NU6000DSP Amp Rundown... - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 580Likes
post #271 of 426 Old 03-05-2018, 05:46 AM
Mike Butny's Avatar
Quoted: 1096 Post(s)
Liked: 2445
Originally Posted by Shreds View Post
Try the LS12 at +6dB to +8dB at around 35-40Hz. Just a guess but probably a better one. Get a mic dude.
Is that before or after running Audy? House curve?
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7013 Receiver, 3-Marantz Ma700 and 2-Ma6100 monoblocks, 7.4.2 Atmos, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, 2 Volt 6 Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, 2 LaVoce 21inch Neo DIY subs and 2 PSA S3600I'S.
Mike Butny is online now
post #272 of 426 Old 03-05-2018, 05:55 AM
Mike Butny's Avatar
Liked: 2445
Originally Posted by Mike Butny View Post
I decided to move the sub to a new spot which tamed the peak. I used 5 filters but did not use the LS6 or LS12. I'm thinking if I did Audy would try and tame it. Thanks for the continued help. Should I leave it alone or add another filter?
@Shreds
Name:	iNuke DSP REW.PNG
ID:	2370838   Click image for larger version
Name:	iNukeDSP Screen Shot.PNG
post #273 of 426 Old 03-05-2018, 08:49 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
No, I'm not into house curves. This was just a blind guess for getting your sealed sub flat to under 10Hz. I recommended it before you got your mic up and running. Now that you've got your response looking good and Audy has done it's thing I would only apply one more filter to flatten out the response of the amp. A 20Hz high shelf filter at 6dB/octave to -2.5dB will flatten out the rolloff of the nuke's response and help bring 10Hz and under up a little in response. You will have to re-calibrate the trim level of the sub to counter the attenuation of the shelf by 2.5dB.
Any newbs reading this should note that this is advice for sealed subs only.
Shreds is offline
post #274 of 426 Old 03-06-2018, 01:11 PM
Mike Butny's Avatar
Liked: 2445
Do I apply this before or after running Audy? Thanks again for your help.
post #275 of 426 Old 03-06-2018, 08:47 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
After. Your graph you posted was after Audy and it looks to be fine. So it should just be one more filter and you're done. How are you liking the sound so far?
Shreds is offline
post #276 of 426 Old 03-06-2018, 10:22 PM
Mike Butny's Avatar
Liked: 2445
That Graph was before Audy. Everything sounds very good but I can't wait for the UM18's to be back so I can have a sub in each corner of the room. 4 18" drivers and 2 15" drivers in a 2300cu room should sound sweet. So should I apply that filter now and re-run Audy?
post #277 of 426 Old 03-06-2018, 10:46 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
It shouldn't really make a difference because we're talking so low of a frequency band which Audy isn't really designed to focus on. You can do it both ways and see which way graphs better. Either way though double check it with your mic and a rew sweep. Post the graph when you get a chance.
Mike Butny and biga6761 like this.
Shreds is offline
post #278 of 426 Old 03-13-2018, 07:29 AM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
Originally Posted by 04rex View Post
Hey guys. I recently ordered one of these amps (I am planning on getting 2) from BestBuy Canada. I heard the fan noise was very loud, as mentioned above, so I wanted to see how loud it was. When I plugged it in, to my surprise the fan noise was actually very quiet. To the point where it is just as quiet as my CV-5000 which I did the fan mod on. I heard that newer models have upgraded fans or something. Are the fans variable speed where it will get faster and louder with more heat or use? All I connected was power, no subs or other wiring just to see how loud it was.
If this is how loud the fans are, then maybe anyone ordering from Parts-Express is getting older models that do not have the upgraded fans or something. The way it is, there is no way I would switch out the fans.
I have only purchased 1, will hopefully purchase the second soon. I won't be able to actually hook it up for a while though.
Just an update on this. I purchased my second one, and it is the same. The fans are silent on it as well. I still have not put any of them through their paces, but when I plug them in, they are silent. One of the amps was running 2 subs in 4 Ohms each at low volume just to check the subs, and the sound of the fans remained the same. Obviously that isn't pushing it hard, but I did have them connected and running.
Purenv likes this.
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 720, Apple TV, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v5, 690 v5, 10x4 v5, Anthem AVM 60, Outlaw Audio 7700 & 7125, 2x JTR Captivator S2s, X-Box One X, Apple TV 4K, HTPC, JVC NX-5, 106" screen
04rex is offline
post #279 of 426 Old 03-13-2018, 10:47 AM
Augerhandle's Avatar
Quoted: 1249 Post(s)
Liked: 1249
My NU3000DSP ramps up the speed when being pushed hard. During quiet passages one can hear it slow back down.
Purenv likes this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #280 of 426 Old 03-15-2018, 07:39 AM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
I am hopefully going to start playing around with the amps this weekend.
