Doug's 1st Timer DIY Soundgroup Fusion-15 Sentinal Build Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #31 of 97 Old 11-28-2016, 02:39 PM
asarose247's Avatar
Quoted: 1203 Post(s)
Liked: 1059
Sure looks like "fun"
wanna have fun? -try connecting those nonexistent dots on a piece of bare pegboard,
Matt proved to be very helpful.
attack it . . .
Toxic teletubby likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #32 of 97 Old 11-28-2016, 02:43 PM
Toxic teletubby's Avatar
Quoted: 213 Post(s)
Liked: 354
attack it . . .
Solder By Numbers - can you do a Velvet Elvis?
Marantz SR6010 Onkyo 636 Onkyo NR801
Epson 3700 Sammy 55JS7000 Sammy K8500 Toshiba HD DVD Sony UBP-X800
Fusion F15's (LCR) Fusion 8's (SS) -JBL Studio Monitor 4406 - SVS SB1000 >BIC F12 Sub
TruAudio Revolve 8" - atmos
Toxic teletubby is offline
post #33 of 97 Old 11-28-2016, 03:00 PM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
attack it . . .
This will be the first bit of soldering I've ever done, let alone the first crossovers, I'll need all the help I can get!!
Anyone interested in where they came from, they're a newly available set. Contact @ja00 for specifics. I'm test-driving them out from a nube perspective, in exchange for the experience and help getting them done.
DougUSMC is online now
post #34 of 97 Old 11-28-2016, 05:36 PM
asarose247's Avatar
Liked: 1059
using the mounting holes in the corners of the board, using 2 pieces of 3/4"
ply about 3" high and long enough to reach down each side.
attach these 2 pieces to a piece of ply so you have a U channel for the xo to sit screwed down on while you poke /set / hot melt /zip tie each component in place without needing to bend or otherwise shorten the leads
once it's all fastened down, then you can remove it from the jig, flip it over and check your work,
leave the leads original length and solder a good connection.
if you can test it , just watch out fore errant touching.
when it's good, or you think it's good
snip the unneeded leads almost down to the dot
Dot's all there is too it . . .
ROCK ON!
post #35 of 97 Old 11-28-2016, 05:52 PM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
ROCK ON!
That's a cool idea, with using extra ply to make a raised work surface, thereby not having to snip the leads. Consider that idea stolen, thanks!
post #36 of 97 Old 11-28-2016, 07:37 PM
asarose247's Avatar
Liked: 1059
DUDE!
you should browse the DIYSG forums a bit more (after this build)
many creative experienced fellow DIY'ers chipping in their .02
I "stole" that idea from there but as a noob myself, > who's gonna just think that up!
iirc it was mtg90 who no doubt got it from . and so on.
"some" overachievers want to use 12 gauge from the board to the input jacks and i'll bet the board isn't sized for that, more like 16. if you're careful, BY HAND, you may be able to use a drill bit and carefully /slowly enlarge the hole to fit 14 but the 16 is scientifically adequate.
and don't be sell yourself "short' on the length of the leads to the horn and woofer from the board, being able to attach to the drivers well outside the box without touching the superb finish on that front baffle, yada yada yada.
(wish i had something to build besides room treatments - tons of fun )
ja00 likes this.
post #37 of 97 Old 11-28-2016, 07:40 PM
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 668
Originally Posted by DougUSMC View Post
This will be the first bit of soldering I've ever done, let alone the first crossovers, I'll need all the help I can get.
Erich H, asarose247 and ja00 like this.
VicTorious1 is offline
post #38 of 97 Old 11-29-2016, 04:47 AM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
DUDE!
I've been reading more and more lately, but he Catch-22 is the more I'm reading, the less work I get done!
I'll probably use 12, but not out of a misguided overachieving attempt. I don't have 14 or 16 lying around, so it's easier to run 12 and just whittle down the wire a bit.
Originally Posted by VicTorious1 View Post
I dig the tips and video, thanks!
post #39 of 97 Old 12-02-2016, 04:25 AM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
Received my shipping confirmation on the DIY Soundgroup kits yesterday, they should be delivered Saturday. I hope to make good progress over the week!
post #40 of 97 Old 12-04-2016, 03:21 PM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
Ok, annoyingly busy weekend (2 day training class AND my company Christmas party on Sat night), so I didn't get much done. Dry-fit the front baffle, and I'm going to have to trim down my support braces to make sure there's clearance for everything. It's too tight in a few spots, but I'm ok with that, given the fact that I just made a WAG on them in the first place.
