An rpi based DIY Vibration meter - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
post #91 of 321 Old 03-10-2017, 10:59 AM - Thread Starter
3ll3d00d's Avatar
Quoted: 2481 Post(s)
Liked: 2699
I think I'm going to adopt the ISO (1631?) reference acceleration and convert the graphs to dB, this places 0dB at 1 micro m/s^2 which means 140dB is 10m/s^2 (i.e. about 1G)
main reason is that it simplifies the plotting of a normalised curve (for technical reasons...)
dominguez1 likes this.
3ll3d00d is online now
post #92 of 321 Old 03-10-2017, 05:59 PM
dominguez1's Avatar
Quoted: 1172 Post(s)
Liked: 1112
Makes sense...get everything in db...easier to speak the same language across different metrics.
Do you have a link for this ISO reference?
dominguez1 is offline
post #93 of 321 Old 03-10-2017, 11:24 PM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
A small side note, no need to reference things to 140 db. That is way to high unless the reference used is less. Anything over 128 db. from the subs is clipping somewhere with movies and clean output was a goal of the thread. You can have a 100 subs but, the movies were only meant to be so loud and ear protection should not get loss in all of this. The goal is to keep our hearing and enjoy it.
derrickdj1 is offline
post #94 of 321 Old 03-10-2017, 11:33 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
It is mentioned in http://www.acoustic-glossary.co.uk/d...m#acceleration and http://www.diracdelta.co.uk/science/...l#.WMOn6WmnxnE
If you Google acceleration reference db then you get lots of hits including that "measuring vibration" b&k pdf.
post #95 of 321 Old 03-10-2017, 11:36 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
SPL dB (which is referenced against 20 micro Pa) and La dB (which is referenced against 1 micro m/s2) are two completely different scales so 140 in one means nothing to the other. I'm sure we can (will) arrive at a view on what dB constitutes reference though.
post #96 of 321 Old 03-11-2017, 01:49 AM
derrickdj1's Avatar
Liked: 767
Matt, your work for this ULF and Vibsensor thread is appreciated at the highest levels. I am just putting a caution for us to keep things real and relevant. We have to all admit, we are approaching levels found by many sources harmful to our hearing and need to keep things in perspective. I plan on doing dual UM18 boxes this summer but, it will be a lateral move since I don't need more spl. It no longers matters what increase in db. that the project may net. I hope this is not coming off wrong. I am all for people making a better system but, caution extreme spl for regular use.
Pesonally, I would love to hear how the perception is at 160 db clean. I can do the upper 130s but, the room can't take it for to long. So, I'm near the limit without having to do some major mods.
post #97 of 321 Old 03-11-2017, 04:36 AM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
for sure, I don't go anywhere near those levels myself. Just remember it's not an arcade game, you don't need the highest score!
post #98 of 321 Old 03-11-2017, 04:46 AM
dominguez1's Avatar
Liked: 1112
3, have you done a comparison of your vibe psd compared to the vibsensor psd?
I'd love to see how they compare with each other.
post #99 of 321 Old 03-11-2017, 08:10 AM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
there is an example in this post, I'll repeat in more detail at some point.
seems like weighing down VS produces similar results <25-30Hz but IMV VS is not useful for >30Hz.
post #100 of 321 Old 03-11-2017, 01:29 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
got a basic normalisation function going, for example a simple x y z view
and then with the z axis selected as the reference (so it becomes a flat line)
it's a bit limited atm as it is done client side and relies on measurements being taken at the same sample rate (will expand that later)
next step is to allow target curves to be set then you will be able to pick a target curve and use that as the reference curve
ID:	2020089   Click image for larger version
post #101 of 321 Old 03-11-2017, 04:07 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
example showing the calculated summed response
and using the sum as the reference to indicate how each axis contributes to that sum (though perhaps this should show the x and y scaled accordingly)
ID:	2020337   Click image for larger version
post #102 of 321 Old 03-12-2017, 12:00 AM
awediophile's Avatar
Quoted: 295 Post(s)
Liked: 150
Are the accelerometers calibrated in terms of sensitivity? I assume you need that in order for us to compare measurements or discuss them on absolute terms.
awediophile is offline
post #103 of 321 Old 03-12-2017, 01:24 AM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
yes they are for sensitivity
there are register slots for sensor specific offsets that you can overwrite. This involves running a calibration routine (placing the device as close to perfectly level as possible, measuring the output over some period of time to calculate new offsets). I get the impression it's important if you're building a quadcopter but not so much for this purpose. I will add that to the app at some point though.
post #104 of 321 Old 03-13-2017, 01:52 PM
Quoted: 295 Post(s)
Liked: 150
I see. Thinking about it, gravity actually should make a good reference.
Also to your earlier concern about removing the affect of gravity from measurements. If your sensor is stable against rotations, then gravity should be very easy to ignore. It will just be a DC component in the measurement.
post #105 of 321 Old 03-13-2017, 02:44 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
yes that's what I'm doing atm
post #106 of 321 Old 03-14-2017, 04:56 PM
dominguez1's Avatar
Liked: 1112
That sum line is awesome! Brings a lot of insight that was hard to see before. For example, that dip in x, y, and z between 20 and 30hz, when summed, is actually flat.
