DIYSG Titan-615LX Build Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 166Likes
post #91 of 195 Old 03-01-2017, 09:27 AM - Thread Starter
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 669
Originally Posted by erwinfrombelgium View Post
Without subs, correct?
Denovo 15 subs. One in each Titan cab. No subs otherwise though.
VicTorious1 is offline
post #92 of 195 Old 03-01-2017, 09:30 AM
gixerking's Avatar
Quoted: 294 Post(s)
Liked: 476
Denovo sub?
gixerking is offline
post #93 of 195 Old 03-01-2017, 09:33 AM - Thread Starter
Quoted: 580 Post(s)
Liked: 669
Originally Posted by gixerking View Post
Denovo sub?
The driver in the Titan 615LX is the Eminence made "Denovo 15". So no subs with the measurement. I was just joking that those drivers in the Titan cab are subs.
filtor1 and hd0823 like this.
post #94 of 195 Old 03-01-2017, 10:03 AM
gixerking's Avatar
Quoted: 294 Post(s)
Liked: 476
I see, just knew it to be eminence deltalite. Didn't know it was called a denovo
post #95 of 195 Old 03-01-2017, 10:52 AM
Erich H's Avatar
Quoted: 1927 Post(s)
Liked: 2793
Regular Deltalites are used in the Fusion-15 and HTM's., not the Titans. Titan woofers use the motor and cones from the Kappalites.
filtor1, gixerking and 18Hurts like this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #96 of 195 Old 03-01-2017, 01:36 PM
filtor1's Avatar
Quoted: 266 Post(s)
Liked: 243
Denovo 15
I didn't hear any noise in that video. Did it show any signs of stress?
filtor1 is offline
post #97 of 195 Old 03-03-2017, 08:55 PM
dlinsley's Avatar
Quoted: 622 Post(s)
Liked: 481
What are the 4 clamps at each corner for, that only appear to be holding the sides and nothing else? Are they angled a little to hit the top/bottom too, or just a gratuitous clamp shot?
I know you can never have enough clamps, but I need to know the minimum for a box at a time
dlinsley is offline
post #98 of 195 Old 03-04-2017, 03:57 AM - Thread Starter
Quoted: 580 Post(s)
Liked: 669
Ha. Not just a gratuitous clamp shot. Some of the Baltic birch pieces, while perfectly sized/cut, weren't perfectly flat, as is to be expected with plywood. So the top and bottom pieces tended to move slightly with a clamp putting pressure down the middle. The four clamps that are at the corners assured that the corners would remain straight and the joints wouldn't move while pressure is being applied down the center with the long clamp running down the middle from top to bottom, if that makes sense.
dlinsley likes this.
post #99 of 195 Old 03-04-2017, 07:29 AM
Quoted: 1332 Post(s)
Liked: 2258
Questions about the Denovo 15
Could a sub be made with that 15 and tuned to 20Hz--along the lines of the VBSS Dayton PA460? I'm fully aware it won't be flat to 20Hz...or even 30Hz but a good option for a midbass monster that still can be "flat" with DEQ? If it could do a maximum of 110dB at 20 to 25Hz before hitting the dynamic limiter, all is well.
Any chance those 15's will be a MBM option? Maybe spill the beans on the Xmax, Fs, VAS and other T/S goodies to see if it would be a good option VS the PA460?
Just wondering... this year I build subs and am looking at various options.
18Hurts is offline
post #100 of 195 Old 03-04-2017, 08:52 AM - Thread Starter
Quoted: 580 Post(s)
Liked: 669
It's over twice the price of the PA460, has more xmax I believe (based on my comparison to my PA460s) and should be able to be flat down to 30hz (at least based on my in room response even lower), especially with DEQ. It'd definitely be a more than capable MBM, but it's not a cheap driver. It's around $200 if I'm not mistaken.
post #101 of 195 Old 03-04-2017, 02:17 PM
Liked: 2258
Thanks for the information,
I figure the 15 will move at least as much air as the PA460 and be close to the same efficiency but I can use a narrower cabinet. Have a buddy finishing up his HT build and needs two subwoofers but along his entire front wall, he only has 18" max space which a PA460 does not fit. My pondering is two of the Denovo 15's would do about what PA460's do (more Xmax to make up for Sd) and it can be squeezed into tighter spaces.
Would I be wrong to assume the Xmax is over 12mm and the Fs is below 30Hz? Then again, if they are unobtanium drivers in the raw--does not matter much. Thanks for the info!
18Hurts is offline
post #102 of 195 Old 03-04-2017, 03:37 PM - Thread Starter
Quoted: 580 Post(s)
Liked: 669
Since I don't want to destroy my Titan LF drivers to measure the length of the voice coil and the height of the magnetic gap, I won't speculate on the actual xmax. I also don't have a ruler that's precise to 1/10th of millimeter. I'd be surprised if the Fs is much higher than 30 Hz though.
18Hurts likes this.
post #103 of 195 Old 03-04-2017, 05:49 PM
gworrel's Avatar
Quoted: 468 Post(s)
Liked: 426
Erich said that the driver uses the same motor and cone as the Kappalite 3015LF which has an xmax of 10.65mm and an xlim of 17mm. If the motor and the cone are the same then I'm not sure what that leaves that is different, the surround? Perhaps to squeeze a bit more xmax out of the design.
RobertChicken likes this.
gworrel is offline
post #104 of 195 Old 03-04-2017, 07:33 PM
Liked: 2258
Checked the stats on the 3015LF, it states an Fs of 44Hz which is rather high for a 15--I guess I'll have to wait for Erich to spill the beans. Figure the Denovo version could have a different spider and suspension to allow more Xmax but pure speculation on my part.
