NU6000DSP Amp Rundown... - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 578Likes
post #361 of 391 Old 09-30-2018, 01:04 PM
michael hurd's Avatar
Quoted: 634 Post(s)
Liked: 669
Originally Posted by jasonmichaelh View Post
I have two sealed UM18-22’s driven by an inuke 6000dsp. One of the speakon connections on the inuke is flakey (intermittent connection follows the connector on the inuke, not the speaker cable or sub or inputs).
If I lock the speakon in place, I get no signal. I have to back it off like an 1/8th of a turn, and if it moves at all I have to reposition it to get “sub2” back.
Anyone else had this problem with inuke or other speakon connections? My inuke is fan modified, so I can’t send it for warranty. Thanks.
Just a quick question, genuine Neutrik SpeakON connectors, or 'might work'? Never had a problem in the past with a genuine Neutrik SpeakON.
bscool likes this.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #362 of 391 Old 09-30-2018, 01:16 PM
jasonmichaelh's Avatar
Quoted: 349 Post(s)
Liked: 164
Originally Posted by Augerhandle View Post
Did you swap Sub 1 and Sub 2 cables at the iNuke?
Yes
System I | Sony 75Z9D | Oppo BDP-203 and 103D | ATV5 | Energy Veritas 1.8 (LR) | 2.0 (C) | 2.0R (S+SB) | Mirage OMD-5 (FH, RH)
Yamaha CX-A5100 | MX-A5000 x 2 | Dayton UM18-22 Sealed x2 w/ iNuke 6000DSP | Panamax Power 360 Strip
System II | Sony 75Z9D | ATV5 | Denon AVR-A100 | NAD T973 | Mirage OMD-28, OMD C2, OMD-5 | SVS PB12+/2
jasonmichaelh is offline
post #363 of 391 Old 09-30-2018, 01:32 PM
Quoted: 349 Post(s)
Liked: 164
I’m using GLS Audio connectors on my speaker wire. I suppose it’s possible the “failing” sub2 out inuke connector will work with a genuine neutrik. However, the other channel/connector (sub1 out) on the inuke works fine with three different cables made with GLS connectors, all of which fail on sub2 output. That would seem to indicate the GLS connectors are good, and the inuke sub2 connector is bad. I’ll try a neutrik connector and if that doesn’t work I may need to replace the connector in the inuke.
post #364 of 391 Old 10-01-2018, 06:00 PM
Nitropro's Avatar
Liked: 26
I might have damaged my iNuke 6000dsp on the weekend or my subs, not sure which yet..
Pushed hard during one point of a song for ~20seconds.
Didn't see the volume knobs turn red and then no more output at the subs (UM18 in 4.7cuft sealed x2).
The iNuke still turns on and performs all the usual relay clicks and the light indicators work (as if sending signal) although no sound. Problem solving starts tonight, any tips are much appreciated.
Nitropro is offline
post #365 of 391 Old 10-01-2018, 07:24 PM
notnyt's Avatar
Quoted: 3728 Post(s)
Liked: 3697
put a volt meter on the inuke output and see if there's ac voltage when you output a sine wave. If so, start checking your woofers.
biga6761 likes this.
notnyt is offline
post #366 of 391 Old 10-01-2018, 07:31 PM
brettus's Avatar
Quoted: 44 Post(s)
Liked: 30
Subs probably popped a coil. Test impedance with a multimeter or a AA battery on each coil if you don't have a MM.
Sent from my A0001 using Tapatalk
brettus is offline
post #367 of 391 Old 10-01-2018, 07:51 PM
corradizo's Avatar
Quoted: 1523 Post(s)
Liked: 1580
Put 9v battery to the subs terminals to see if it moves.
corradizo is online now
post #368 of 391 Old 10-02-2018, 05:02 PM
Nitropro's Avatar
Liked: 26
Thanks for the tips fellas.
UM18 RIP 2018
azz7686, LGERIC and bebb like this.
