Ported SubRiser question - AVS Forum | Home Theater Discussions And Reviews
 12Likes
  • 1 Post By K9woofer
  • 2 Post By K9woofer
  • 1 Post By Samps
  • 2 Post By michael hurd
  • 4 Post By K9woofer
post #1 of 15 Old 03-24-2017, 01:37 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Ported SubRiser build thread
I am wondering if this oddly shaped box would still perform properly. 2 of these would be the riser for the second row.
edit: better pic
unretarded likes this.
K9woofer is offline
post #2 of 15 Old 03-24-2017, 05:58 PM
Samps's Avatar
Quoted: 1222 Post(s)
Liked: 901
Should work just fine. You'll need to adjust the port length to account for it being along the sides. It will need to be shorter than winisd calculates. Usually half the height of the port subtracted from the length.
Considering the odd shape and semi long length of the cab, there may be a standing wave issue, but I'm not qualified to figure that out. Probably easily fixed with a pillow in the right spot.
Samps is offline
post #3 of 15 Old 03-26-2017, 12:05 PM
Augerhandle's Avatar
Quoted: 1158 Post(s)
Liked: 1144
Your end to end resonance (along the long dimension) will be around 110 Hz. Could be a problem, but as Samps posted, a few cheap pillows should help
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #4 of 15 Old 03-26-2017, 08:38 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Thanks for the responses.
This thing will probably get a lowpass filter to avoid localization, unless the phase gets too far out. Front subs in addition to this.
K9woofer is offline
post #5 of 15 Old 06-29-2017, 06:57 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Started assembly.
Samps and unretarded like this.
K9woofer is offline
post #6 of 15 Old 06-30-2017, 01:49 AM
Quoted: 566 Post(s)
Liked: 64
What driver are you planning to use? How many cubes for each driver?
Tip24/96 is offline
post #7 of 15 Old 06-30-2017, 01:46 PM
Samps's Avatar
Liked: 901
Interesting project. The box isn't as long and skinny as the drawing made it look. That should work just fine. I wonder if it might actually work better without a lot of bracing? Obviously it needs to be strong enough to support weight on top of it, but a little bounce may or may not enhance the feel.
Samps is offline
post #8 of 15 Old 06-30-2017, 08:58 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
UM-18, 14.5 cu ft each.
K9woofer is offline
post #9 of 15 Old 07-07-2017, 07:32 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Longest internal dimension is 58.5". Will it need a pillow inside?
K9woofer is offline
post #10 of 15 Old 07-07-2017, 07:47 PM
michael hurd's Avatar
Quoted: 635 Post(s)
Liked: 670
Yes, some form of absorption will be needed. Placed away from the wall, it becomes more effective.
LTD02 and eng-399 like this.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #11 of 15 Old 07-12-2017, 07:09 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Got one almost done.
bscool likes this.
K9woofer is offline
post #12 of 15 Old 07-18-2017, 04:34 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
I played some sweeps with and without a pillow. I can hear the dip and peak around 100hz quite obviously without a pillow. With a pillow it is minor.
Excursion minimum came in around 15hz. Was trying for a 16hz tune.
K9woofer is offline
post #13 of 15 Old 07-20-2017, 09:35 AM
joebuddyguy's Avatar
Quoted: 110 Post(s)
Liked: 153
Nice! Looking forward to seeing these completed! You and @Scott Simonian have inspired me to do something similar. I plan on keeping the entire riser ~14 inches high and up firing the drivers underneath the back row seating. Are you going to be facing the drivers at a wall or the first row of seating?
joebuddyguy is offline
post #14 of 15 Old 07-21-2017, 05:01 PM - Thread Starter
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Drivers will be facing the first row.
I played around with SketchUp a bit. Updated the first post.
joebuddyguy likes this.
K9woofer is offline
post #15 of 15 Old 07-24-2017, 05:50 PM
unretarded's Avatar
Quoted: 1687 Post(s)
Liked: 2072
Nice, I am also planning something like this !!!!!!
Link to Stereo Integrity SI HT 18 sub build......https://www.avsforum.com/forum/155-di...-pedestal.html
Speakers and subs for sale...https://www.avsforum.com/forum/209-au...kers-subs.html
unretarded is offline
