The Aggressive 1299s: A Trilogy - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #1 of 42 Old 03-02-2017, 09:08 AM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
Talking The Aggressive 1299s: A Trilogy
My center channel has always been the weakest link of my front stage. It’s a hand-me-down TM that, while not bad sounding, is inadequate compared to my MTMWWW mains.
However, after adding a pair of sealed HS24-MKII’s, my mains are also lacking the output to keep up. I figured I would go with a matching L/C/R and retire my 4TSE to the bedroom.
I decided on The Aggressive 1299. I’ll be building them to 6 cubic feet with dual slot ports tuned to 47hz.
The build will begin with the center channel. The L and R will follow.
I designed the cabinets in such a way that the center can switch from being horizontal to vertical with the swapping of the center section of the double baffle. This is experimental, but it looks sound on paper, er, in Solidworks. The vertical configuration of the center channel will be identical to the left and right if I ever use them behind an AT screen. This required spacing the woofers slightly wider than I would have otherwise, but not by much.
I’ve been all over the map with respect to box size and port tuning. I decided to go as large as I could using the following restraints:
No deeper than my subs at 21”
Not wider than 15” (75% wider than my current mains)
The height was negotiable, but I wanted to keep it under 47.5” for efficient use of material on the CNC. I can fit all three cabinets on 5 sheet of ply if I keep the height limited, with little scrap. Pushing the height doesn’t work out as well.
The center of the waveguide is 26.5” from the floor for the left and right. I’ll add some stands to bring that up to ear level.
The skillfully packed parts for the CC arrived yesterday. And blank xover boards came from @mtg90 last week.
Both @Eric H and @tuxedocivic were helpful as I pondered cabinet size and tuning.
The ports are 2.75 tall x 13.58 wide and 8.705” long. In the sims the ports are 10.08 inches long, but I’ve reduced them by half the height since they run along a wall. That’s the method I’ve read repeatedly, but my ears are open if there is a better approach.
Some parts for the CC:
These boards looks great and should make the xover assembly a breeze.
Overall dimensions
Some sims:
SPL at 100 watts at 3 meters, compared to the 1299 in a sealed box of the same size, and my current mains. The left and right will have considerably more power on tap, with a Gen 1 XPA-2. The center will be powered by a Denon X3300W.
Port velocity with 300 watts no high pass.
Response compared to sealed in the same size cabinet.
This is the approach for the modular center section of the baffle. I couldn’t make it a square without further pushing the woofers down and limiting the port height, so it will require two sets of the center section.
In vertical configuration:
Horizontal configuration:
Here is how they’ll sit in my room:
And here’s how the tower will look without a side panel, colored braces, before a horizon at dusk (now you don’t have to ask).
baniels is offline
post #2 of 42 Old 03-02-2017, 09:09 AM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
I might update this post with finished pictures someday.
dsl1 likes this.
baniels is offline
post #3 of 42 Old 03-02-2017, 09:57 AM
tuxedocivic's Avatar
Quoted: 2303 Post(s)
Liked: 2235
Im looking forward to this.
When you say reduce the height of the port by half, did you mean the length?
My youtube channel: Impulse Audio
tuxedocivic is offline
post #4 of 42 Old 03-02-2017, 10:38 AM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
Port length in WinISD is 10.08" long. I am building them only 8.705" long, or 1.375" shorter than WinISD calculates. 1.375 is half the 2.75" height of the ports.
tuxedocivic likes this.
baniels is offline
post #5 of 42 Old 03-02-2017, 11:24 AM
dtsdig's Avatar
Quoted: 1140 Post(s)
Liked: 1406
These are going to be awesome! The slot port looks great, way better than giant round ports in my opinion. That simulated front stage looks so badass. Please don't take 2 years on these :P
baniels and filtor1 like this.
dtsdig is offline
post #6 of 42 Old 03-02-2017, 12:10 PM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
Haha. I will do my best.
baniels is offline
post #7 of 42 Old 03-02-2017, 12:20 PM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
Three years later....
