Titan-615 General Discussion Thread - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 879Likes
post #931 of 975 Old 03-30-2019, 08:36 PM
mtg90's Avatar
Quoted: 903 Post(s)
Liked: 1740
Erich usually measures all the compression drivers before shipping them out. The other two probably lined up better (stereo matched pair) so he marked that third one for center channel. In reality you could probably mix them up and never hear the difference.
mtg90 is offline
post #932 of 975 Old 04-21-2019, 06:40 PM
kgveteran's Avatar
Quoted: 966 Post(s)
Liked: 280
Is there a sweet spot as to distance from this speaker, to the LP ? I dont know if i even worded that correctly :0/
My distance is roughly 12’, the mains sit behind a AT screen, wouldnt toeing them in create a gap (R&L) between speaker and screen, something that should be avoided ?
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is online now
post #933 of 975 Old 07-05-2019, 05:05 AM
windshear's Avatar
Quoted: 82 Post(s)
Liked: 34
Does anyone know when these will be available again? Im not getting any reply via email from Erich.
Classe CA2300 CA5300 CA2100
Classe CP800 "2.6". Marantz AV8805 "7.6.4"
B&W 2x800Di HTM1D 4xSCMS 4xCCM7.4
2x Dual Opposed DIY HST18's
2x Triangular DIY UM18-22's
windshear is offline
post #934 of 975 Old 07-05-2019, 08:23 AM
markg35's Avatar
Quoted: 365 Post(s)
Liked: 291
Erich is very good about getting back to you.He might be on holiday.
markg35 is offline
post #935 of 975 Old 07-05-2019, 12:00 PM
Erich H's Avatar
Quoted: 1945 Post(s)
Liked: 2820
Or the reply went to the spam folder.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #936 of 975 Old 07-05-2019, 01:44 PM
windshear's Avatar
Quoted: 82 Post(s)
Liked: 34
No , I check that daily.
post #937 of 975 Old 07-06-2019, 01:23 PM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
Hopefully they will be back in stock soon. They've been out of stock for 4-5 months. He was waiting on woofers back in April. Hopefully those came in.
Sent from my SM-G950U using Tapatalk
Jedi940 is offline
post #938 of 975 Old 07-06-2019, 02:10 PM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
Fyi, they just went back in stock
Jedi940 is offline
post #939 of 975 Old 07-06-2019, 05:33 PM
Erich H's Avatar
Liked: 2820
I'm not sure they were out of stock quite that long. Maybe 2.5 months or so. The problem is that the Titan 15" woofer uses some custom stuff that adds a few extra weeks to the manufacturing. The hemp coned 8" woofers used in the Fusion-8 were the same way.
I don't put all of them in stock that are here because if too many orders come in I'd get behind. That's pretty much how it is with all of the bigger kits that take a lot of time to package up. I usually put about 10 of something in stock but it's difficult to track inventory for everything. Sometimes I don't even realize the site only shows 0 or 1 until someone contacts me.....then I put more on the site if they're here.
The problem is that the shopping cart software will subtract inventory when an order is placed, but if the person changes their mind and cancels the order the site doesn't put those back in stock. And boy do us DIY guys love changing our minds on speaker models!
imrf, Jedi940, fill35U and 1 others like this.
Erich H is offline
post #940 of 975 Old 12-06-2019, 09:10 PM
Quoted: 259 Post(s)
Liked: 255
@Erich H - Any update on the Titan being back in stock?
Sources/processing: stack of stuff that if it isn't vintage now, it will be soon!
Amps: stacks and stacks of old iron
Main speakers: big DIYSG
Surrounds: Bose graveyard
Subs: a bunch
fill35U is offline
post #941 of 975 Old 12-06-2019, 09:46 PM
Erich H's Avatar
Liked: 2820
Which one?
Erich H is offline
post #942 of 975 Old 12-07-2019, 05:39 AM
Quoted: 259 Post(s)
Liked: 255
Which one?
The Titan-615LX basic kit with drivers, waveguide, XO, ports...
Subs: a bunch
fill35U is offline
post #943 of 975 Old 12-14-2019, 12:53 AM
Iccy's Avatar
Quoted: 45 Post(s)
Liked: 34
Anyone in the Des Moine or Ceder Rapids area have a set of Titan LX?
