How do i make a 3.5cubic sub box act like a 10 cubic - AVS Forum | Home Theater Discussions And Reviews
 26Likes
  • 4 Post By Roadrune
  • 5 Post By Bill Fitzmaurice
  • 1 Post By uniquepattern
  • 1 Post By Raylon
  • 2 Post By EndersShadow
  • 6 Post By Bigus
  • 1 Post By Bill Fitzmaurice
  • 1 Post By Scott Simonian
  • 3 Post By Augerhandle
post #1 of 18 Old 02-14-2017, 11:47 PM - Thread Starter
John O'Connell's Avatar
Liked: 0
I READ HOW POLYFIL MAKES A SMALLER SUBBOX ACT LIKE A BIGGER BOX
I JUST DONT NO HOW MUCH TO ADD IM PLANING TO USE
Fairfield Poly-Fil Traditional White Quilt Batting, Crib Size, 45-Inch by 60-Inch FROM AMAZON IN TWO 3.5 CUBIC FOOT SUB BOXS WITH 1INCH THICK WALLS
AN TWO Rockford Fosgate Punch P1S2-15 SUBS AND ONE Dayton Audio RSS390-PR 15" Aluminum Cone Passive Radiator SET FOR 15.5HZ PER BOX I PLAN TO GIVE EACH SET 750WATTS
AT 4OHMS MY HOME THEATHER
SO HOW much acoustic treatment do i need TO MAKE A 3.5CUBIC SUB BOX ACT LIKE A 10 CUBIC SUB BOX?
John O'Connell is offline
post #2 of 18 Old 02-15-2017, 12:00 AM
Quoted: 17 Post(s)
Its really easy, just build it like a 10 cuft
7.1.4
DIY ER18MTM, DIY custom Overnight Sensation, DIY LilWrecker DIY Hypex poweramps, Denon AVR X6200W, Cambridge Audio Azur 751BD
https://www.avsforum.com/forum/155-di...und-atmos.html
Roadrune is offline
post #3 of 18 Old 02-15-2017, 12:08 AM
goonstopher's Avatar
Quoted: 333 Post(s)
Liked: 70
I thought this was going to be a rant about people (I've been guilty) looking for more performance than their space will allow ha
goonstopher is online now
post #4 of 18 Old 02-15-2017, 05:46 AM
Bill Fitzmaurice's Avatar
Liked: 5767
If that's what you read it was incorrect. Stuffing a box will lower the Q, which in some ways is similar to what happens with a larger box, but it's only similar, not the same. Model the effect yourself in WinISD. In 'box' mode open the 'advanced' tab, change the Qa from the default 100 (no damping) to 10 for fully filled, 5 for stuffed and compressed.
No amount will do that. Also, stuffing is used only in sealed cabs, not ported or PR.
Bill Fitzmaurice is offline
post #5 of 18 Old 02-15-2017, 06:25 AM
uniquepattern's Avatar
Quoted: 807 Post(s)
Liked: 857
How to make a 3.5ft3 box into 10ft3....
Bend the theories of physics.... and if ya figure out how to do that, let me know.... Id love to figure out how to stuff 30ft3 of volume into a 5ft3 space...
Rowan611 likes this.
uniquepattern is offline
post #6 of 18 Old 02-15-2017, 06:29 AM
Raylon's Avatar
Quoted: 441 Post(s)
Liked: 578
Didn't know that's how you did that. I will remember that! I've tried it on multiple box designs and so far I've found no boxes like being stuffed
kaiforce likes this.
Raylon is offline
post #7 of 18 Old 02-15-2017, 07:09 AM
EndersShadow's Avatar
Quoted: 1167 Post(s)
Liked: 1429
Add a TON of power, and a really nice shelf filter and make sure your driver can handle the wattage without blowing*
*its not "just" that simple but using a shelf filter can help change the F3 of a sealed driver, which is what I'm assuming we are talking about.
Brazle and fill35U like this.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #8 of 18 Old 02-15-2017, 07:33 AM
Bigus's Avatar
Quoted: 577 Post(s)
Liked: 535
Just connect each box to an additional 7 cu ft box in a closet or garage via Einstein-Rosen bridge. Audioquest or MonsterCable probably carry them.