So to start off, would I essentially turn the outer knobs fully clockwise, then put the internal limiter at about -3? I will be running a 15" Sealed Ultimax in 4 ohms off each channel. I have a each pair connected together with each pair in different parts of the room. So essentially acting as 2 subs instead of 4 individual.
I would also change the signal to stereo so I can calibrate a pair as 1 correct? By doing this do i still need to connect both inputs or will it merge them together?
Thanks for the help.
04rex is offline
post #281 of 426 Old 03-17-2018, 12:19 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
OK so I just upgraded my receiver to a yamaha rx-a2070 the automatic calibration goes to 31hz but you can manually adjust to 15.6hz, this os new to me to heat about the reverse phase on the 6000dsp. Im using it to power 2ultimax 15s. I have a couple questions for running the auto calibration, should I set the front knobs of the amp fully clockwise? And I'm trying to give the sub's a clean 700rms at 4ohms also should I run them in mono or stereo? The receiver gives you bands you can set with different hz. Maybe I should have gone with auddessy xt32? �� I don't have a umik mic trying to get one borrowed. Also is the setting you posted a cheat sheet for the 20hz?
ID:	2376486   Click image for larger version
ID:	2376488   Click image for larger version
Joe879 is offline
post #282 of 426 Old 04-04-2018, 09:41 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
OK, where my sealed guys at?
If you set a 20Hz high shelf filter at 6dB/octave to -2.5dB, you can make the response of the nuke flat to 10Hz:
Green: Amp response with no EQ into 4 ohm load -starts rolling off at 42Hz, 1dB down @15.7Hz, 3dB down @6.6Hz
White: Low end extender curve into same load -starts rolling off at 9.6Hz, 1dB down @6.1Hz, 3dB down @3.2Hz
For those of you sealed guys with a more advanced skill set who have measured the rolloff of their signal chain with loopbacks in REW and need to compensate for the cumulative rolloff of your components or of just your AVR's sub output, I came up with a few options to bring back up the ULF:
Yellow: Flat amp response
Purple: 20Hz, 6dB/octave high shelf at -4dB
Red: 20Hz, 6dB/octave high shelf at -6dB
Teal: 20Hz, 6dB/octave high shelf at -10dB
Grey: 20Hz, 6dB/octave high shelf at -12dB
Green: 20Hz, 12dB/octave high shelf at -10dB
For the above rolloff boosters, I'd recommend testing with worst case scenario content (ULF) and ease up the level while monitoring excursion just to make sure you're not going to put yourself in a dangerous situation with your drivers. As with the HPF cheats, the low shelf attenuation will raise the noise floor and you will have to re-calibrate your sub level. I recommend doing that by using the front knobs on the amp (or worst case the gain in the DSP) as opposed to maxing out your AVR trim as this has shown problems with clipping strong re-directed bass signals in all of the AVR's that I've tested.
Where do I enter this information in?
Sent from my SM-G935T using Tapatalk
Joe879 is offline
post #283 of 426 Old 04-04-2018, 10:41 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
Use the HS12 or HS6 depending on what curve you're after.
HS12 =high shelf 12dB/octave
HS6 =high shelf 6dB/octave
All of them are at 20Hz. Adjust the gain (attenuate) to match desired curve. Re-calibrate sub level when finished.
biga6761 likes this.
Shreds is offline
post #284 of 426 Old 04-05-2018, 01:39 AM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Thank you
Joe879 is offline
post #285 of 426 Old 05-02-2018, 12:11 PM
Liked: 0
Nu6000dsp help with hpf cheat--lowering others
Hello I have followed the posts about the NU6000DSP high pass cheat in this thread here
https://www.avsforum.com/forum/155-di...p-rundown.html
I have set it to Butterworth 12/db and HS12, as I lower the db level to set it to 15hz high pass its almost as if there is still a huge filter on them at 20hz. I have make up an PEQ of 30,35,40,45,50 so I can lower the other frequencies to match the level of sub 20hz after the HPF is in effect.
Is this normal? Did everyone else have to lower other frequencies as well to get the response flat?
Thanks Eric
killahertz357 is offline
post #286 of 426 Old 05-02-2018, 09:59 PM
Liked: 1249
Thanks Eric
What kind of subwoofer? Driver? Post pics of your DSP settings please.
post #287 of 426 Old 05-02-2018, 10:02 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
I don't understand what you mean by this. It looks like for a 15Hz high pass, you'd be shooting for a -7dB to -8dB high shelf attenuation. Are you saying that when you do this, the knee of the high pass cutoff doesn't change?
Shreds is offline
post #288 of 426 Old 05-03-2018, 09:22 AM
corradizo's Avatar
Quoted: 1537 Post(s)
Liked: 1598
Shreds, would using an LS12 @ 20hz +6db along with the bw12 HP achieve the same thing as using the HS12 with neg gain?
corradizo is offline
post #289 of 426 Old 05-03-2018, 08:24 PM
Quoted: 2800 Post(s)
Liked: 11953
No, because HS and LS filters set to the same frequency have different knees.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #290 of 426 Old 05-03-2018, 09:33 PM
Liked: 0
When I put on the high shelf to -8 with the butterworth turned on at -12db at 20hz it almost sounds like its cutting off right at 20hz and its a lot quieter then 20hz and up. VS the 15hz or 12hz or whatever I would like to set it too. Maybe the shelf is just not steep enough and effects 20hz still?