________________________________________
DIY Mid Hi Speakers Build - SKHorn Build - Gjallarhorn Build SOLD - Othorn Build SOLD - SEOS 12 Build - Other Gear: JVC NX5 - Seymour Matinee Black - QSC CX4.5Q amps x 5 - QSC Q-sys 110f - Speakerpower 6000 x2
dsl1 is offline
post #8 of 42 Old 03-02-2017, 12:22 PM
lukeamdman's Avatar
Quoted: 1386 Post(s)
Liked: 2008
@Rowan611
dsl1 likes this.
lukeamdman is offline
post #9 of 42 Old 03-02-2017, 12:43 PM
Samps's Avatar
Quoted: 1330 Post(s)
Liked: 994
Awesome!
Looks like the top and bottom are not braced. Probably wouldn't matter much either way.
Samps is offline
post #10 of 42 Old 03-02-2017, 02:12 PM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
That's a good point. I meant to come back to that once I finalized the port. I might go without.
I could split the ports with a piece down the middle which would brace close to half of the top/bottom. Wouldn't have to make them much longer to keep the same tuning. Just need to decide if I can get into the way it looks, vs a clean slot.
Originally Posted by Samps View Post
Awesome!
Rowan611 and skipz like this.
baniels is offline
post #11 of 42 Old 03-02-2017, 04:24 PM
Rowan611's Avatar
Quoted: 638 Post(s)
Liked: 735
Originally Posted by lukeamdman View Post
I like the design!!
We talked about this. I do think I will redesign mine for a similar tune. Both the discussions I've had with dsl1 and you have convinced me to go for a 45hz - 50hz tune. Honestly, I'll like @baniels design. I liked it when dsl1 showed it to me a few weeks ago. I had multiple slotted ports in mine. But, I dig the huge one here; although, I do think it needs a brace. Might be able to push it back into the mouth and paint it all black inside. Would make it much harder to see.
@dsl1 I'll be in contact man. I might get everything cut for the boxes. Everything is packed and in storage, but at least I can get the boxes cut and ready.
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #12 of 42 Old 03-02-2017, 05:19 PM
dtsdig's Avatar
Liked: 1406
I think it looks better without the port split and I really don't think a brace there is necessary anyway. After all, even though these will make some bass, it's not like you'll be dealing with inches of peak to peak excursion. You could always put a dowel right into the center near the back edge of the port panel inside the cab so it wouldn't be visible.
dtsdig is offline
post #13 of 42 Old 03-02-2017, 06:32 PM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
Yes agreed, the bracing the port doesn't matter. Honestly our boxes in general are way overkill.
baniels likes this.
dsl1 is offline
post #14 of 42 Old 03-03-2017, 06:47 AM
bpgunning's Avatar
Quoted: 48 Post(s)
Liked: 91
Yeeaaaa I'm gonna need you to go ahead and do a comparison of the 4TSE and the 1299s when you finish them... I am looking at having my dad build a set of mains for me to replace my Polks, and the 4TSE and 1099s are both on the short list. I don't listen super loud so a traditional tower (i.e. not high-efficiency) seems fine, but if the DIYSG stuff is very on-par with the high end 4TSE at normal listening levels, then I might need to reconsider. My biggest concern is that I've never heard a compression driver before so I'm not sure how they sound. Anyway, enough about that, finish your speakers and post comparative review ASAP
bpgunning is offline
post #15 of 42 Old 03-03-2017, 08:06 AM
ja00's Avatar
Quoted: 225 Post(s)
Liked: 150
Love the colored braces and the detail on the crossover!
ja00 is offline
post #16 of 42 Old 03-03-2017, 11:49 AM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
I'm going to keep the port free of visible obstruction designed, and not brace the top and bottom. But it's easy enough to add a little brace to the backside of the port, unseen. Shown in yellow.
