Theater 10.0 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 232Likes
post #361 of 388 Old 12-20-2019, 10:51 AM - Thread Starter
MKtheater's Avatar
Quoted: 2761 Post(s)
Liked: 3208
So I demoed TIH last night at reference with the subs 12 dB hot(on test tones) 17-20 dB hot from 4.5-10 hz based on my response. The Cop car smash seen had a shutter effect throughout the theater and seats after the last punch right before he said is that all you got.
Building the room, speakers, and subs.
MKtheater is online now
post #362 of 388 Old 12-20-2019, 01:23 PM
Reddig's Avatar
Quoted: 610 Post(s)
Liked: 1249
Originally Posted by gpmbc View Post
Best I’ve ever seen your theater look!
I second that MK! Its never looked so good! The flood was good news in disguise.
JTR/JBL/JVC/Denon/Oppo/Monolith/Silver Ticket/Furman/Seatcraft/Acoustimac/AudioQuest/Harrison Labs/Roku
Reddig is offline
post #363 of 388 Old 12-20-2019, 09:40 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
Thanks, everybody agrees who has been in it so far. It really is much darker in person than these iPhone pics. Putting the subs in the wall really created that much bigger effect which gave me the extra 3 feet for the back row to move off that wall. BTW, I had to go green so to speak and use soy glue pine and pillows in the acoustic panels. They seem to work pretty good, they actually stick out farther than what they would have been with batts. My 2 inch panels are more like 4 inches in the middle and my 4 inch panels are more like 6. The two supporting steel poles are wrapped in several layers of foam and then covered with black microsuede. My subs are also soy glue pine plywood and I used screws and pl premium on all the seams. I stuffed them with pillows which really make them sound solid. The riser is 13 inches tall.
Reddig likes this.
post #364 of 388 Old 01-30-2020, 07:52 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
That last graph was with a behringer NX3000, and then with a Peavy IPR2-7500. Notice the rolloff is much less.
I gained about 5-6 dB at 3 hz during those sweeps.
post #365 of 388 Old 01-30-2020, 08:05 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
I meant there is about 5-6 dB less roll off at 3hz.
post #366 of 388 Old 02-28-2020, 10:14 PM
Titan38's Avatar
In my room 7 different people prefer the sound of these
over these
DIY JBL(best JBL design I owned)
which were preferred over these
BFM DR-250
JBL 3622
JTR triple 8
M&K S-5000THX
which started it all for me. That last picture were the M&K S-5000THX speakers that sound fantastic. There were quite a bit in between speakers as well. I have had the same people listen to my room for 12 years. My latest speaker with dual 12s, 9 Dual ring radiators(resonant frequency of 800hz or so, crossed at 1.6khz) sound the best to everybody. Clean, ultra detailed, huge sound stage, and non fatiguing. Some of the big horns I have had covered 500hz to 12khz easily and these are still preferred. I also had Fusion pure 10s, klipsch, other JBls, Sho-10s, Yorkvilles, behringers, axiom, magnepan, etc...
@MKtheater in your speaker rankings (post 206) Is that the "stock" tlah ranked highest of that group, or your ported line array?
Titan38 is offline
post #367 of 388 Old 02-29-2020, 07:01 AM - Thread Starter
MKtheater's Avatar
Liked: 3208
It was the stock going from memory. I think we all preferred the smoother sound of the soft domes compared to the compression drivers tested. Of course these were all with subwoofers so we were not comparing speakers as stand alone solutions but integrated into my HT and just overall experience.
post #368 of 388 Old 02-29-2020, 07:01 AM
BP1Fanatic's Avatar
Quoted: 438 Post(s)
Liked: 408
Geez MKT, you've had some AWESOME systems!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #369 of 388 Old 02-29-2020, 08:46 AM - Thread Starter
MKtheater's Avatar
Liked: 3208
Thanks. Everytime a new design or something came out I tried it. I had horn subs before they became a thing around here. That is why when I see horn designs I don't try them because I like low end extension over excessive midbass which I have had both, for my room anyways.
Oh, I did not even put these in there which were better than the JBL 3622, and equivalent to the Yorkville unity 215.
Plus these
This last one was an fully horn loaded system, and those MBM were crazy.
