How much space needs to be around driver surround - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 2 Post By Cichlid109
  • 1 Post By BassThatHz
  • 1 Post By Cichlid109
  • 1 Post By Trimlock
  • 1 Post By Electrodynamic
  • 1 Post By Shadowed
post #1 of 14 Old 04-14-2017, 10:22 AM - Thread Starter
tjcinnamon's Avatar
Quoted: 1811 Post(s)
Liked: 490
So I creating a build to match my BDI media console. The front of the sub will have a slated "grill" over the front of it. I'm using the SI HST 11. My concern is it has a large 1.65" surround (nipple) around the driver. I'm uncertain of how much that moves an any direction. I need to accommodate for that. Perhaps it only moves sideways?
Here is a picture of the HST 11:
Here is a picture of what I want to build
Here is a diagram wondering what dimensions I'll need for clearance
cc: @Electrodynamic
ID:	2083953   Click image for larger version
Name:	HST 11 Room.png
ID:	2083961   Click image for larger version
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #2 of 14 Old 04-14-2017, 10:30 AM
Cichlid109's Avatar
Quoted: 273 Post(s)
Liked: 154
The spec.s say 38mm roughly 1.6" iy you want to be safe I would allow 4". My HST18 during some movies will easily move 2 +.
tjcinnamon and Electrodynamic like this.
Denon AVR-4520 LCR BIC PL89ii's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height w/EP-2000, BIC DV84's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #3 of 14 Old 04-14-2017, 10:37 AM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4295
To be safe I'd say 2x it's height, starting from the peak outward.
Or xmech + surround height, starting from the cone outward.
Or xmax + surround height, starting from the cone outward.
That should give plenty of clearance considering the positive direction is less than half of that.
tjcinnamon likes this.
BassThatHz is offline
post #4 of 14 Old 04-14-2017, 11:00 AM - Thread Starter
tjcinnamon's Avatar
Liked: 490
So xmax is 38 mm (1.5")
Surround is 42mm (1.65")
we're thinking a 3.15" plus .85" for fudge factor.. So 4" in the outward. what about the side to side plane? My guess is it won't move side to side as much (i.e. the diameter for the recessed front plate cutout)
post #5 of 14 Old 04-14-2017, 12:26 PM
Cichlid109's Avatar
Quoted: 273 Post(s)
Liked: 154
They are designed to move in and out not side to side. It works like a piston. Never seen a sub move side to side.
post #6 of 14 Old 04-14-2017, 03:27 PM - Thread Starter
tjcinnamon's Avatar
Liked: 490
@BassThatHz
@Cichlid109
I suppose another option would be to have them downward firing. I'm a little hesitant because it's thicker carpet and I do like the tactile feel. What are your thoughts on that?
some people say it's the same. It very well could be. I have no frame of reference.
post #7 of 14 Old 04-14-2017, 03:33 PM
Quoted: 445 Post(s)
Liked: 364
Originally Posted by tjcinnamon View Post
@BassThatHz
@Cichlid109
Apart from mine bouncing a peice of metal inside, it sounds the same. I've had mine up fire, down fire and laying down facing the room and I can't tell the difference.
Trimlock is offline
post #8 of 14 Old 04-14-2017, 03:40 PM
Cichlid109's Avatar
Quoted: 273 Post(s)
Liked: 154
If your going to go down firing I would suggest instead of having the sub firing into the carpet put a plate or something the carpet is going to muffle the sound a great deal. With my HST's I built a DO cabinet found some stainless steel legs approx. 4" H x 2" dia I attached a wooden plate that is a little larger then the box so the sub fires on the plate vs. the carpet. Look at the image I have the same top and bottom of the box.
post #9 of 14 Old 04-14-2017, 06:33 PM
Electrodynamic's Avatar
Quoted: 536 Post(s)
Liked: 806
I would leave at least 2" above the top of the surround for adequate clearance. With rated power you can get by with less clearance but if you exceed rated power you should leave 2" or slightly more above of the top of the surround for movement.
Electrodynamic is offline
post #10 of 14 Old 04-14-2017, 07:10 PM
Shadowed's Avatar
Quoted: 953 Post(s)
Liked: 913
The carpet won't absorb much if anything at all in sub frequencies.
Augerhandle likes this.
Shadowed is online now
post #11 of 14 Old 04-16-2017, 09:25 AM - Thread Starter
tjcinnamon's Avatar
Liked: 490
What would rated power be in the case of the hst 11's?
post #12 of 14 Old 04-16-2017, 11:16 AM
Cichlid109's Avatar
Quoted: 273 Post(s)
Liked: 154
Cannot remember exactly but I think I remember Nick telling me he had a clone hooked up to it?? The spec.s say 2000 based on the 18's I would say a little more and your still okay.
post #13 of 14 Old 04-16-2017, 05:20 PM - Thread Starter
tjcinnamon's Avatar
Liked: 490
My guess is I won't run it that high.
post #14 of 14 Old 04-17-2017, 09:37 PM
Quoted: 536 Post(s)
Liked: 806
I can not, and will not, ever recommend over rated power. However, I have sent my twin DO-11's well over rated power for short durations. During those durations I know, and accept, that if they fail I will pay to repair them as said abuse is not covered under warranty. However, my drivers are performing flawlessly to this date without any rebuilds, repairs, etc. IIRC they are going on 3+ years of use at this level.
And yes my amplifier is a 14k clone on a pair of 11's. BUT I rarely use even 1/2 of what the amplifier is capable of for 90% of listening material and listening levels.