ID:	1807521   Click image for larger version
ID:	1807609   Click image for larger version
VicTorious1 likes this.
post #41 of 97 Old 12-04-2016, 03:30 PM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
I also stole a pretty genius idea from @ asarose247 , and made a setup to test fit the components for the crossover onto the board.
I basically took some left-over 2x6, cut in half, and put a screw thru the boards in a couple of spots. This lets them float, and I can test-fit all of the components on the board to start out:
Then I dry fit the pieces, just matching up what's written on the board with the stamped label on each.
This means that I can just stick the leads thru the board, test it out, and not have to snip them or bend them badly. From underneath it looks like this:
Lastly, a closeup of what it one board looks like, before any more steps:
Next thing to do is zip-tie and hot-glue everything in its place. Running out of time tonight tho, so that'll have to wait until tomorrow.
Credit so far also goes to @mtg90 , whose awesome video's step-by-step I'm following and referring back to frequently!
ID:	1807649   Click image for larger version
ID:	1807657   Click image for larger version
ID:	1807665   Click image for larger version
post #42 of 97 Old 12-04-2016, 05:19 PM
HFGuy's Avatar
Quoted: 229 Post(s)
Liked: 244
Mount the inductors the other way around my friend.
HFGuy is offline
post #43 of 97 Old 12-04-2016, 05:30 PM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
You mean they're upside down? Are those feet supposed to be the glue points? And do I just pull the leads up and bend them out of the way to get the tinned part to the right depth for soldering?
post #44 of 97 Old 12-04-2016, 05:32 PM
HFGuy's Avatar
Quoted: 229 Post(s)
Liked: 244
Not the best photo to describe how I mounted them but its all i've got
HFGuy is offline
post #45 of 97 Old 12-04-2016, 05:37 PM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
Cool, that makes a lot of sense. Thanks for the help and bothering to stop by and let me know!
post #46 of 97 Old 12-04-2016, 05:53 PM
HFGuy's Avatar
Quoted: 229 Post(s)
Liked: 244
That's what this community is for.
BTW I use big zipties to secure the inductors, not glue.
HFGuy is offline
post #47 of 97 Old 12-04-2016, 05:54 PM
ja00's Avatar
Quoted: 224 Post(s)
Liked: 149
+1 what @HFGuy said.
Couple recommendations:
1. Make sure you peel the insulation off the inductors before you solder them. Exposed wires should be visible from the top side to guarantee you have soldered bare wire on the bottom side of the board. It is ok to bend the wires up on the inductors a little bit to not have the insulated part on the hole.
2. When bending leads of components, try not to bend right at the component/lead junction. Make the bend so that the wire exiting the component is perpendicular to the component and the wire through the hole is perpendicular to the board. Try to make the wire bends smooth, not sharp.
3. Try to mount the capacitors so that the values are visible. This will come in handy later IF you need to troubleshoot.
4. When using hot glue, make sure it does not go through the holes. There were a couple instances where the glue prevented good connection.
It is great that you dry fitted before soldering!
ja00 is offline
post #48 of 97 Old 12-04-2016, 06:25 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 215
Looking good. It's smart of you to do a dry fit and see what goes where and how things fit together. The dry fit allows you to fine-tune braces and placement of things. That cautious methodology will serve you well in this hobby.
I like the bracing; simple yet effective. I will probably use a variant of it in my sub builds. IMO, people tend to over-think bracing. This isn't engineering of a 2-mile-long cable suspension bridge or some other incredibly complicated and sensitive structure.
Take your time with the crossovers; you've received excellent advice so far. If in doubt, STOP, take a picture or two and ask. IME, the two most important things when soldering crossovers together are ensuring a good solder joint and avoiding solder bridges. Of course, having the correct components in the correct place goes without saying!
michaelddd is offline
post #49 of 97 Old 12-04-2016, 06:29 PM
HFGuy's Avatar
Quoted: 229 Post(s)
Liked: 244
Best solder advice I can give after teaching hundred of baby engineers of the years - Use the joint to melt the solder, not the soldering iron itself.
VicTorious1 and ja00 like this.
HFGuy is offline
post #50 of 97 Old 12-04-2016, 06:35 PM
Quoted: 580 Post(s)
Liked: 668
Personally, I didn't let any of the colored/red insulated part of the wires enter into the holes. I had only the exposed portion of the wire enter the holes. It makes for easier soldering and less of a need to troubleshoot later in order to check that you properly removed all of the insulation before soldering. Ja00's pic is a good example.
1st Cav likes this.
post #51 of 97 Old 12-05-2016, 04:57 AM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
I'm OCD, so I'm planning to use both. Glue to get it in place, then zip tie to keep it there. That's my plan for everything big/heavy enough that I worry about it moving as the driver thrashes.
