Volt-10 LX Edition Atmos build - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By DaleNixon
  • 3 Post By PsychoM3
  • 1 Post By OJ Bartley
  • 2 Post By DaleNixon
post #1 of 19 Old 05-06-2017, 12:55 AM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
Here's my Volt-10 LX Edition Atmos build. I wanted something shallow for my narrow theater and decided these would fit the bill. If they didn't work I'd still have decent speakers I could use for rears or atmos. I originally was going to paint them flat black, for the sake of a dark theater, but since they are off to the sides their color is less important. Plus, they are very noticeable being white which hopefully lessens the chance of knocking into one of them by accident.
I've included a REW chart from early testing before any EQing and run in an untreated room. I ran each speaker separately in the identical position. Should I be concerned with that difference from 450 to 700 hz where one speaker is about 3-4 dbs lower? Is there anything obvious that could have caused it like poor seal, a difference in fiberfill, a messed up crossover, or should I just wait for them to break-in and do another test?
As far as sound quality goes...I think they sound good...great? I'm not an audio expert, but I'm not disappointed. I've heard bad speakers (boomy or boxy) and these are not bad. They fit in fine with my Frankenstein theater of Klipsch, B212XL's, and Monoprice...all compression driver speakers.
And one odd note is that Audyssey set the crossover on the Volts at a very low 40Hz where the small atmos box (I used the same dimensions as the flat packs) is supposed to only reach to 80Hz. I manually changed them to 80Hz to match the other speakers anyway, but I thought that was odd they'd go that low being sealed and mounted right up against a wall.
ID:	2119657   Click image for larger version
ID:	2119665   Click image for larger version
Name:	atmos boxes.jpg
ID:	2119681   Click image for larger version
Name:	crossovers unassembled.jpg
ID:	2119689   Click image for larger version
Name:	crossovers assembled.jpg
ID:	2119705   Click image for larger version
ID:	2119713   Click image for larger version
Name:	crossovers installed.jpg
ID:	2119721   Click image for larger version
Name:	primed and stuffed.jpg
ID:	2119729   Click image for larger version
Name:	painted satin white.jpg
Name:	painted satin white2.jpg
ID:	2119745   Click image for larger version
Name:	Volt-10LX (2) All SPL.jpg
chucky7 likes this.
_________________________________________________
Denon AVR-X4200W / Crown XLI 2500
7.4.4 Klipsch Ref. ii & In-Ceiling Atmos / Titan-615LX center
NU3000DSP - 2 SI HT18 D4's / NU6000DSP - 2 Ultimax 18"s
BenQ W1070 / 120" AT screen / Volt-10LX Atmos build
DaleNixon is offline
post #2 of 19 Old 05-06-2017, 02:53 AM
Quoted: 22 Post(s)
The dip in frequenzy response is most likely a room problem that can only be fixed with speaker placement and/or acoustical treatments.
But you can always swap the speakers and measure again to eliminate a speaker issue.
7.1.4
DIY ER18MTM, DIY custom Overnight Sensation, DIY LilWrecker DIY Hypex poweramps, Denon AVR X6200W, Cambridge Audio Azur 751BD
https://www.avsforum.com/forum/155-di...und-atmos.html
Roadrune is offline
post #3 of 19 Old 05-06-2017, 03:02 AM
WereWolf84's Avatar
Quoted: 418 Post(s)
Liked: 177
Nice build, may I know what radius of that roundover you used?
WereWolf84 is online now
post #4 of 19 Old 05-06-2017, 11:50 AM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
I measured each speaker separately from the same speaker position and the same mic position.
post #5 of 19 Old 05-06-2017, 11:52 AM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
3/8" roundover bit.
WereWolf84 likes this.
post #6 of 19 Old 05-06-2017, 12:15 PM
asarose247's Avatar
Quoted: 1291 Post(s)
Liked: 1133
Always good to see nice clean tight work
Enjoy!
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #7 of 19 Old 05-06-2017, 03:16 PM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
Enjoy!
Thanks. They're not quite perfect though....a few more coats and more sanding is in store, but listening to them for now trumps looking at them.
post #8 of 19 Old 05-06-2017, 05:25 PM
PsychoM3's Avatar
Quoted: 469 Post(s)
Liked: 457
Volts in white satin
I'm hoping to blend
Speakers I'm sanding
Never seeming to end
Cause I love you
Yes I love you
Oh how I love you
Apologies to the Moody Blues
BllDo, 18Hurts and Luminated67 like this.
