SKHorn - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 537Likes
post #301 of 773 Old 06-01-2017, 11:32 AM
lukeamdman's Avatar
Quoted: 1385 Post(s)
Liked: 2000
Two coats of Satin Poly in. There was a bit of water damage from the shipping, and @dsl1 didn't anticipate this enclosure being finished outside of duratex so I am going for the "Distressed" look. The wife says it's in style anyways, so I am working with it I actually like how it's turning out, minus the woodpatch that doesn't seem to like to take stain as nice as the last type I had.
Originally Posted by Ricci View Post
Drivers on the way?
Please tell me you're putting IPALs in that thing!
Scott Simonian likes this.
lukeamdman is offline
post #302 of 773 Old 06-01-2017, 11:33 AM
beastaudio's Avatar
Quoted: 5585 Post(s)
Liked: 5409
Originally Posted by Decadent_Spectre View Post
People have hardly ever done BPs on AVS, there tends to be a very narrow view on AVS as far as speakers and subs go. Outside of the "accepted standards" everything is treated as suspicious or as inferior where seemingly a measurement is all that matters. There are a wide array of options available out there in the pro world for 30Hz + options which are very loud if that is your criteria. As far as "sub" BPs go, my favorite is undoubtedly the B2. The JTR stuff is OK, far better choices exist than the OS Pro for 30-40Hz + IMO but perhaps none as cheap. Have fun!
What's a b2?
beastaudio is offline
post #303 of 773 Old 06-01-2017, 11:46 AM
beastaudio's Avatar
Liked: 5409
@Ricci seems to be a pretty serious fan of the new ds115, even over the sw152 AND it's cheaper. I dunno. I want to max this thing out and get ipals, but that's quite a bit more coin to say the least, not to mention a basic requirement for a SP amp.
post #304 of 773 Old 06-01-2017, 11:54 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5986 Post(s)
Liked: 5115
Yeah, no kidding.
At less than half the MSRP of the IPAL's, I wouldn't feel so bad about using the new 115's.... as long as they worked in the SKhorn, I mean.
Scott Simonian is offline
post #305 of 773 Old 06-01-2017, 12:03 PM
beastaudio's Avatar
Liked: 5409
Yeah, no kidding.
They are on the list that Josh posted of recommended drivers. More efficient, more usable xmax than the 152, and a better pricetag. I'd leave a dB or two on the table not using the iPals, but why would I ever need them?!?!?
post #306 of 773 Old 06-01-2017, 12:12 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 904
Ricci have you considered a V2 that has the ports redesigned for the single port option only? Or two port? Seems like that's the way most home users would use it, so why not make the lesser ports larger?
Samps is offline
post #307 of 773 Old 06-01-2017, 12:25 PM
gpmbc's Avatar
Quoted: 379 Post(s)
Liked: 260
Regarding the B&C 21ds115, is LE considered high if venturing into midbass use? It seems all specs went up a notch other than that.
gpmbc is online now
post #308 of 773 Old 06-01-2017, 12:29 PM
lukeamdman's Avatar
Liked: 2000
"need" is a difficult word to use for any hobby
post #309 of 773 Old 06-01-2017, 01:46 PM
Bass Enabler
Liked: 5115
The SKhorn was not designed for home use.
post #310 of 773 Old 06-01-2017, 01:49 PM
Bass Enabler
Liked: 5115
I'd like to think so!
Yeah, the numbers did go up a lil bit but that's in comparison to the 152. Doesn't seem abnormally high or anything. These were designed to do bass. I'm sure they excel in midbass.
post #311 of 773 Old 06-01-2017, 01:55 PM
Samps's Avatar
Liked: 904
I'm not suggesting a replacement, just an option.
If you know going in that it will only be used in your basement, might as well use up the available port area as best you can.
