Modelling Request: PA460-8 in 4cf sealed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-25-2017, 02:55 PM - Thread Starter
ZLTFUL's Avatar
Quoted: 329 Post(s)
Liked: 296
As the title suggests, can someone model the Dayton PA460-8 in a 4cf sealed enclosure at 400-600 watts?
I know this leaves performance on the table and isn't the ideal usage of this woofer but I am piecing together a strange scenario for this build that requires low cost, simple build for a friend.
Power will be a 400-600 wpc @8ohm "budget" pro-amp.
I just don't have the means to model this currently.
Thanks in advance for any assistance.
I keep confusing my intentions with my abilities.
The Blank Slate Cinema/MacGillvray Pub Build Thread
ZLTFUL is online now
post #2 of 2 Old 10-25-2017, 06:17 PM
EndersShadow's Avatar
Quoted: 1268 Post(s)
Liked: 1537
Can do........ Give me a few mins and then check your email...
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