PsychoM3 is offline
post #9 of 19 Old 05-08-2017, 10:48 AM
OJ Bartley's Avatar
Quoted: 569 Post(s)
Liked: 670
Nice build. I just opened the shipping box on my Volt-6's, and was pleasantly surprised at how beefy they were. I bet the 10 is a pretty imposing speaker in person. These Volts probably don't get the credit they deserve, because they look so unimposing in the small boxes, but they seem like great quality speakers. I'd guess that being wall mounted helped give them some low end, which might explain Audyssey, but it's nice to know they could play low if needed.
nlpearman likes this.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is offline
post #10 of 19 Old 05-08-2017, 12:02 PM
chadsmith013's Avatar
Quoted: 2491 Post(s)
Liked: 2555
i agree with that..i was surprised how beefy they actually were..
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 4 DIYSG Volt 6's
Subwoofers: Dual Eminence NSW 21's in Cyclops enclosures w/Inuke 6000
Nearfield: 4 B-52 SP-1804 18s w/Inuke 6000DSP
chadsmith013 is offline
post #11 of 19 Old 05-08-2017, 01:36 PM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
I don't know...every Volt review I've read including the 6's and 8's have been glowing. I'm considering more in the future, but ported this time. (Use the sealed for Atmos and ported for surround.)
I didn't know wall mounting could help with the bottom end.
Watched the Spielberg movie "War Horse" for the first time last night expecting to be impressed with the bass, but was more impressed with the surround effects particularly the surround Volt-10LX's. The Behringer B212xl's in the rear also sounded nice...I usually don't hear the rears much. This movie must have an especially good sound mix.
ID:	2125233   Click image for larger version
ID:	2125241   Click image for larger version
Erich H and WereWolf84 like this.
post #12 of 19 Old 05-08-2017, 05:23 PM
WereWolf84's Avatar
Quoted: 418 Post(s)
Liked: 177
Nice looking, how do you hang/mount it on the ceiling?
post #13 of 19 Old 05-08-2017, 06:41 PM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
They're not being used for atmos / ceiling...just as surrounds.
post #14 of 19 Old 05-08-2017, 07:02 PM
OJ Bartley's Avatar
Quoted: 569 Post(s)
Liked: 670
You're right, they do get great reviews... Maybe what I was trying to say is that they get pigeonholed as surround/atmos speakers, when they can make great mains for smaller setups too.
I think wall mounting (or placing against the wall) can add some boundary reinforcement in the lower octaves, but don't quote me on that.
Sent from my LG-H812 using Tapatalk
post #15 of 19 Old 05-09-2017, 08:32 AM
RLBURNSIDE's Avatar
Quoted: 2012 Post(s)
Liked: 1411
The main selling point for coax speakers like the Volt 10s is Atmos, IMO, due to their point-source like nature which results in better imaging. Of course that should apply for traditional stereo / 7.1 as well, it just seems weird to not go Atmos with these. Although they are definitely pretty big for height speakers!
Also it would likely be better to have angled enclosures for the ceiling speakers so the drivers can be aimed at the main listening position.
Terrific looking enclosures btw, love the white satin look (although again, for home theater black everything is ideal, especially if placing these behind an AT screen. White would reflect light back at the viewer unless there were many layers of fabric)
RLBURNSIDE is offline
post #16 of 19 Old 09-06-2018, 09:20 AM
manusha's Avatar
Quoted: 39 Post(s)
Did you put a window pane brace inside as instructed in here? https://www.diysoundgroup.com/volt-10.html
I am trying to build these but dont understand how to put the braze as described in that link.
manusha is offline
post #17 of 19 Old 09-06-2018, 09:46 AM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
I did not add a brace. I made my own boxes...if you get the flatpacks the braces should be included ..they were with my titans flatpack.
Edit: The DIYSG site states "No brace is needed for the angled surround design" and I built the even smaller atmos box so it should not be required. If you are porting I guess that's a different story.
post #18 of 19 Old 09-06-2018, 04:50 PM
Luminated67's Avatar
Quoted: 845 Post(s)
Liked: 461
Volt make some of the best drivers in the business so not at all surprised you were impressed, some beautifully crafted boxes you have there..... really nice work.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #19 of 19 Old 09-06-2018, 07:18 PM - Thread Starter
DaleNixon's Avatar
Quoted: 213 Post(s)
Liked: 131
Thanks! Actually they are black now.
Name:	volt 10lx black.jpg