Samps is offline
post #312 of 773 Old 06-01-2017, 02:11 PM
Bass Enabler
Liked: 5115
I guess it was just another way of saying, "It was designed for a specific purpose for a specific person. Just happened to be shared to the public. Don't get your hopes up for a re-design based off your parameters."
This is the DIY section. Where you do your OWN dirty work.
post #313 of 773 Old 06-01-2017, 02:12 PM
Ricci's Avatar
Quoted: 389 Post(s)
Liked: 909
Id say the Ipals might give you that last 3dB over the 115 but it is a big investment for that last little bit. I do it but Im crazy or perhaps stupid.How often will you need that last 3dB...
Dont forget that the port has to get a lot longer with the extra area too. There's not much space to do that in the current one. Really itd be best to make the vented volume larger and make the ports bigger for the lower tune but them its turning into a proper fridge of a sub.
Ricci is offline
post #314 of 773 Old 06-01-2017, 08:40 PM
Decadent_Spectre's Avatar
Quoted: 381 Post(s)
Liked: 182
What's a b2?
d&b B2.
It isn't for most people here as it doesn't get low.
Decadent_Spectre is offline
post #315 of 773 Old 06-01-2017, 09:34 PM
LTD02's Avatar
Quoted: 2950 Post(s)
Liked: 3678
specs:
2 x 18" ported horn; power handling 600w rms.
http://www.dbaudio.com/en/systems/ca...ocumentation-4
response:
guts:
without equalization, that short horn path is going to put a big spike in the response (and efficiency) in the ~110hz ballpark, which appears to be why ds likes it, apparently.
rough model.
displacement:
efficiency:
sub has cone motion displacement dip at ~110hz and efficiency from ~110 to ~150 is greater than 25%, both of which would reduce distortion.
looks like one heck of an mbm.
Name:	D and B B2 subwoofer.png
ID:	2167234   Click image for larger version
Name:	D and B B2 subwoofer - response.png
ID:	2167242   Click image for larger version
ID:	2167274   Click image for larger version
Listen. It's All Good.
LTD02 is offline
post #316 of 773 Old 06-01-2017, 10:23 PM
chrapladm's Avatar
Quoted: 1110 Post(s)
Liked: 448
Well I would have bought DS115's for my future Skhorn had I known they were coming out. Instead I will be building mine with SW152's.
Beast I didnt know you had that much room under your center channel for a Skhorn. Wow. Should be awesome.
chrapladm is offline
post #317 of 773 Old 06-02-2017, 06:43 AM
beastaudio's Avatar
Liked: 5409
The skhorn may not have been designed for home use, but it DOES fit in a home...so......
I won't be running it all ports open so the top ports which will be plugged are going to be behind the screen still. I'll flip the center to fit on top of it with a stand that should align the horns pretty closely with the left and right speakers. This at least is the initial plan. Lord knows I'll likely change it up at least a dozen times. Going to finally get the danleys out from behind the screen and spruce everything up real nicely.
chrapladm and eng-399 like this.
post #318 of 773 Old 06-02-2017, 07:57 AM
Quoted: 381 Post(s)
Liked: 182
specs:
response:
guts:
rough model.
displacement:
efficiency:
Your making an assumption here about me liking it and why, I said it's my favorite BP, that's all. I do not want one for my own use as it doesn't meet my criteria, I chose not to buy it when I was looking some years ago. BP isn't my thing. Also that internal pic, is that from one the DIY copies? Got a link to thread? People here will likely like the Martin ASX or Void Incubus Sub more is my guess.
Also MBM? Et tu? Lol Clearly a sub IMO.
post #319 of 773 Old 06-02-2017, 08:24 AM
Bass Enabler
Liked: 5115
...but it DOES fit in a home...so......