BP1Fanatic likes this.
post #370 of 388 Old 05-08-2020, 03:02 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
Here is my walls response from the center channel.
post #371 of 388 Old 05-08-2020, 04:40 PM
BP1Fanatic's Avatar
Quoted: 438 Post(s)
Liked: 408
Wow!
post #372 of 388 Old 05-09-2020, 05:14 AM
femi's Avatar
Quoted: 334 Post(s)
Liked: 432
nice slope. i can go skiing on that bad boy.
Femi
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is offline
post #373 of 388 Old 05-09-2020, 01:28 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
Femi
People can understand why I don't port these anymore. They already act like a ported sub where I have them.
femi likes this.
post #374 of 388 Old 05-30-2020, 07:25 AM - Thread Starter
MKtheater's Avatar
Liked: 3208
Here are a couple responses from speakers I have built. One is a 10 and the other is a 12.
10
12
and 45 degrees off axis in room.
My 12 in the wall rolls off like the 10 and they liked to be crossed over to 120hz to the subs. These are all sealed. The new 12 crosses over at 70-80hz.
post #375 of 388 Old 05-30-2020, 08:10 AM
gpmbc's Avatar
Quoted: 461 Post(s)
Liked: 373
Hey, did you make further changes to the speakers or more time in dialing them in? Did you end up adding more tweeters to the 10” version?
gpmbc is offline
post #376 of 388 Old 05-30-2020, 08:51 AM - Thread Starter
MKtheater's Avatar
Liked: 3208
These are just single tweeter and single 10 and or 12. I am using capable drivers to play reference in room without compression.
Here they are
10
12
post #377 of 388 Old 05-30-2020, 09:32 AM
Quoted: 82 Post(s)
I am talking to myself LOL! Well here are some designs I have been working on and the TLAH is on the right.
Great work
Do you have a list of parts and speaker design plans? And the crossovers for each one. I’m sure it’s in this post somewhere, but I’m lazy. Lol.
Thanks and keep up the great work
hessc50 is online now
post #378 of 388 Old 05-30-2020, 09:52 AM - Thread Starter
MKtheater's Avatar
Liked: 3208
I took all those apart. I made vertical towers and now bookshelves. Using higher quality and more powerful woofer and tweeters results in less work and a smoother response. Overall cost is about the same. My single 12 can play as loud but much lower than the dual 10s. My single horn loaded silk dome equals 2 of the other tweets and even more down low.
post #379 of 388 Old 06-04-2020, 08:36 AM - Thread Starter
MKtheater's Avatar
Liked: 3208
trevordj likes this.
post #380 of 388 Old 06-04-2020, 06:10 PM
BP1Fanatic's Avatar
Quoted: 438 Post(s)
Liked: 408
Pretty!
post #381 of 388 Old 06-04-2020, 06:42 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
Pretty!
Thanks. They came out great and sound awesome!
post #382 of 388 Old 06-04-2020, 07:38 PM
Quoted: 159 Post(s)
Liked: 200
Great looking speakers, are they your design? What drivers did you use?
monty6400 is offline
post #383 of 388 Old 06-04-2020, 08:25 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
Yes, they are. They have a Morel silk dome tweeter and the Eminence LFA12.
monty6400 likes this.
post #384 of 388 Old 06-04-2020, 08:58 PM
trevordj's Avatar
Quoted: 169 Post(s)
Liked: 260
Theater 10.0
Those look great! Maybe I missed it, what type of paint/process did you use to finish them?
-Trevor
trevordj is offline
post #385 of 388 Old 06-04-2020, 09:48 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
I was impressed by the hammer sub thread finish and mimicked it. I changed a little based on paints Used and having miter locked joint edges.
post #386 of 388 Old 06-05-2020, 05:07 AM - Thread Starter
MKtheater's Avatar
Liked: 3208
This is the thread
https://www.avsforum.com/forum/155-d...ish-video.html
post #387 of 388 Old 06-27-2020, 04:03 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
here is another finished speaker. These are surrounds.
BP1Fanatic and monty6400 like this.
post #388 of 388 Old Today, 06:29 PM - Thread Starter
MKtheater's Avatar
Liked: 3208
I am working on another 10 and then maybe two more 10s with the horn tweeter. I will probably sell the set to some interested parties.
