New DIY Sound Group Jeff Bagby kit - AVS Forum | Home Theater Discussions And Reviews
 80Likes
post #1 of 137 Old 10-30-2017, 09:39 AM - Thread Starter
Buddylee123's Avatar
Quoted: 906 Post(s)
Liked: 622
Anyone checked out the DIY Sound Group page today? Erich has a bunch of info on some new kits that are in the works. The one that really caught my attention was the one by Jeff Bagby. I really want to build my first kit and this one has my attention because it uses a ribbon tweeter and a 7-inch woofer. I think these might be perfect for my living room. Heres the description "Jeff Bagby: MT using a nice 7" woofer with a Fountek ribbon tweeter. This one might take a little over a month." Anyone know that the MT stands for?
http://www.diysoundgroup.com/
filtor1 and mikeTRON250LM like this.
Buddylee123 is offline
post #2 of 137 Old 10-30-2017, 09:43 AM
Quoted: 26 Post(s)
The MT means it is using just a Mid and a Tweeter.
dunnkm2 is offline
post #3 of 137 Old 10-30-2017, 09:49 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Not sure which speaker you're referencing, but generally speaking MT stands for the driver arrangement with M = Mid and T= tweeter, so in this case MT = mid, tweeter or a 2-way design. Other iterations would be MTM, TMM, or TMW (W= woofer).
Check out my End-Table Marty Build
squiers007 is offline
post #4 of 137 Old 10-30-2017, 09:58 AM
Erich H's Avatar
Quoted: 1888 Post(s)
Liked: 2706
The TM from Jeff Bagby will be a bit longer than the other ones because we just decided which tweeters to use. I wasn't sure if I should put that one up or not because it's a little early still. The others are started or completed already.
The one I'm anxious to hear first will be the Anarchy model with the large Wavecor tweeters. Pete designs speakers for some good companies, one of which is Vapor Audio. He said he really liked the Anarchy woofers and the speakers can play very loud from around 35/40hz on up with gobs of bass output. The prototypes were are a speaker meet a couple weeks ago and people really liked them.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #5 of 137 Old 10-30-2017, 11:02 AM
JohnDean's Avatar
Quoted: 549 Post(s)
Liked: 259
I'd like to hear more about the HTM-8 "Possible dual woofer horizontal center channel."
18Hurts likes this.
JohnDean is offline
post #6 of 137 Old 10-30-2017, 11:10 AM
Erich H's Avatar
Liked: 2706
The HTM might be a dual 10" woofer center channel. It depends on how the 8" woofer works out.
18Hurts likes this.
Erich H is offline
post #7 of 137 Old 10-30-2017, 11:53 AM
corradizo's Avatar
Quoted: 1549 Post(s)
Liked: 1608
Mid/Tweeter I think. Can't wait to see these high output dome tweeter kits myself.
Sent from my SM-N900V using Tapatalk
corradizo is offline
post #8 of 137 Old 10-30-2017, 01:28 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 904
What's the target sensitivity on the Bagby ribbon kit?
Samps is offline
post #9 of 137 Old 10-30-2017, 01:43 PM - Thread Starter
Quoted: 906 Post(s)
Liked: 622
Thanks for the info Erich. Do you think the Anarchy model from Pete will perform better in a large room than the one from Jeff? These will be going in my main living area which is approximately 18'W X 25'L x 14'H.
post #10 of 137 Old 10-30-2017, 01:52 PM
Erich H's Avatar
Liked: 2706
The Anarchy model should play lower bass, and handle more power with the ability to play louder. It's got a very large Wavecor tweeter in a waveguide too. So it's going to be nice sounding brute of a speaker.
It could be built into a tower and play quite low. For occasional movies you could probably get away with no subwoofer as long as you weren't expecting room shaking bass under 30hz or so.
Erich H is offline
post #11 of 137 Old 10-30-2017, 01:53 PM - Thread Starter
Quoted: 906 Post(s)
Liked: 622
This will be a 2 channel setup and used mostly for music and light TV watching.
post #12 of 137 Old 10-30-2017, 02:26 PM
bgtighe23's Avatar
Quoted: 1846 Post(s)
Liked: 1231
Any larger tower offering to come? Seems like there are no tower kits featuring dome/ribbon tweeters.
