New DIY Sound Group Jeff Bagby kit - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 80Likes
post #121 of 137 Old 12-26-2017, 06:55 PM
mikeTRON250LM's Avatar
Quoted: 418 Post(s)
Liked: 343
Originally Posted by datranz View Post
Honestly, this one of the best small speaker I?ve ever heard reguadless of price
What is this?
Sent from my SM-G935P using Tapatalk
mikeTRON250LM is offline
post #122 of 137 Old 12-26-2017, 06:59 PM
Steve Hanna's Avatar
Quoted: 170 Post(s)
Liked: 101
Domes are smooth with consistent dispersion in all directions. They're rarely offensive cause they have a smooth frequency response and generally low distortion. They are low sensitivity though, so can't handle dynamics as well as the others.
Compression drivers have the hardest response to work with and can cause offensive sounds if they don't get filtered properly. But their huge efficiency provides insane dynamics. The dispersion is related to the chosen horn, but it's always much narrower than a dome (usually that's a good thing). They usually have bad response above 10khz.
Ribbons have high distortion at lower frequencies (below 3khz about). But have good sensitivity. Above the area of bad distortion they have very low distortion and extend well beyond 20khz. Their sensitive isn't like a CD but is still quite high and has good dynamics for the most part. The dispersion is wide like a dome horizontally but narrow vertically depending on the ribbon height mostly. Their dispersion and low end capability makes them a hard choice but if used properly are thought to have the highest reward.
I have reviews of 3 ribbons on my youtube channel if you want to see more about them. I plan on using a ribbon in a 3 way tower so I've been testing them a lot.
There are also the AMT air motion transformer diaphragm tweeters that are similar to ribbon designs. They can be crossed lower.
Steve Hanna is offline
post #123 of 137 Old 12-26-2017, 08:14 PM
datranz's Avatar
Quoted: 63 Post(s)
Liked: 48
Originally Posted by mikeTRON250LM View Post
What is this?
http://www.diysoundgroup.com/speaker...dster-kit.html
mikeTRON250LM likes this.
datranz is offline
post #124 of 137 Old 01-02-2018, 10:05 AM
OSUCowboy1389's Avatar
Quoted: 14 Post(s)
Liked: 7
So I am currently looking for a center channel to go with my B&W 685 S2. I have a 6.5inch tall by 16.5inch wide by 19inch deep space that I would like to fit it in. I also have a ton of 3/4in MDF laying around that I would like to use for the build. I am wondering if any of these new kits might fit the bill? From what I have looked at the S2000 is the only one that would fit. I know dimensions are critical but could some modifications be made to fit my space and not negativly affect some of the other kits. Thanks in advance
Sent from my Pixel 2 using Tapatalk
OSUCowboy1389 is offline
post #125 of 137 Old 01-04-2018, 10:22 AM
PrimeTime's Avatar
Quoted: 786 Post(s)
Liked: 484
We often add sound absorption to our walls and floor coverings to dampen the reflections, then use a wide dispersion speaker. Doesn't always make sense.
It makes some sense if you have one of the more elaborate home theaters (group seating) where wide dispersion could be useful, or are attending a GTG.
For music listening, which is usually more intimate and has a midplane "sweet spot," it doesn't.
The waveguide/horn focuses the sound towards the listener and away from the reflection surfaces.
As do "oversized" mid-woofers putatively crossed too high.
PrimeTime is offline
post #126 of 137 Old 01-20-2018, 08:05 AM
Liked: 0
Failed Login
I'm having problems connecting to the DIY Sound Group page. I haven't been on there in awhile, but now when I go to their page, it asks for a username and a password, but I can't access the page, and I can't find anywhere to create an account. Anyone out there have any info/ help?
ctsmee is offline
post #127 of 137 Old 01-20-2018, 08:16 AM
Sean Mc's Avatar
Quoted: 49 Post(s)
Liked: 82
Message was up past couple days that Erich will be switching over to new website design this weekend. I think this gap in availability is part of the switch.
Sean Mc is offline
post #128 of 137 Old 01-20-2018, 11:35 AM
Quoted: 418 Post(s)
Liked: 343
I think that message has been up for 2 or 3 weeks now.
post #129 of 137 Old 01-20-2018, 11:39 AM
Sean Mc's Avatar
Quoted: 49 Post(s)
Liked: 82
I agree a "new website coming" note has been up for that long. I only recall the "it's happening this weekend" up for a couple of days.
Sean Mc is offline
post #130 of 137 Old 01-20-2018, 11:41 AM
Erich H's Avatar
Quoted: 1847 Post(s)
Liked: 2642
The new site is getting moved over today and tomorrow.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #131 of 137 Old 01-23-2018, 10:37 AM
gt5pilot's Avatar
Quoted: 26 Post(s)
Liked: 25
Still not up? Is there a new URL or will it be the same?
gt5pilot is offline
post #132 of 137 Old 01-23-2018, 11:18 AM
Quoted: 170 Post(s)
Liked: 101
He will get it done as soon as he can.
It's up now
post #133 of 137 Old 02-15-2018, 02:37 PM
Altheia's Avatar
Quoted: 54 Post(s)
Still don't know which speaker you are talking about. The link changed.
Altheia is offline
post #134 of 137 Old 02-15-2018, 03:25 PM
Quoted: 1007 Post(s)
Liked: 1257
Guessing it's this one: https://www.diysoundgroup.com/home-a...dster-kit.html
Pradeep2 is online now
post #135 of 137 Old 04-12-2018, 11:28 AM
Freddyknuckles's Avatar
Originally Posted by sandydankness View Post
About the 4/8 ohm question; is anybody who is willing to spend a grand or more on parts, take the time to build and finish a kit really going to be powering them off an avr?
I have an Yamaha RX-V781 AVR.
I would agree if we were talking about speakers a grand or more. But we are not talking exclusively about $1000 speakers.
I am interested in the S2000 MTMs which are $250 a pair and fall into the same budget conscious category as my mid range AVR. I'm sure there are lots of do-it-yourselfers in the same boat.
That being said, I think should be ok with the S2000s according to the Yamaha owners manual.
"When connecting 6-Ohm speakers, set the unit's speaker impedance to "6-Ohm min." In this case you can also use 4-Ohm speakers as the front speakers."
YMMV
Freddyknuckles is offline
post #136 of 137 Old 04-12-2018, 08:51 PM
atbroome's Avatar
Quoted: 181 Post(s)
Liked: 211
YMMV
For yamahas you shouldn't actually set the switch to low impedance. You end up with less power. It's there so Yamaha could meet an energy certification.
Vizio P65-C1
atbroome is offline
post #137 of 137 Old 04-12-2018, 09:22 PM
I do realize that but thank you for the advice. That is worth pointing out because if is an often misunderstood setting on Yamaha receivers.
My point was to show the 4 ohm reference but I left the full quote for context.
I guess I will take them at their word and try some 4 ohm