Iccy is offline
post #944 of 975 Old 02-03-2020, 10:23 AM
kgveteran's Avatar
Quoted: 966 Post(s)
Liked: 280
Originally Posted by mtg90 View Post
Originally Posted by Fattykidd View Post
We need pics..
Sorry for bare MDF box, it would have looked cooler painted but I have not done that yet.
Hey! Can you give a little comparison to the JBL2226/SEOS12 you built a ways back
post #945 of 975 Old 04-03-2020, 08:34 AM
dlinsley's Avatar
Quoted: 706 Post(s)
Liked: 564
@mtg90 what power rating do we need to use for the 25-27 Ohm resistor across HF? I can get 10W 27 Ohm locally, so was thinking of trying this experiment. I've recently found that using tilt in ARC Genesis to provide a 2dB down slope is preferable in my system, so this tweak seems appropriate to play with.
I only just discovered these crossover mods, and so I'm also going to experiment with removing the 33 Ohm for the mid-range. Hoping to improve the snap of tom drum heads - the one thing I miss from the PSA MTM210 I replaced.
dlinsley is offline
post #946 of 975 Old 04-03-2020, 09:14 AM
mtg90's Avatar
Quoted: 903 Post(s)
Liked: 1740
10w is perfectly fine, could likely get away even with a 5w resistor there.
dlinsley likes this.
mtg90 is offline
post #947 of 975 Old 04-03-2020, 01:26 PM
dlinsley's Avatar
Quoted: 706 Post(s)
Liked: 564
Thanks! 99c for 5W or $1.05 for 10W
dlinsley is offline
post #948 of 975 Old 05-01-2020, 04:27 AM
Vince_B's Avatar
Quoted: 347 Post(s)
Liked: 246
Edit, just realized I could go with a bigger screen closer to the floor and possibly have more options. Started out just hanging the old screen, but then titans happened, and so forth as you know how it goes.
Hey guys quick question on arranging titan center behind an at screen. If I stand up the titan it will have the lower screen frame in front of the woofer. Alternately I can arrange the titan woofer beside the upper frequency drivers as shown in my bad paint renderings The subs were built for my previous space so were meant to be horizontal to avoid rocking etc, so that is one point in favor of option 1. I don't have to put both subs behind the screen, so I can do option 1 and just have one sub horizontal and move the other sub or place at the back of the room etc.
This won't be set in stone, it's sort of a phase 1 setup, so with that in mind, what would you do?
Name:	front stage mockup 2.jpg
ID:	2719286   Click image for larger version
Name:	front stage mockup.jpg
Vince_B is online now
post #949 of 975 Old 05-01-2020, 09:35 AM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
I would go with the second option and stand it up. I believe the crossover on the woofer is 300Hz which is still plenty large enough to bypass the frame of the screen. The frame shouldn't be more than a couple inches in width.
Jk7.2 likes this.
Jedi940 is offline
post #950 of 975 Old 05-01-2020, 09:37 AM
Jk7.2's Avatar
Quoted: 1847 Post(s)
Liked: 3382
I second that.
Jk7.2 is offline
post #951 of 975 Old 05-01-2020, 09:53 AM
BBLV's Avatar
Quoted: 125 Post(s)
Liked: 166
Just finished two of my three Titan "630LX" kits earlier this week. More pics in my build thread, but thought I'd share the finished pics here. These things ROCK!
Also included an REW measurement of the pair in my room (screenwall is fully treated, but not the rest of the room yet). A few dips I'm trying to EQ out, but can't get REW to add boost - I'm a total REW noob, so if you have any tips let me know.
Name:	IMG_0713 (30%).JPG
ID:	2719412   Click image for larger version
Name:	IMG_0711 (30%).JPG
ID:	2719414   Click image for larger version
Name:	IMG_0712 (30%).JPG
ID:	2719416   Click image for larger version
Name:	IMG_0673 (30%).JPG
ID:	2719418   Click image for larger version
Name:	IMG_0589 (30%).JPG
Name:	Titan 630LX 1st Stereo REW Measurement.jpg
BBLV is offline
post #952 of 975 Old 05-01-2020, 02:52 PM
ricren's Avatar
Quoted: 24 Post(s)
Originally Posted by BBLV View Post
Just finished two of my three Titan "630LX" kits.