1. I knew that the insulation had to be out of the way, but didn't even know I could remove it. I was just planning to pull them back out 'til a non-insulated part was poking thru.
3. Definitely, that's why the stickers are still on some of them! At least 'til after I solder.
One thing I noticed in your picture was that you had the zip ties over the fabric wrapping the inductor. Is that coincidence/looks/preference, or necessary?
Thanks! The dry-fit is more of a necessity, since I had no measurements on the baffle and KNEW there was a 1/1000000 chance that I'd guess right. The bracing isn't really my idea, I just checked out some build threads, the pictures on DIY Soundgroup, and re-created them. Credit there goes really to Erich.
Good call, thanks! I watched mtg90's video a bunch of times, but didn't notice he was intentionally doing that 'til you mentioned it.
Another good tip, thanks!
All of this stuff should make the build simpler, and I think I'm going to have to take more pics if I want this thread to serve as a "Idiots Guide to Your First Speaker Build".
Thanks for all the comments and help, please keep 'em coming!!
post #52 of 97 Old 12-05-2016, 08:03 AM
ja00's Avatar
Quoted: 224 Post(s)
Liked: 149
Depending on the insulation rating, you can heat it up enough to melt it and remove it, or scrape it off. But yeah, your method of just using the already exposed part is best because it is already tinned.
It's best to keep away from the wires when using zip tie to avoid damage, but not required. Should be fine either way. Some of these inductors don't have the black fabric in the middle so it is not possible to avoid the wire. The air core inductors don't even have these. Just be careful not to nick the wires when working on them. But really should not be an issue.
ja00 is offline
post #53 of 97 Old 12-05-2016, 08:27 AM
HFGuy's Avatar
Quoted: 229 Post(s)
Liked: 244
If it was that easy to remove the enamel off of the inductor wires with a soldering iron than you could never reliably solder any inductor.
HFGuy is offline
post #54 of 97 Old 12-05-2016, 08:54 AM
ja00's Avatar
Quoted: 224 Post(s)
Liked: 149
I did not mean heat it up with a soldering iron, sorry I should have been more specific. Although I have used some wires in the past that are solder strippable, but then again I had a solder bath.
I meant using some kind of light source like a match, butane lighter or even your stove. But this will only work if the insulation rating is not that high and I don't know what the rating of those wires are.
ja00 is offline
post #55 of 97 Old 12-05-2016, 09:22 AM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
It sounds like I should just stay away from that step. We'll see how much excess I "really" have left, after I flip those right side up.
The plan for now is to just give them a little more bend up top, if possible.
post #56 of 97 Old 12-05-2016, 10:02 AM
HFGuy's Avatar
Quoted: 229 Post(s)
Liked: 244
Are you talking about Litz wire ?
HFGuy is offline
post #57 of 97 Old 12-05-2016, 05:49 PM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
Ok, a little bit of progress today, but not much. In order to keep it all accurate, I took off most of the components, straightened the leads, and re-placed them with the labeling showing, better arches, etc. As a result, all I got done was that, hot-gluing, and the zip ties. Ran out of time before I could get the soldering done, but that should be pretty quick and easy tomorrow. (Famous last words...)
What say you gents?
ID:	1810561   Click image for larger version
post #58 of 97 Old 12-05-2016, 06:29 PM
Razz2o4's Avatar
Looks nice, I can't wait to see the finished product.
Razz2o4 is offline
post #59 of 97 Old 12-05-2016, 09:27 PM
ja00's Avatar
Quoted: 224 Post(s)
Liked: 149
That looks good.
It may seem like all this prep work is unnecessary or waste of time even but trust me it pays off in the end, assuming of course this will not be your last crossover build. Once you get on the habit of spending more time up front to make sure everything is correct, you will spend a lot less time with actual soldering and frustration later on. No different than measuring twice, cutting once.
ja00 is offline
post #60 of 97 Old 12-06-2016, 04:34 AM - Thread Starter
DougUSMC's Avatar
Quoted: 695 Post(s)
Liked: 586
That looks good.
Don't worry, the plan also calls for 4 Volt 6 as surrounds.
I really am going super slow b/c I have a feeling this is one of those times where problems compound and speed kills. I wanted to just open the package, heat up the glue gun, stick and solder, but I'd have already had problems. All those inductors would've been upside down, almost every piece's label was unreadable, and the leads weren't as pretty. I've probably spent 3x as long as needed on these, but if that means they all work the first time, it's worth it!
