How to use Passive Crossover Designer by Jeff Bagby - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #31 of 49 Old 06-12-2017, 09:51 PM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
Al Toid is offline
post #32 of 49 Old 06-19-2017, 12:08 PM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
I just added the 5th installment. I've already shown how to auto-populate a 2nd order crossover based off the frequency. Unfortunately, this only creates a Linkwitz-Riley, which is not always the best for the speakers you choose. In this video, I will go over the 4 different types of crossovers in this program (Bessel, Butterworth, Variable Q, Linkwitz-Riley), how to determine their component values. Each one of these crossovers will directly affect your final frequency response of the speaker you are building. So if the auto calculate does not get you your desired response, try a different 2nd order crossover.
Altzheimer likes this.
Al Toid is offline
post #33 of 49 Old 07-02-2017, 05:51 PM
LastButNotLeast's Avatar
Quoted: 2486 Post(s)
Liked: 2110
Originally Posted by Al Toid View Post
I did attempt to upload the file, but AVS forum is not allowing me to do so. It states it is an invalid file type. If I can think of another way to upload the file I will.
For future reference, if you just .zip the file, you can then upload it (as long as it's less than the max file limit; for bigger files, use a link to DropBox).
Michael
Al Toid likes this.
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #34 of 49 Old 07-04-2017, 09:04 AM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
Alright Guys, we are now on the 6th installment. In this video I will show how to properly determine a box size using either Passive Crossover Designer or WinISD. Feel free to ask any questions if you have any.
Al Toid is offline
post #35 of 49 Old 07-06-2017, 11:47 AM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2229
Here is the xsim tutorial we discussed. Its pretty technical and expects a good knowledge base but Ill eventually get to some simplified stuff. I also added your videos to a playlist that I can hopefully grow with more design software type tutorials.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #36 of 49 Old 07-06-2017, 11:53 AM
corradizo's Avatar
Quoted: 1532 Post(s)
Liked: 1589
corradizo is offline
post #37 of 49 Old 07-06-2017, 12:09 PM
Liked: 2229
Originally Posted by corradizo View Post
Wow guys!!!! Thank you!!
Gonna give XO design a whirl?
post #38 of 49 Old 07-06-2017, 12:37 PM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
https://youtu.be/Ccqij1DZafs
This is awesome! Thank you! I'll make sure to let everyone know you put this out there. If you don't mind, I'm going to add yours to the first page of this forum topic as well. As you best said, let's give some options
Al Toid is offline
post #39 of 49 Old 07-06-2017, 12:38 PM
corradizo's Avatar
Liked: 1589
I just learned to calculate phase alignment between subs and mains last night so why not?? ;-)
Al Toid likes this.
post #40 of 49 Old 07-07-2017, 04:17 PM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
Seriously. Why not? Plus it is fun to desing speakers, even if you never build them. And when you do finally get the courage to do it, the results can be quite rewarding.
Al Toid is offline
post #41 of 49 Old 07-07-2017, 04:35 PM
corradizo's Avatar
Liked: 1589
Agreed. I need to take the time to study the fundamentals as all that I know I've gleaned from forums. The tutorials are great, don't get me wrong. They are quite awesome but I would like to know the theory before I dive in.
post #42 of 49 Old 07-07-2017, 06:27 PM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
I completely agree. It is important to understand the fundamentals and how that changes/modifies your design. I am excited to see where this new leg of DIY takes you.
Al Toid is offline
post #43 of 49 Old 07-07-2017, 08:01 PM
Steve Hanna's Avatar
Quoted: 170 Post(s)
Liked: 101
There are some excellent books that could explain the theory and different networks. Fascinating subject. The secret sauce that sets the advanced designers apart from the cookbook readers.
Al Toid likes this.
Steve Hanna is offline
post #44 of 49 Old 08-14-2017, 12:51 PM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
Okay guys, last in the series is Phase and how to best calculate it in PCD. HEre is the link to the video. I hope this helps!
Steve Hanna and tuxedocivic like this.
Al Toid is offline
post #45 of 49 Old 01-12-2018, 01:57 AM
Quoted: 170 Post(s)
Liked: 101
Instead of SPL Copy try this:
How to use FPGraphTracer
FPGraphTracer download
http://labs.fprawn.com/index.php/fpgraphtracer/
post #46 of 49 Old 06-30-2018, 12:12 PM
Quoted: 66 Post(s)
Liked: 6
https://www.youtube.com/watch?v=NO8CHG2FSsY
Tried this one wish they would have went into more detail on Impedance i cant get it to properly do it
CrazyCramers is offline
post #47 of 49 Old 07-01-2018, 08:24 PM
Quoted: 66 Post(s)
Liked: 6
Will this help me with my issues? i cant get passive xover software to make a somewhat flat response and ive spent hours trying- i can tag you on post
post #48 of 49 Old 07-01-2018, 08:30 PM - Thread Starter
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
One common issue I see when people have issues with this, is they forget to reset the measurements on the graph (left hand side). Typically x axis stays the same, but you need to change your y-axis to ohms instead of spl.
If this isn't your problem, let me know what you are actually having issues with, so I can see if I can help.
Al Toid is offline
post #49 of 49 Old 07-02-2018, 07:15 AM
Liked: 2229
Im not sure what your issue is, but it the problem is getting the drivers to work together and get a good result then it wont matter what program you use. If it is something to do with the PCD software not working for you then I would definitely try Xsim. It's a pretty good software.
Sent from my SGH-I337M using Tapatalk