The question is...does it subjectively feel 'flat' or a 'dip' in that range?
Also, how did you calculate the sum? I'd like to try in Excel...
post #107 of 321 Old 03-15-2017, 01:09 AM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
my perception of my setup is that it's pretty "smooth", i.e. it doesn't feel like any particular frequency is emphasised. So yes, the sum looks more like what I think I feel.
Note that the sum is for spectrum only, I don't believe it can be applied to PSD (or at least I've never seen PSDs summed anyway, only acceleration). It's just the root sum of the squares with an additional weighting factor for x & y as per some research doc I posted in one of the other threads.
Code:
# calculate the sum of the squares with an additional weighting for x and y
Psum = (((Pxx * 2.2) ** 2) + ((Pxy * 2.4) ** 2) + (Pxz ** 2)) ** 0.5
Note that ** 2 means squared and ** 0.5 means square root
post #108 of 321 Old 03-15-2017, 12:35 PM
dominguez1's Avatar
Liked: 1112
Code:
Cool...thanks for the equation.
I keep forgetting that this is not PSD, but acceleration.
I referenced this in this post in the ULF thread a while back, but here is some info on Peak Ground Acceleration and perception:
https://en.wikipedia.org/wiki/Peak_ground_acceleration
Do you see anything applicable in here that can make acceleration/vibration more relatable?
post #109 of 321 Old 03-15-2017, 02:08 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
We could probably calculate a value like that and see what we measure in our setups. I'm not sure how it relates though as the subjective assessment is based on the whole earth moving (NB: I have never been in an earthquake so no idea what it feels like, I find it hard to relate that to a home cinema setup though)
post #110 of 321 Old 03-23-2017, 01:11 AM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
switched to a different chart lib which is much faster to render & added the normalisation options (NB: build not published yet)
quick demo below
FriscoDTM likes this.
post #111 of 321 Old 03-27-2017, 02:26 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
added a time series view
Marc Alexander and FriscoDTM like this.
post #112 of 321 Old 03-29-2017, 03:01 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
added a simple target curve editor, need to hook this into the measurements for normalisation use next
post #113 of 321 Old 04-02-2017, 02:34 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
added the ability to use a wav as a target curve, example showing EoT
also faffed around for ages attempting to get a constant Q filter going but failed (well technically succeeded but it didn't achieve what I wanted so...)
post #114 of 321 Old 04-07-2017, 03:23 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
bought the target curve into the analysis screen so you can measure a scene and then normalise the measured response vs the on disk content. This is just some random measurement compared against EoT though.
post #115 of 321 Old 04-08-2017, 03:50 AM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
a better example, 2 sensors placed at different seats and using EoT as the test signal
usual vibsensor style view against time, suggests it is a bit noisy (wasn't especially careful with securing the sensor tbh) but seems sane
now looking at the frequency response, using the summed vibration to keep the graph simple & comparing the two seats. They look pretty similar except one seat falls away at the low end
pick one as the reference so we can really concentrate on the differences, now we can really see that one seat is feeling it much more than the other and this seat is the one that is closer to the sub. This suggests a need for more subs to produce a more even response across the area & also illustrates how quickly TR falls away as the sub gets further away.
next add the source track as a target curve (means get the track as a wav and drag it onto the target screen)
you can now add this to the analysis screen, for now you have to manually adjust the level so in this case I set it so the curves meet at the 30Hz tone. We can already see my room adds a random spike at ~40Hz that is non existent in the content and in fact this is my room mode so we can see how a room mode adds TR as well
(NB: the glitch over on the right appears to be some sort of rendering bug on chrome on linux, doesn't happen on windows)
finally set EoT as the reference series so we can see how we track the source, this makes it clear how much one seat is hotter than the other and the extent to which we're falling behind the curve.
ID:	2073857   Click image for larger version
ID:	2073865   Click image for larger version
ID:	2073873   Click image for larger version
ID:	2073881   Click image for larger version
post #116 of 321 Old 04-13-2017, 04:55 AM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
pushed a new release to https://github.com/3ll3d00d/vibe/releases/tag/0.3.1 containing all the above features
the windows exe is a bit big (200M) but my time > disk space I'm afraid
MrGrey likes this.
post #117 of 321 Old 05-01-2017, 02:38 PM
MrGrey's Avatar
Quoted: 1737 Post(s)
Liked: 6490
MrGrey is offline
post #118 of 321 Old 05-01-2017, 02:42 PM - Thread Starter
3ll3d00d's Avatar
Liked: 2699
Originally Posted by MrGrey View Post
I get this error on windows 10,
I should change that message, it's not an error Open your browser and go to http://localhost:8080, you want the target option (menu at the top)
post #119 of 321 Old 05-01-2017, 02:49 PM
MrGrey's Avatar
Liked: 6490
OK i got it working. thank you
MrGrey is offline
post #120 of 321 Old 05-01-2017, 02:52 PM
MrGrey's Avatar
Liked: 6490
o that sucks, i wish it could handle bigger files,
MrGrey is offline
