My DIYSG 1099 Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #31 of 41 Old 03-31-2017, 12:03 PM
ja00's Avatar
Quoted: 224 Post(s)
Liked: 149
@wasser , I clamped the laminate to a scrap piece of baseboard after making sure it was straight, then flush trimmed. Installing it was easy because the Volt 6 baffles (at least the slanted ones I have) are a little oversized.
ja00 is offline
post #32 of 41 Old 03-31-2017, 03:03 PM
wasser's Avatar
Quoted: 119 Post(s)
Liked: 83
That's what I was thinking. Although I didn't do mine that way, that's exactly how I'd planned to do it had I glued the baffles first. I opted to glue them second because I was unsure of being able to align the whole edge laminate on the F-15s, especially with the instant bond of the contact cement. The wood glue was much more forgiving.
Fusion-15: Asian Night Sentinels
wasser is offline
post #33 of 41 Old 04-01-2017, 02:59 PM - Thread Starter
fschris's Avatar
Quoted: 47 Post(s)
Liked: 45
I have some DIYSG Marty Cubes to build after this so I will think about lamination of the front before I glue them up if possible....
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
post #34 of 41 Old 04-02-2017, 06:27 PM - Thread Starter
fschris's Avatar
Quoted: 47 Post(s)
Liked: 45
What do people think about the clear coat after using a Rustoleum Enamel ? Do You need it ? I would think the paint is pretty tough for outdoor use the speakers will be indoors in climate controlled area.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #35 of 41 Old 04-03-2017, 03:41 AM
dtsdig's Avatar
Quoted: 1124 Post(s)
Liked: 1386
So were the photos showing paint damaged on the fronts?
dtsdig is offline
post #36 of 41 Old 04-03-2017, 06:18 PM - Thread Starter
fschris's Avatar
Quoted: 47 Post(s)
Liked: 45
Wow , after I repainted the front Baffle they look really good. I used about 3 cans of the Rustoleum Enamel Satin black. I decided not to do a clear coat because I read too many people having issues with cracking and yellowing etc. The rustoleum should hold up well as I wont be beating them up.
wasser likes this.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #37 of 41 Old 04-03-2017, 09:20 PM
Quoted: 30 Post(s)
Liked: 37
If I may offer a suggestion with regard to adapting laminate/veneer to precut face plates? Put the laminate on first before the face plate. This will always oversize your cabinet. To correct the transition, mask the edge of the laminate with tape (I use fine line autobody tape, but green tape or regular masking tape will work well enough), and mask another parallel to it, basically like you would a pin stripe. In the case of a baffle with a 3/4" roundover, approximately 5/16" is a good size. Then take 5 minute epoxy, and mix either colloidal silica (cabosil), talcum powder, or even baking flour will work, with it, to about a peanut butter consistency. Then just fill the masked separation. Remove the tape as soon as the epoxy starts to kick.
With 5 minute epoxy, you may have enough time to do two sides per mix so don't make too much. 10 or 15 min (or longer) epoxy would be better
It will leave you with a very neat profile that looks like a professional factory fit.
Mask and paint the faces after.
MrBoat is offline
post #38 of 41 Old 04-05-2017, 03:42 AM - Thread Starter
fschris's Avatar
Quoted: 47 Post(s)
Liked: 45
Made more progress
OJ Bartley, markg35, ja00 and 1 others like this.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #39 of 41 Old 04-06-2017, 05:40 PM
markg35's Avatar
Quoted: 346 Post(s)
Liked: 269
I really like these speakers!Probably overkill for my needs though.Great Job!
markg35 is online now
post #40 of 41 Old 04-07-2017, 04:14 PM
Quoted: 49 Post(s)
Just ordered 3. How do you like them ??
Beams37 is offline
post #41 of 41 Old 04-08-2017, 06:21 AM - Thread Starter
fschris's Avatar
Quoted: 47 Post(s)
Liked: 45
one down and 4 more to go...
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