Very nice build. I like the reiforcement.
ricren is offline
post #953 of 975 Old 05-01-2020, 03:03 PM - Thread Starter
eng-399's Avatar
Quoted: 2476 Post(s)
Liked: 5162
They look awesome!!!
BBLV likes this.
eng-399 is online now
post #954 of 975 Old 05-01-2020, 03:43 PM
Vince_B's Avatar
Quoted: 347 Post(s)
Liked: 246
Thanks for the input guys, I was thinking it was higher crossover but after you said that looked it up, 350 is what they published. The screen is a diy spandex so the frame is 3.5” wide, I’m going to build a 110” screen and make the bottom frame thinner and set it lower. No second row so it can be down low. And nice side benefit of a little bigger screen.
Those 630 look awesome, nice build and bracing. I’ve got the 615 sanded and ready for finish. Been working constantly so I parked some other speakers up here to enjoy a movie in the morning.
post #955 of 975 Old 05-30-2020, 10:15 AM
JMAX2016's Avatar
Quoted: 161 Post(s)
Liked: 38
Guys,
I'm really considering pulling the trigger on Titan 818's. Any suggestions or comments?
From what I can see, the 615LX has been getting great reviews. Clarity, dynamics, large sound (and loud, but I'm talking sounding large), etc.
I've never owned a speaker like this. I own Goldenear Triton 1's which I really like, but I'd like to try something different.
I listen from 11' away from a 137" wide screen, running 4 - 18" ported ultimax's in 16 cu ft net enclosures.
So any comments or suggestions would be appreciated.
Yamaha Aventage 3060, 7.2.4
Goldenear Triton 1's, Supercenter XXL, 4-MPX, 4-652
4-18" Ultimax's - 16 cu ft ported, 2 - Behringer NX6000's
JVC RS500 Pro, Panasonic DP-UB820 UHD Blu-Ray Player
137" wide 16:9 V6 AT Screen
JMAX2016 is offline
post #956 of 975 Old 05-30-2020, 10:26 AM
gpmbc's Avatar
Quoted: 458 Post(s)
Liked: 370
Wow you killed it, those look great!
BBLV likes this.
gpmbc is offline
post #957 of 975 Old 05-30-2020, 06:17 PM
Vince_B's Avatar
Quoted: 347 Post(s)
Liked: 246
Originally Posted by JMAX2016 View Post
Guys,
Do it. Finally got three titan 615 finished and in place. Took a pound of patience to wait until they were finished but they are up three flights of stairs from the basement and I don’t have time to drag them back down for finishing. Only a couple of hours of listening but we put on HB2 golden army and with the htm10 as surrounds, wow. Mains and center at 40hz and one hs24 on an inuke, no room correction. The kid said this is what movie theater should sound like. Very capable speaker and really like the two piece design. They will reveal the quality of a recording, listened to Weezer sacd and it has its moments but the titans aren’t forgiving. Metallica black album was much better. The room has minimal treatments also.
Did a dye black and blue finish, the faster version, not completely silky smooth but close and they’re in a blacked out room. Epic speakers. They look better if you paint the woofers edges black. Silver screws and speaker trims stand out and don’t look as good as black.
NotShorty, femi, BBLV and 1 others like this.
post #958 of 975 Old 05-31-2020, 11:01 AM
Quoted: 243 Post(s)
Liked: 159
What did you paint the woofer edges with?
bochoss is offline
post #959 of 975 Old 05-31-2020, 04:25 PM
Vince_B's Avatar
Quoted: 347 Post(s)
Liked: 246
Rustoleum oil base. They sell a tiny can of it. Some disposable fine brushes would be helpful
NotShorty and bochoss like this.
post #960 of 975 Old 05-31-2020, 10:45 PM
JMAX2016's Avatar
Quoted: 161 Post(s)
Liked: 38
[QUOTE=Vince_B;59733370]They look better if you paint the woofers edges black. Silver screws and speaker trims stand out and don’t look as good as black.
I think I'm going to... I've actually never owned Home Theater speakers before. Only Hi-fi speakers. What will I hear that's different compared to the hi-fi speaker's?
Also on the woofer cones, did you spray paint the whole woofer and the surrounds for the woofer?
JMAX2016 is offline
