One inuke3000dsp to power vbss and transducers? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By talon95tsi
post #1 of 5 Old 03-21-2017, 04:15 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 3
I know this is basic and I think it can be done but I'd like to verify from an expert. Can I run a set of 4 transducers off of one channel of an inuke 3000 and the other channel powering a set of vbss subs? I believe with the right transducers I can get to the correct ohm load on both channels. From what I'm reading one channel of the 3000 will power the vbss well. The other will be more then enough for the transducers but I could just turn them down correct?
Thanks for any feedback.
andy9743 is offline
post #2 of 5 Old 03-21-2017, 06:48 PM
mtg90's Avatar
Quoted: 799 Post(s)
Liked: 1631
Yes this should be possible. You will want to run the amp in dual mono or bi-amp mode. As long as both channels have a load that is equal or greater then 2 ohms you should be good.
mtg90 is online now
post #3 of 5 Old 11-27-2017, 08:16 AM
Quoted: 12 Post(s)
Liked: 4
OP, did you ever do this? I'm thinking about running 4x transducers for a 4ohm load with one channel of my Inuke 3000DSP.
Purenv likes this.
talon95tsi is offline
post #4 of 5 Old 11-27-2017, 12:04 PM
Purenv's Avatar
Quoted: 230 Post(s)
Liked: 143
Same here.... please update.
Purenv is offline
post #5 of 5 Old 11-29-2017, 10:47 PM
Quoted: 142 Post(s)
Liked: 70
Butt shakers are just like different sub configurations and need various amounts of juice depending on the set up...
I have an inuke 3000dsp powering a ported 10+ cu.ft. si18 v1 at 2ohm off one channel and 2 aura butt shakers at 8 ohm on the other channel. The auras are rated at 75 max but can take more in short bursts (around double so far over 6 of them with no failures for me yet in 2 different setups).
Match the watts available based on resistance to the ratings on the transducer (s) and I would over power them 33.675% and you could be good. Use the measured power output from the knockerNY on this site for the power rating though.
May the shake be with you. Always.
cellarnoise is offline