18Hurts is offline
post #105 of 195 Old 03-04-2017, 07:53 PM
Erich H's Avatar
Liked: 2793
I believe all Kappalites (10" - 15") use the same magnet/motor, but there's a lot they can change to alter the end product. Spider, surround, dust cap, BL, magic dust, etc, etc. For example there are four different 10" Kappalites from high powered midrange to subwoofer by changing some parts.
Erich H is offline
post #106 of 195 Old 03-11-2017, 04:50 PM - Thread Starter
Quoted: 580 Post(s)
Liked: 669
So I finally got around to connecting my XPA-3 to the Titans and I definitely recommend adding power to the Titans above and beyond just the AVR. They were fine on the AVR but I definitely noticed my receiver clipping sometimes at higher db. I know there's not really a need to hit 130db, but these easily and cleanly hit 130db in my room with all speakers driven and just two driven.
eng-399 likes this.
post #107 of 195 Old 03-11-2017, 05:05 PM
eng-399's Avatar
Quoted: 2460 Post(s)
Liked: 5125
I'm on the hunt for a good 3 channel amp for these now after reading your post. Sounds like they had no problems when you turned them up.
eng-399 is offline
post #108 of 195 Old 03-11-2017, 06:06 PM
OJ Bartley's Avatar
Quoted: 592 Post(s)
Liked: 701
I'm just going to put this here...
http://www.marklevinson.com/productd...ct/no533h.html
http://www.parasound.com/a31.php
http://www.mcintoshlabs.com/us/Produ...roductId=MC303
I've seen this recommended but don't know anything about it... http://www.d-sonic.net/products/3-channel-amplifiers/
Just a few ideas, I'm amp shopping vicariously through you. I think I'd look closely at the McIntosh, what a cool piece.
If you really want big power, 3 monoblocks is probably the best way to accomplish that.
Sent from my LG-H812 using Tapatalk
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is offline
post #109 of 195 Old 03-11-2017, 06:46 PM
stsand's Avatar
Quoted: 96 Post(s)
Liked: 88
I'm sure those are all great amps, but I shudder to think what they cost. If you have lots of money to throw around, why not.
I've owned the Emotiva XPA-3, and really, that's all you need. 200 continuous watts per channel for extremely efficient speakers. Just my 2 cents.
Sent from my XT1575 using Tapatalk
stsand is offline
post #110 of 195 Old 03-12-2017, 04:18 AM
OJ Bartley's Avatar
Quoted: 592 Post(s)
Liked: 701
Lol, I didn't see anything about a budget. Stop crushing my dreams!
post #111 of 195 Old 03-12-2017, 05:56 AM
Michael Mitten's Avatar
Quoted: 207 Post(s)
Liked: 216
I love my Emotiva and Adcom amps.
Michael Mitten is offline
post #112 of 195 Old 03-12-2017, 05:58 AM - Thread Starter
Quoted: 580 Post(s)
Liked: 669
@eng-399 - have you checked out the diy amps? Looks like @Fattykidd successfully built one. I'm looking into that as a potential upgrade option down the line assuming they have a low noise floor. I can hear a little, minor hiss with my ear up to the CD. However, I can't hear it from even a foot away.
post #113 of 195 Old 03-12-2017, 10:25 AM
eng-399's Avatar
Liked: 5125
Ya I'm all over that thread I was looking last night at the website were Fattykidd bought the amp parts from. I can hear a hiss to from the cd just like you but only when really close to it like your saying. I'm going to start and put a list together and add of the cost but most likely get exactly what he bought.
VicTorious1 likes this.
eng-399 is offline
post #114 of 195 Old 03-12-2017, 11:24 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 596
I was also looking atTHESE . They're very similar to what frisco used in his build.
VicTorious1 and eng-399 like this.
Fattykidd is offline
post #115 of 195 Old 03-12-2017, 11:32 AM
corradizo's Avatar
Quoted: 1552 Post(s)
Liked: 1633
corradizo is offline
post #116 of 195 Old 03-12-2017, 04:18 PM - Thread Starter
Quoted: 580 Post(s)
Liked: 669
Originally Posted by corradizo View Post
nu4-6000?
Does the NU4-6000 have problems with higher frequencies?
post #117 of 195 Old 03-12-2017, 04:42 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
@VicTorious1
iNukes sound like ASS in the higher freqz.... IJS.....
You WILL like these.... https://www.qsc.com/live-sound/produ...-series/pld42/
Juju
kingwiggi likes this.
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20Hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is online now
post #118 of 195 Old 03-12-2017, 04:55 PM
Liked: 2258
Is that a no? I guess the iNukes still have that high frequency roll off issue? Shame, I was hoping their latest slight revision took care of that problem.
Carvin has a 4 channel Class D with DSP, I think it runs around $579 for the rig. I think it would be cool if Crown stuffed four XLS1500 amps into the same chassis, stuffed in the XTi DSP, made the high pass filter go down to 10Hz or lower and pumped up the power supply.
Keep dreaming...
18Hurts is offline
post #119 of 195 Old 03-12-2017, 04:58 PM
mtg90's Avatar
Quoted: 851 Post(s)
Liked: 1691
Three bridged Behringer A500 amps would provide decent power for the titan's, XLR input, low noise, fanless and they have nice level indicators on the front so you can see how much power you are actually using. The only issue with that amp is that the attenuators introduce distortion if not left at full.
mtg90 is offline
post #120 of 195 Old 03-12-2017, 05:53 PM
Jk7.2's Avatar
Quoted: 1730 Post(s)
Liked: 3141
Interesting. I've owned this amp before. I didn't have any issues with it. 500 watts into 8 ohms bridged isn't bad. The cost is not bad for three either. I just wonder if these being so 'affordable' means you get what you pay for in sound quality.
Jk7.2 is offline