Yup!
wlhungdude likes this.
post #320 of 773 Old 06-02-2017, 11:14 AM
LTD02's Avatar
Liked: 3678
Your making an assumption here about me liking it and why, I said it's my favorite BP, that's all...
iirc, you like a big spike in the 100-125hz ballpark for tacileness, and that sub does it naturally in frequency response and efficiency, so that doesn't seem like a bad guess as to why you might like it. if you have a different theory, kick it out there.
anyway, the pic was from a random google image search. it seemed to look like some of the other b2 cab drawings--one had measurements but wasn't as clear as to the form factor for beast's question of what is a b2 (i was kind of curious too). the hornresp are just my quickies based on guesstimates of the parameters...just to get a rough idea of the b2's performance.
looks like art welter has/had one.
https://soundforums.net/forum/pro-au...5737#post75737
Name:	D and B B2 subwoofer guts 2.png
LTD02 is offline
post #321 of 773 Old 06-02-2017, 12:40 PM
Quoted: 381 Post(s)
Liked: 182
No I do not like a peak in the 100-125Hz range. It is my favorite BP because the processed response is what you would expect out of a BP and because it doesn't go too low, also my opinions are based more on my own hearing experiences or what I hear from people I trust rather than measurements. Whether it has a peak/dip/X distortion etc is irrelevant to me as far as my purchasing decisions go if I have heard it or if some one I trust has recommended it for my tastes. That said if you find it relevant I find that using a bandpass filter on a flat sub response can create an interestingly unique sound and if done right can sound good, to me anyway. So YMMV.
post #322 of 773 Old 06-02-2017, 05:01 PM
wlhungdude's Avatar
Quoted: 212 Post(s)
Liked: 269
Going to finally get the danleys out from behind the screen....
'bout damn time you moved on from those Danleys....
Waiting for you to sell ***** takes a lot out of a brother...
I hear those JBL M2's are even better....
Bro-seph
beastaudio likes this.
mods, can we have a 'dislike' button ?
wlhungdude is online now
post #323 of 773 Old 06-03-2017, 02:32 AM
LTD02's Avatar
Liked: 3678
roger.
LTD02 is offline
post #324 of 773 Old 06-06-2017, 07:10 PM - Thread Starter
dsl1's Avatar
Quoted: 201 Post(s)
Liked: 417
Get your drivers?
________________________________________
DIY Mid Hi Speakers Build - SKHorn Build - Gjallarhorn Build SOLD - Othorn Build SOLD - SEOS 12 Build - Other Gear: JVC NX5 - Seymour Matinee Black - QSC CX4.5Q amps x 5 - QSC Q-sys 110f - Speakerpower 6000 x2
dsl1 is offline
post #325 of 773 Old 06-07-2017, 07:48 AM
beastaudio's Avatar
Liked: 5409
Originally Posted by dsl1 View Post
Get your drivers?
Slated for delivery tomorrow.
post #326 of 773 Old 06-07-2017, 08:13 AM
Ricci's Avatar
Quoted: 389 Post(s)
Liked: 909
4 or 8 ohm?
Ricci is offline
post #327 of 773 Old 06-07-2017, 09:03 AM
beastaudio's Avatar
Liked: 5409
4 or 8 ohm?
4's
post #328 of 773 Old 06-07-2017, 09:47 AM - Thread Starter
dsl1's Avatar
Quoted: 201 Post(s)
Liked: 417
4's
DS115 or SW152?
dsl1 is offline
post #329 of 773 Old 06-07-2017, 10:07 AM
beastaudio's Avatar
Liked: 5409
DS115 or SW152?
ds115's seemed the hands down best choice outside of the prolific ipals. Now I just need to get the dang ports cut and toss some stuffin' in there. @Ricci , where did you source that stuff you got for yours? I was just going to go with rockwool batts...
eng-399 likes this.
post #330 of 773 Old 06-07-2017, 12:12 PM
Ricci's Avatar
Quoted: 389 Post(s)
Liked: 909
Ebay. Memory foam chunks.Jammed them in behind the wood port blocks.Little weather stripping for good measure.
Ricci is offline
bass , skhorn , subwoofer