I will certainly do that when they're done. The 4TSE are great speakers. They've served me well for almost 6 years.
baniels is offline
post #17 of 42 Old 03-05-2017, 10:18 AM
Al Toid's Avatar
Quoted: 223 Post(s)
Liked: 219
Personally, I love the thread name. If it weren't for the thread name, I may not have clicked on this. Good luck finishing it. It seems you are putting a lot of effort and time designing in this.
baniels likes this.
Al Toid is offline
post #18 of 42 Old 03-05-2017, 04:41 PM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
The boards from @mtg90 make this too easy (not a complaint). Got a stack of baltic birch coming tomorrow. Should be making some dust this week.
baniels is offline
post #19 of 42 Old 03-05-2017, 09:50 PM
Nexgen76's Avatar
Quoted: 814 Post(s)
Liked: 233
Subbed looking forward to your build......You won't be disappointed in 1299.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #20 of 42 Old 03-06-2017, 07:46 AM
nlpearman's Avatar
Quoted: 48 Post(s)
Liked: 46
Could you show a picture of the back side of the board with all the soldering?
Upgraditis Anonymous
nlpearman is offline
post #21 of 42 Old 03-06-2017, 11:51 AM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
Sure.
baniels is offline
post #22 of 42 Old 03-06-2017, 12:04 PM
Quoted: 349 Post(s)
Liked: 491
Love all the thought you put into how to do this and also the potential for a changeable center speaker mid-baffle!
1299 now that's a man speaker! How big is your room that will have these and the beast subs?
RoboAVS is offline
post #23 of 42 Old 03-08-2017, 06:37 AM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
Question - when it comes to lining the walls of the cabinet. I see I can get Ultratouch in 3.5" thickness (somewhat) locally. But can order the 2" stuff online. 3.5" seems awfully thick. Am I better off using the thinner (r8) stuff?
The room is sort of open plan to the kitchen behind the living room. 21' wide along the front wall, and 27 or so from the front to the back of the kitchen. But the back of the main couch is in the middle, about 13.5' from the front wall, putting the main LP about 12' from the L/R and just under 11' from the center channel.
Roughly like this, walls not shown
baniels is offline
post #24 of 42 Old 03-08-2017, 07:36 AM
Liked: 2235
Can the 3" be slip apart? Thats what I do with regular pink fluffy insulation and it pulls apart right down the middle if you start the rip right.
post #25 of 42 Old 03-08-2017, 12:30 PM
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 669
I used the 2" UltraTouch from HD and it worked great when finishing my 1099s.
VicTorious1 is offline
post #26 of 42 Old 03-08-2017, 09:29 PM
mtg90's Avatar
Quoted: 895 Post(s)
Liked: 1728
The Ultratouch insulation is pretty difficult to rip or cut into half thickness, probably easier getting the thinner stuff online.
mtg90 is offline
post #27 of 42 Old 03-09-2017, 05:16 AM - Thread Starter
baniels's Avatar
Quoted: 219 Post(s)
Liked: 365
Thanks for the input. I've never worked with the stuff in the past. I'll order the 2" stuff.
baniels is offline
post #28 of 42 Old 03-09-2017, 08:37 AM
clientnumber9's Avatar
Quoted: 27 Post(s)
Liked: 52
Beware that the denim insulation produces a heck of a lot of dust when cutting and tearing. I used it on my 1099s and it worked great and was easy to use. I started tearing it in my living room and made a mess before i moved the tearing outside. Just my $.02
lukeamdman likes this.
clientnumber9 is offline
post #29 of 42 Old 03-09-2017, 10:36 AM
OJ Bartley's Avatar
Quoted: 595 Post(s)
Liked: 708
I'd stick with the 2" stuff. I just used an old pair of scissors to cut mine for my HTM-12's and there was virtually no mess at all.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is offline
post #30 of 42 Old 03-16-2017, 06:53 AM
Rowan611's Avatar
Quoted: 638 Post(s)
Liked: 735
Any progress??
Rowan611 is offline
1299 , diysoundgroup
