Raylon's Stealth 1099s - AVS Forum | Home Theater Discussions And Reviews
 45Likes
  • 27 Post By Raylon
  • 1 Post By 18Hurts
  • 7 Post By DaveyK
  • 1 Post By Raylon
  • 7 Post By Raylon
  • 2 Post By dwaleke
post #1 of 25 Old 05-01-2017, 02:35 PM - Thread Starter
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 585
So here is my Stealth 1099s Project. I wanted something with a high WAF factor but still sound good. I found a set of 1099s that @dwaleke was selling so I made the ten hour round trip to pick them up. They were in great shape, prebuilt, so it was well worth the trip.
So my plan was to heighten the side speakers so all the horns were at ear level of 32”. I used sand filled boxes on the bottom to do this. These things are a solid 150lbs a pop now, which is super overkill but they are solid. I then got Baltic Birch ply and layered the sides and added a lip that extended ¾” so I could install grills.
I found some ¾” metal stock and asked my friend to weld them together. So far we did the one as a test run and it works wonderfully. Unfortunately he did them so well after putting the material on I don’t think I would be able to get the thing out without destroying the fabric. I tried to cover the grill once and it came out poorly, but once I ripped it off and tried again, it came out perfect. Hot glue works wonders.
I painted the face of the boxes black so when looking through the grills it appears uniform. It also gives a great appearance with the grills off. I am looking forward to having the other two grills built and have them be done. I loved working on the project and am insanely happy with how they have turned out.
Picking them up was quite the journey!
Giving them a few days testing before ripping them apart.
Sanded them all down, nice and pretty.
Built wooden stands and added sand to deaden the up and add weight.
Glued the boxes on. Solid and extremely heavy now.
Got the skin put on. Starting to look good.
Added front piece for looks and to make them look more finished.
One grill done. Just had to add material. Wanted to see how one worked before building more.
Ready for paint!
All primed!
Painted and fronts painted black!
Reassembled and beautiful!
One grill down! Two to go!
And they are all done!
Hope you guys enjoyed the build, I know I did! Love the finished project. I will add pictures of the trio when they are all done!
Raylon is offline
post #2 of 25 Old 05-01-2017, 02:39 PM
eng-399's Avatar
Quoted: 2428 Post(s)
Liked: 5004
eng-399 is offline
post #3 of 25 Old 05-01-2017, 02:44 PM - Thread Starter
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 585
Originally Posted by eng-399 View Post
Great work Ryan the speakers look great! What's the xo point your putting on them to mix with the 18's.
You know I haven't really had the chance to play with them that much. Right now the 18's are crossed over at 120hz to get all that nearfield goodness. I will have to play with them some more to see what I like. I'm also dreading going to your house because I know I'm gunna want to build some VBSS or something to get some midbass madness going on.
Raylon is offline
post #4 of 25 Old 05-01-2017, 02:49 PM
eng-399's Avatar
Liked: 5004
Start at 80 and go up on the 1099's. I remember when I built dmans 1099's we played a few gun fighting movies and they sounded fantastic with all those guns going off the vocals from them were nice to. You going to have lots of fun playing different clips through them. They match your trim in your house to along with the entertainment center. I'm sure your wife is happy with the looks.
eng-399 is offline
post #5 of 25 Old 05-01-2017, 03:06 PM
Quoted: 1297 Post(s)
Liked: 2096
You are my hero!
Increasing the size of the speaker to "stealth" it--and get away with it! Genius!
At 150 pounds, that makes it more permanent and it makes the center channel look smaller. All you need to do now is get a larger TV to make the center shrink in size.
I'm pondering using the 1099 myself--but my furniture allows 13" in height but only 30" in width. My options are to port it in the back to save about 3.5" in width or so and maybe angle the two 10's on the sides to make it 30" wide? The depth can be 22" so a possibility.
Have 9 months to figure it out, instead of making sawdust--figure it out with cardboard. Using two hemp 8's instead of 10's and put the slot ports on top of the 8's would make it fit--in a way.
Let us know how well the horizontal center images with your configuration, it is the sun in the solar system of surround.
shivaji likes this.
18Hurts is offline
post #6 of 25 Old 05-01-2017, 03:10 PM
salehdidit's Avatar
Quoted: 43 Post(s)
Liked: 27
Looks great. I sat on the fence for a really long time on those speakers, but am so glad you got them and created this. Great job!
salehdidit is offline
post #7 of 25 Old 05-01-2017, 03:24 PM
Modicen's Avatar
Quoted: 126 Post(s)
Liked: 53
Awesome job!
Modicen is offline
post #8 of 25 Old 05-01-2017, 03:25 PM
shivaji's Avatar
Quoted: 1194 Post(s)
Liked: 1170
Great job. Loved the ingenuity of the joining base and speaker into one. Looks great.
shivaji is offline
post #9 of 25 Old 05-01-2017, 08:22 PM - Thread Starter
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 585
So far running great! Having the heights match exactly I think really helps, things pan across the screen perfectly and it blends right in.
Yep they were a great deal! I use the Fusion 6's and the Volt 6's he threw in after giving them both quick paint jobs Those really sealed the deal!
