, that offers such "DIY loudspeakers -cabinet " and please for your attention, they want money for such a product;
post #80 of 83 Old 06-24-2018, 09:27 PM
noah katz's Avatar
Quoted: 1873 Post(s)
Liked: 660
The way I deal with MDF joints showing is by painting with polyester or epoxy resin.
Immediately after applying the first coat, I use a heat gun to reduce its viscosity and make it absorb deeper.
The result is wood/plastic composite that is very stable.
I apply additional coats while the first is still tacky so that the outer layer is solid plastic.
Pic shows my MDF joints 4 years after the build.
Noah
noah katz is online now
post #81 of 83 Old 06-26-2018, 05:12 AM - Thread Starter
Liked: 44
Your method is one of the right ones, especially when talking about finishing, with some paint!
My idea was that the German DIY- site in question did not foresee that moment with the huge finishing work, but offers, something like a product, they have not even tried to make one body in the right way speakers , at least for advertising!
post #82 of 83 Old 06-27-2018, 11:55 AM - Thread Starter
Liked: 44
A look at the room where I listen to music/everything you see is created by my hands- fact!/;
post #83 of 83 Old 10-25-2018, 02:35 AM - Thread Starter
Liked: 44
Several new momentum in the construction of the stands for the rear speakers;
P.S.
This is the address of my group, here there are no limitations on posting your DIY- Audio Ideas in photos, I would be very pleased if we met there! In this group , commercial posts are not allowed!
Thank you for your attention!
Joro
https://www.facebook.com/groups/1046794425475324/
ID:	2473182   Click image for larger version
ID:	2473184   Click image for larger version
ID:	2473186   Click image for larger version
Trimlock likes this.
