MiniMarty dimensions please help - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By FriscoDTM
  • 1 Post By Augerhandle
post #1 of 3 Old 08-28-2017, 03:10 PM - Thread Starter
Quoted: 67 Post(s)
Hi, I am about to start cutting the wood to build 2 minimartys but I found 2 different blueprints and I need to know witch one is right before cutting. They have the same external dimension but different port size. 1 set show a port height of 3 inches and the other one show a port height of 2.5 inches. They also vary in length.
Port set #1: 3 x 47.5
PORT set #2: 2.5 x 44.75
Please advice in order to start the project. Thanks.
Jonathan Pacheco Vasquez is offline
post #2 of 3 Old 08-30-2017, 07:51 PM
FriscoDTM's Avatar
Quoted: 432 Post(s)
Liked: 391
You probably want to decide the port dimensions based on the specific driver and amp you are have, using WinISD. You want to keep the first port resonance high enough that it doesn't reduce output from the sub, and you want the port cross section large enough so you don't hear audible chuffing at max power. Both can depend on the particulars, so you really want to model it.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #3 of 3 Old 08-30-2017, 11:09 PM
Augerhandle's Avatar
Quoted: 1252 Post(s)
Liked: 1254
Go with the revised cutlist (2.5 x 44.75).
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
marty , minimarty