Originally Posted by Modicen View Post
Awesome job!
Yea my goal in the end was to have a sleek looking speaker in the end and I think I nailed it!
Raylon is offline
post #10 of 25 Old 05-01-2017, 08:45 PM
FriscoDTM's Avatar
Quoted: 428 Post(s)
Liked: 389
Nice work those look great
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #11 of 25 Old 05-01-2017, 08:51 PM
goonstopher's Avatar
Quoted: 335 Post(s)
Liked: 72
I'm aiming for an overkill stealth system and yours helped me realize that full hiding might not need to be 100% if the finish matches nicely
goonstopher is offline
post #12 of 25 Old 05-02-2017, 03:14 AM
DaveyK's Avatar
Quoted: 119 Post(s)
Liked: 152
These look great! I was actually thinking of buying these exact speakers (great deal!) and doing something very similar. Like you, I was also planning on a stealth approach to sneak some very capable speakers into our main living room. I built some VBSS's into a TV stand and end table, and plan to go with a similar finish on the speakers--see attached pictures. I'm happy you beat me to these as they will serve as inspiration for my build whenever the time comes. The contrast of the black baffle against the white looks awesome and I'd be tempted to leave them naked without the grilles. Job well done! Did they pass the WAF test?
DaveyK is offline
post #13 of 25 Old 05-02-2017, 05:31 AM - Thread Starter
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 585
Thanks! I loved your VBSSs I remember the build thread! I do really like the black baffle on white, it does look great. They did pass the WAF test, she likes them! The only thing she doesn't like is the sheer size of then. The towers are pretty massive. She wishes we had a bigger TV stand(Center Channel stand now I guess) that didn't get dwarfed by the speakers.
Raylon is offline
post #14 of 25 Old 05-02-2017, 06:16 AM
gpmbc's Avatar
Quoted: 386 Post(s)
Liked: 264
Everything turned out great ... well executed!
gpmbc is online now
post #15 of 25 Old 05-03-2017, 11:00 AM
OJ Bartley's Avatar
Quoted: 492 Post(s)
Liked: 583
Those look gorgeous, very well done! The only question I have is: shouldn't they have some insulation inside? Regardless, they look (and I'm sure they SOUND) fantastic. Great work.
OJ Bartley is offline
post #16 of 25 Old 05-03-2017, 12:14 PM - Thread Starter
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 585
Oh ya they are stuffed with the appropriate amount of polyfill and denim insulation! I took it all out for construction and painting! And thank you!
OJ Bartley likes this.
Raylon is offline
post #17 of 25 Old 05-04-2017, 04:03 PM
d_c
d_c's Avatar
Quoted: 1178 Post(s)
Liked: 1602
d_c is offline
post #18 of 25 Old 05-04-2017, 06:13 PM
ja00's Avatar
Quoted: 225 Post(s)
Liked: 150
Looks great! Blends with the Xbox very nicely.
ja00 is offline
post #19 of 25 Old 05-07-2017, 06:38 PM
Liked: 9
Those turned out dynamite. Every part of your build is brilliant. The added sand in the bases is great. The effect in your room is nice too.
I've been wondering how to ditch the milkcrates under my fusion 15s. I'm gonna have to copy your speaker "stands". Mine will be without the nice finish since I hide mine behind an at screen.
Looking foward to pics with the L and R grills done. They look pretty cool with their grills off too.
Sent from my SM-N920T using Tapatalk
Grott77Ralph is offline
post #20 of 25 Old 05-12-2017, 06:46 PM - Thread Starter
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 585
Update time! First thanks for all the compliments! They turned out really well and I am super happy with them. My friend came over and finished the other two frames and I finished them up today. I am super happy with the end result. Now to rerun Audyssey and enjoy!
eng-399, Modicen, bscool and 4 others like this.
Raylon is offline
post #21 of 25 Old 05-13-2017, 07:10 AM
dftkell's Avatar
Quoted: 117 Post(s)
Liked: 87
Do you have a build thread for the TV stand? Looks great.
dftkell is offline
post #22 of 25 Old 05-14-2017, 05:07 AM
DaveyK's Avatar
Quoted: 119 Post(s)
Liked: 152
Thank you for the compliment. Here is the link for the TV stand and end table builds:
https://www.avsforum.com/forum/155-di...and-build.html
DaveyK is offline
post #23 of 25 Old 05-18-2017, 07:25 AM
dwaleke's Avatar
Quoted: 1449 Post(s)
Liked: 748
This is so great to see. Exactly what I was hoping for when I sold them. They look great and I bet they sound awesome in your setup.
Congrats on a great build.
dwaleke is offline
post #24 of 25 Old 05-18-2017, 11:04 AM
chadsmith013's Avatar
Quoted: 2239 Post(s)
Liked: 2301
and now he is selling them..
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP Channel A
Nearfield: 4 B-52 SP-1804 18s w/Inuke 6000DSP Channel B
chadsmith013 is offline
post #25 of 25 Old 05-18-2017, 11:29 AM
dwaleke's Avatar
Liked: 748
Lol. I shouldn't be surprised. This is AVS after all. We are addicts!
chadsmith013 and infinity06 like this.
dwaleke is offline