Nitropro is offline
post #369 of 391 Old 10-02-2018, 05:47 PM
corradizo's Avatar
Liked: 1580
post #370 of 391 Old 10-03-2018, 04:37 PM
Quoted: 349 Post(s)
Liked: 164
Thanks for the suggestion!
Replaced my GLS connector with a genuine Neutrik and no more connection problem! The Neutrik connector feels much better in hand and seems to be a much higher quality product, at about 2x the cost of the GLS knock-off.
post #371 of 391 Old 10-03-2018, 05:19 PM
Quoted: 634 Post(s)
Liked: 669
Good to know! Parts express is about the best source for low priced Neutrik SpeakON connectors.
LTD02, notnyt and biga6761 like this.
post #372 of 391 Old 10-05-2018, 01:24 PM
Fackamato's Avatar
Quoted: 122 Post(s)
Liked: 48
How come the drivers cooked? Aren't they supposed to handle the iNUKE power (way less than 2kw per channel)?
Clipped signal?
Sent from my Pixel XL using Tapatalk
LG OLED55C6P calibrated
Denon X4400H 5.2.4
Denovo HTM-10
HSU Research surrounds
2x18" Dayton Ultimax sealed < Pro-LITE 7.5 amp < MiniDSP 2x4 HD
Fackamato is offline
post #373 of 391 Old 10-07-2018, 11:09 AM
azz7686's Avatar
Quoted: 279 Post(s)
Liked: 125
Well Clipping will kill it and overheat the coil!
You were using in a 4' sealed enclosure?
Spoiler!
azz7686 is offline
post #374 of 391 Old 10-08-2018, 04:49 PM
Nitropro's Avatar
Liked: 26
4.7' sealed.
I incorrectly wired the subs in a moment of stupidity. Only connecting one set of terminals
Popped the lead in wire going over the spider.
Don't think there is any coil damage, still investigating.
Nitropro is offline
post #375 of 391 Old 10-13-2018, 06:23 PM
azz7686's Avatar
Quoted: 279 Post(s)
Liked: 125
I was curious on size cause I have one in a sealed enclosure and the other in a ported one and the sealed I can hear it struggling and I now keep the gain lower on that one untill I build my matching ported enclosure.
Spoiler!
azz7686 is offline
post #376 of 391 Old 10-14-2018, 10:38 AM
Nalleh's Avatar
Quoted: 2403 Post(s)
Liked: 3132
I guess i can put the pics up here too. The NU replacement: NX seems to have the same parts inside, so they should perform the same as the outgoing ones.
Originally Posted by Nalleh View Post
Swapped the fans for Noctua’s on my new NX6K and took some pics vs NU6K. Looks the same inside, the right circuit board even has the same number.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #377 of 391 Old 10-14-2018, 11:33 AM
BCRSS's Avatar
Quoted: 491 Post(s)
Liked: 455
Looks as they down rated the output on 4Ohm.
chiptouz likes this.
BCRSS is offline
post #378 of 391 Old 10-14-2018, 02:18 PM
chiptouz's Avatar
Quoted: 262 Post(s)
Liked: 313
@Nalleh - did the noctua fans lower the overall sound level? BTW where did you get the nx6000d? All the sites I see say 11/9 date. Oh and what size fans did you use?
My Movie Library - and still growing!
Family Room: Sony XBR-85x900F + Denon 4520ci + Oppo 203, Speakers: LCR: DIYSG Elusive 1099's, S(R+RS) Polk TC60i, Sub: 2x LTD02 Designed UM18-22 Subs w/Nx6000d
Considering: DIYSG Volt10v2 for FH, CH, and Surrounds
chiptouz is offline
post #379 of 391 Old 10-14-2018, 03:06 PM
Nalleh's Avatar
Liked: 3132
Yes, they did, that why i swapped them I have used various Noctuas earlier, but now got these:
https://noctua.at/en/nf-a8-flx
These are dead silent, and comes with several low noise filter you can use, depending on your need. And cheap .