Bigus is offline
post #9 of 18 Old 02-15-2017, 08:13 AM
Liked: 5767
A filter will lower the system response but it won't add the necessary driver excursion to make use of it. No matter how you try you can't fit 50 pounds of potatoes into a 20 pound capacity bag.
derrickdj1 likes this.
post #10 of 18 Old 02-15-2017, 09:27 AM
asarose247's Avatar
Quoted: 1177 Post(s)
Liked: 1041
that "sound of a sack of potatoes" reference is about the obscure and now forgotten first iteration of the bose bass module,
called the "Blivet Sub"
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #11 of 18 Old 02-15-2017, 11:23 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5985 Post(s)
Liked: 5114
Wow. I can't believe nobody mentioned to do an isobaric system?
Obviously he listed what he has but...
You can make a 3.5cuft APPEAR as a 7cuft box if you mounted the two drivers in a clamshell.
It's not the most efficient or cost effective practice but it WILL make a 3.5cuft enclosure appear as one double it's size. It's the only real way. Stuffing will do jack.
fill35U likes this.
Scott Simonian is offline
post #12 of 18 Old 02-15-2017, 11:41 AM
Steve Hanna's Avatar
Quoted: 170 Post(s)
Liked: 101
Nothing can triple the volume of your enclosure except to build a bigger one. The physical size difference between a 3.5 and a 10 isn't as much as you think.
Steve Hanna is offline
post #13 of 18 Old 02-15-2017, 12:22 PM
Liked: 5767
I never mention an isobaric because I don't see the sense in paying for two drivers but only getting the maximum SPL of one.
ZLTFUL likes this.
post #14 of 18 Old 02-15-2017, 03:33 PM
Bass Enabler
Liked: 5114
Yeah, no kidding. That wasn't the point though. I wasn't trying to save him money or gain SPL.
He wanted to know how to make an enclosure larger than it really is (to the driver) and I gave him the answer.
michael hurd likes this.
post #15 of 18 Old 02-15-2017, 05:27 PM
Quoted: 1248 Post(s)
Liked: 1934
I got this!
Calculate your 3.5 cubic foot box measurements in centimeters.
Take those measurements and use inches instead
3.5 X 2.54 = 8.89 cubic feet
Then throw a kilogram of fill in per "cubic foot" and you'll be really close!
I had a girlfriend tell me I'm proof you can pack 500 pounds of dookie into a 160 pound package--won't work with subs though.
About 7 years ago I built a sub with isobaric 15's to get deeper response and it did work. Of course, I already had a pair of 15's laying around and used a passive radiator to save on the 3.3 cubic foot enclosure. It does work but--I would not suggest it unless you absolutely have no other choice. The clamshell isobaric with the magnet sticking out really impressed my wife with the Mad Max look.
18Hurts is offline
post #16 of 18 Old 02-15-2017, 05:52 PM
Bill Shenefelt's Avatar
Quoted: 170 Post(s)
Liked: 80
Remember, the box volume is internal volume minus speaker volume minus port volume minus bracing volume. The speaker volume is the same in either box. Assuming 3/4 inch thick walls you need to add 1.5 inches to either a 3.5 or a 10 cubic ft box. The cube root of 3.5 is about 18 1/4 (plus 1 1/2 for wall thickness)= 19 3/4 The cube root of 10 is about 25 1/4 (plus 1 1/2 inches thickness or 26 3/4.
For a cube, you are talking about adding approximately 7 inches to each side dimension to go from 3.5 cu ft to 10 cu ft. Maybe for a sealed box with wool stuffing you can get that down to 6 inches a side.
Bill Shenefelt; JBL 4343 monitors on Audire and Crown 1502 amps. 2 SVS 16 SB subs. 8 cu ft ported enclosure with 18 inch jbl driver on a Crown 1002 XTi amp (below 30 cps cut via eq), 4 Klipsch in-ceiling atmos. Anthem MRX 1120 receiver. Accuphase C-200, PS P600, Sony 4k projector and tv, SOTA Saphire turntable and Oppo 205 disk player .
Bill Shenefelt is offline
post #17 of 18 Old 02-15-2017, 08:47 PM
Augerhandle's Avatar
Quoted: 1128 Post(s)
Liked: 1126
Use something like this:
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #18 of 18 Old 02-15-2017, 09:39 PM
Shadowed's Avatar
Quoted: 935 Post(s)
Liked: 902
Wow,.... its bigger on the inside!
Shadowed is offline
