Converting Monoprice Passive 15" 2-Way PA Speakers to Active - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #61 of 74 Old 10-29-2017, 08:16 AM
LastButNotLeast's Avatar
Quoted: 2486 Post(s)
Liked: 2110
But it could be a good option for some people.
Me!
So, if it's not too much trouble,...
Michael
tuxedocivic likes this.
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #62 of 74 Old 10-29-2017, 06:38 PM
Liked: 0
What a total waste of time...but I guess someone had to find something to do, I prefer to build my own or purchase a pair of higher quality.
William Colon is offline
post #63 of 74 Old 10-29-2017, 07:52 PM
Liked: 2110
I've built my own. Didn't enjoy it one bit, and don't use them.
"Higher quality" is relative. I think one would have to spend substantially more than the cost of these for a noticeable improvement.
As a hobby, I guess it qualifies as "something to do." I enjoy using REW and HCFR, and have done a pretty good job with the open floorplan, vaulted ceiling with skylights, minimal investment that I've had with which to work.
I'm not asking you to waste your time. I was just looking for something else interesting to do with mine.
Michael
post #64 of 74 Old 10-30-2017, 06:42 AM
Liked: 2110
Sorry, but did you mean Mark's experiment with active crossovers (which he clearly discusses as an experiment and does not suggest that everyone do this) or my desire to modify the existing passive crossovers (which might, indeed, be of interest to those of us who own these speakers)?
Michael
post #65 of 74 Old 10-30-2017, 07:03 AM
Liked: 2110
Mtg90 did that for the berry thingys.
Found it:
https://www.avsforum.com/forum/89-spe...l#post36330378
In the case of the Monos, we're looking to drop it from 3300 to 1000; might be too much of a change to be "simple."
Michael
post #66 of 74 Old 10-30-2017, 12:50 PM
arsenalgunner's Avatar
Quoted: 18 Post(s)
I'm getting veklempt. Talk amongst yourselves. Here's a topic: "These 'Active' monoprice PA Speakers are neither active nor speakers". Discuss.
arsenalgunner is offline
post #67 of 74 Old 10-30-2017, 01:22 PM
Liked: 2110
Mark's setup is active. The speakers are great bang-for-the-buck (passive) home theater speakers.
Not much to discuss.
Unt vy are you so emotional?
Michael
post #68 of 74 Old 11-04-2017, 12:57 PM
Liked: 4
Sub Crossover
@imagic Is there a reason you used the Denon AVR to cross the low end at 80hz as opposed to using the DDRC-88A?
@tuxedocivic Is there any benefit to the XO adjustability of the DDRC-88A (w/ Dirac Live) compared to passive XOs? I'd assume digital tuning of the XOs would be easier than buying and soldering up passive components until you find the right combo, albeit more expensive.
rdh24 is offline
post #69 of 74 Old 11-04-2017, 01:29 PM
Liked: 2110
Originally Posted by rdh24 View Post
buying and soldering up passive components until you find the right combo.
There is actually a science behind it. A complicated science and art.
Which is why I was hoping modifying/changing the existing xo would be cost-effective. Apparently, it isn't.
Michael
post #70 of 74 Old 11-04-2017, 03:08 PM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2229
There is a very small benefit that if you're more techy and prefer to change the XO on the computer then it's a benefit. To be honest, using alligator clips I can make a change to my passive XO much faster than hooking up my minidsp, launching the software, syncing, and changing the settings.
I hear this logic all the time. Active is easier cause you can make many changes quickly. Well first of all, you shouldn't make XO changes every few seconds. You should make them every few days during the design process. Second, this logic should never be a reason to choose active over passive. The choice should be made based on design goals. If the design goal is to get razor sharp frequency response with steeps slopes (a perfectly good goal) then active is probably a better choice provided a different goal is portability or simplicity. When people choose to go active because they can click buttons I automatically know they've missed the point. Thankfully, most of the time they have more reasons than the ease of button clicking.
Sent from my SGH-I337M using Tapatalk
PrimeTime likes this.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #71 of 74 Old 11-06-2017, 10:06 AM
Liked: 2110
This is a post in the original thread from 18Hurts (post 9):
"The 3.3 KHz crossover is rather funky--but you have a quick and dirty way to drop it down to approx. 1.6 to 1.7 KHz. Remove both XO boards, take the coils and caps off the second one and put the caps in parallel and the coils in series to drop it around an octave."
I wouldn't sacrifice one xo for another, but I could certainly spring for parts.
But, again, I don't know what I'm talking about.
Thoughts?
Michael
post #72 of 74 Old 11-06-2017, 02:56 PM
Liked: 2229
Thoughts?
Michael
Sounds like using a simple rule of bigger parts equals lower XO but could also cause a giant null or an erratic response. If you wanna try it sure just don't expect good results and I suggest trying to measure it.
post #73 of 74 Old 11-06-2017, 05:08 PM
Liked: 2110
I'm happy with the way it measures now. I will leave well enough alone.
Many thanks.
Michael
post #74 of 74 Old 12-11-2017, 07:09 AM
Liked: 2110
20% off today only:
20GREEN
Michael
15" pa speakers , active speakers , Monoprice