This is not the D model, it is a regular NX6000 (no DSP) version. I got a open box from :
https://www.gear4music.com/us/en/PA-...Amplifier/2G7Z
(Only from the Norwegian division)
Nalleh’s HT
Nalleh is offline
post #380 of 391 Old 10-14-2018, 05:17 PM
bebb's Avatar
Quoted: 221 Post(s)
Liked: 156
Clipped signal?
Actually, at 4 ohms, the inuke 6k does not put out way less than 2kW per channel. It is actually slightly over based on the testing done by BigDWiz on youtube.
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #381 of 391 Old 10-14-2018, 05:29 PM
Fackamato's Avatar
Quoted: 122 Post(s)
Liked: 48
Here's a more accurate test: https://www.avsforum.com/forum/155-d...l#post51012305
4 ohm, 1211 watts per channel (1529 burst) at 40Hz.
Denon X4400H 5.2.4
Denovo HTM-10
post #382 of 391 Old 10-14-2018, 06:13 PM
corradizo's Avatar
Liked: 1580
Not sure what to believe. When @Ricci tested the x21 sub loaded with the 21DS115-4 on an iNuke 3kdsp bridged he indicated it went into protection at 77v at 3ohm which is close to 2000w output. So I think it can do more than 1200w in my application ( I have built 2 similar subs (but with a much bigger port).
https://data-bass.com/data?page=system&id=144&mset=168
post #383 of 391 Old 10-14-2018, 06:24 PM
Fackamato's Avatar
Quoted: 122 Post(s)
Liked: 48
Right. But that wasn't an iNuke 6000 running in stereo, it's not an apples to apples comparison.
Denon X4400H 5.2.4
Denovo HTM-10
post #384 of 391 Old 10-14-2018, 07:31 PM
bebb's Avatar
Quoted: 221 Post(s)
Liked: 156
Thanks. That does look more comprehensive. It is at 4.4 ohms though. I expect 4 ohms would be slightly more.
bebb is offline
post #385 of 391 Old 10-21-2018, 07:20 PM - Thread Starter
Shreds's Avatar
Quoted: 571 Post(s)
Liked: 631
Hey Nal, nice to see you again and great work, I appreciate it. I'm going to link this post on the front page of this thread.
Nalleh likes this.
Shreds is offline
post #386 of 391 Old 01-04-2019, 11:24 AM
randyc1's Avatar
Quoted: 249 Post(s)
Liked: 42
...Anyone know how to (Delete Amp Presets) in Setup ??
randyc1 is offline
post #387 of 391 Old 01-04-2019, 11:27 AM
Augerhandle's Avatar
Quoted: 1148 Post(s)
Liked: 1140
https://www.avsforum.com/forum/155-d...l#post57376796
randyc1 likes this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #388 of 391 Old 01-23-2019, 10:44 AM
mcallister's Avatar
Quoted: 203 Post(s)
Liked: 78
Just to double check, if my inuke is wired out of phase just changing around the inputs on the sub will “fix” the issue or is there more too it?
mcallister is offline
post #389 of 391 Old 01-23-2019, 08:19 PM
notnyt's Avatar
Liked: 3697
that's it.
notnyt is offline
post #390 of 391 Old 02-22-2019, 03:43 PM
jcmccorm's Avatar
Quoted: 594 Post(s)
Liked: 443
Hey guys, quick question/observation.
I've been setting up my NU6000D for 180 phase from info in this thread. I've been matching my subs to the mains by tweaking distance and looking at REW sweeps to decide when it's right. I recently added a second sub and decided to look at REW phase and impulse graphs to see where the subs were at. The numbers for distance were out of whack.
This prompted me to check my RCA<->XLR cable from monoprice and ohm it out. The "hot" signal (center pin of the RCA) lines up with the "hot" pin indicated in the 6000 manual:
Furthermore, I downloaded the Polarity Test wav file in this thread (thank you!) and sure enough, the drivers were being "sucked in" on the pulses.
So at least for me (and my cable), I don't need to set the NU6000D to 180 phase. I've been running with 180 phase for a while so it's kind of a mind-blow. I'm off to change phase and go through the whole deal again....
IAH likes this.
jcmccorm is offline