I have to make up PEQ's to bring down 25-50hz because after I turned the the HS12 to -3 or more (-5 , -7) I had to basically crank the gain to get it to sound as loud at other frequencies then when its off. I also have to bring the other frequencies down because they are loud as F compared to 20hz.
post #291 of 426 Old 05-03-2018, 09:34 PM
Liked: 0
The graph states its supposed to be flat still from 15hz and up, past 20hz.. but in my testing its not at all. No idea whats going on. and the other frequencies are louder and I have to bring them way down. I also peak at 18hz in my room. With the filters right off, it sounds a lot better. I am worried for movies though when I have it cranked up. So I set up a windows program called Equalizer APO and was able to bring down the 1-10hz region with that surprisingly. Works pretty good to be honest.
post #292 of 426 Old 05-05-2018, 07:19 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
What do you mean bw12?
Shreds is offline
post #293 of 426 Old 05-05-2018, 07:23 PM
corradizo's Avatar
Liked: 1598
Butterworth 2nd order
post #294 of 426 Old 05-05-2018, 07:40 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
Nothing should be put to -12dB. You might be talking about the gain in which case things would be messed up. Just to make sure your settings should look like this:
Then you will have to use the knobs on the front of the amp to boost up the gain roughly about 8dB when you re-calibrate your sub channel to your mains. Then use the AVR's trim to fine tune the sub level.
If you do this it will lower the pole of the high pass, no doubt about it. If you're still having trouble, remember: a picture is worth a thousand words. Post some measurements and settings screens of what you're talking about and we'll definitely be able to figure out what's going on.
ID:	2400692   Click image for larger version
Shreds is offline
post #295 of 426 Old 05-05-2018, 08:07 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
Here is a 20Hz low shelf boost of 6dB and the bw12 HP at 20Hz:
So it would be these two responses summed together. You might be right that this is another way to approach lowering the high pass filter. It wouldn't be exactly the same but it may achieve the desired result more or less without using attenuation. It'd be an interesting experiment to see what it does to a real system at listening position. If you feel up to the challenge feel free to post the results here.
Someday I'll go back and do the loopback of the amp using this method and see what I can get going. Good job thinking outside the box Corr.
Shreds is offline
post #296 of 426 Old 05-05-2018, 08:26 PM
corradizo's Avatar
Liked: 1598
Thanks but I can take no credit. This idea was convyed by Mark Seaton in his write up regarding the B&C 21DS115-4 subwoofer project he worked on. I'll take some time soon to try the hp both ways and will report back.
Link to the write-up: http://www.seaton-sound-forum.com/po...binets-8429422
post #297 of 426 Old 05-05-2018, 09:06 PM
Liked: 11953
Assuming I understood corradizo's original question correctly, which was using a positive LS12 in lieu of a negative HS12, I can't help but wonder why this is being considered a novel idea. The main reason for using a negative HS instead of a positive LS is because on this DSP the HS filters have their knee lower than on the LS filters. As a result, a HS filter @ 20Hz behaves as the inverse of a LS filter that is set lower than 20Hz, essentially allowing you to accomplish what a LS filter would at a lower frequency than the DSP allows you to set. How low the knee ends up is determined by how much negative gain is used.
The different knee may have been a bug. AFAIK many or most other DSPs define the knees of their LS and HS filters identically. In any case, it works out really well to enhance the iNukes' functionality.
post #298 of 426 Old 05-05-2018, 09:50 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 632
Just being supportive in the name of experimentation.
Right. So what better way to find other bugs than through testing different things in the system? I agree with you though, you will definitely loose the Butterworth curve. By the way aron, how's the system doing these days, I haven't kept track.
Shreds is offline
post #299 of 426 Old 05-06-2018, 02:33 PM
Liked: 0
Shreds did you miss a photo in this comment? "should look like this" ?
I need a high pass filter of about 14hz or so for tapped horn. Correct me if I am wrong, Set Highpass to Butterworth 12db, then a HS12 to -7 or so to achieve a highpass under 20hz?
When I do that, I have to basically crank the gain because it is very quiet compared to before. It also sounds like its cutting off 20hz still when in the graphs it shows it should still be flat. Is this normal? Am I doing something wrong here?
If there are others ways to do it please let me know. Thanks and sorry for the confusion
post #300 of 426 Old 05-06-2018, 03:31 PM
corradizo's Avatar
Liked: 1598
@eng-399 visited today. The filter definitely protected the drivers. We didn't have time to test and measure, I'll do that as promised in follow up.
eng-399, biga6761 and unretarded like this.