@Erich H
Receiver : Denon x5200
Front Stage : L/R - Statements by Jim Holtz
Surround Speakers : Klipsch RF-82II x 4 / RP-280F x 2
Subwooferage : 6 UM18/4 HT18 Subwoofer Log
bgtighe23 is offline
post #13 of 137 Old 10-30-2017, 02:39 PM
Erich H's Avatar
Liked: 2706
What would be considered a large tower?
Erich H is offline
post #14 of 137 Old 10-30-2017, 02:58 PM
They_call_me_Roto's Avatar
Quoted: 353 Post(s)
Liked: 255
If you offered a 1099 kit with bamboo cabinets and either the RAAL 140-15 or 70-10 (70-10 might not have enough output to match the rest of the speaker), I would purchase three of them for a front soundstage speaker setup. Would be fairly easy to do. Take your current center speaker design of the 1099 and make a different cut for the tweeter to house the ribbon. That would be a left or right floostander. Then take the design for a L/R floorstander and cut the tweeter area for a ribbon and you have a center channel speaker.
I've wanted this since I first saw the 1099. I have never liked compression drivers, my ears seem to be sensitive to them.
Packing a lot of sound into a small room.
268 square feet/2144 cubic feet
7.2 surround sound.
They_call_me_Roto is offline
post #15 of 137 Old 10-30-2017, 03:01 PM
pgwalsh's Avatar
Quoted: 581 Post(s)
Liked: 423
Something as large as the Anthologies or Statements, IMO. I wouldn't mind seeing some full range 3-way designs for 2 channel listening. Then agian I can STFU since I now live in New Zealand and shipping to hear is not practical.
Cheers on the new designs, they sound really interesting.
pgwalsh is offline
post #16 of 137 Old 10-30-2017, 03:12 PM - Thread Starter
Quoted: 906 Post(s)
Liked: 622
I would love to see a tower kit like this offered but a little smaller, maybe 2 Anarchy woofers and a ribbon tweeter. I think the Anarchy woofers look good enough to not cover them and I am really liking the sound of ribbon tweeters.
post #17 of 137 Old 10-30-2017, 03:20 PM - Thread Starter
Quoted: 906 Post(s)
Liked: 622
Just looked these up, those would be nice!
post #18 of 137 Old 10-30-2017, 03:54 PM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2230
I've been dying to build a 3 way using dual Motus 8" woofers ever since I tested them on my YouTube channel. Plus a Fountek NeoX 3.0 ribbon and some mid I haven't settled on yet. Sound a lot like what you're describing and would be extremely hifi. I just gotta convince Erich
Sent from my SGH-I337M using Tapatalk
My youtube channel: Impulse Audio
tuxedocivic is offline
post #19 of 137 Old 10-30-2017, 04:04 PM
Erich H's Avatar
Liked: 2706
No convincing needed, just let me know the midrange and we'll get it rolling. I think you should also consider the round Neo cd3.0 as well, but not sure if you've compared the two. The smaller one might make a shorter center channel if anyone needed that.
Erich H is offline
post #20 of 137 Old 10-30-2017, 04:12 PM
corradizo's Avatar
Liked: 1608
post #21 of 137 Old 10-30-2017, 04:31 PM
pgwalsh's Avatar
Quoted: 581 Post(s)
Liked: 423
Hey there, nice woofers.
Tux,
I'm not sure if you've seen or viewed the Wavecore Ardent thread on HTGuide, but those speakers are a bit lust worthy. I wish they extended lower in the bass region for the price and I know there was talk doing a passive sub version possibly in the future. Biggest problem for me is the price and complexity of the crossover. I have read a lot of positive things about Beryllium dome tweeters in the few months.
Drivers:
ScanSpeak D3004/6640-00 Beryllium dome tweeter
Accuton C90-9-079, matched pair
Wavecor SW223BD01 - 4 ohm
pgwalsh is offline
post #22 of 137 Old 10-30-2017, 04:37 PM
Erich H's Avatar
Liked: 2706
One thing I'm never sure of and all the designers hate me for is this.....I always try to shoot for 8 ohm speaker kits. The dual Anarchy is a 4 ohm speaker. I think there will be a 4 ohm and 8 ohm version of the single woofer model, possibly.
What do you guys think about 4 ohm versus 8 ohm on the dome/ribbon tweeter speakers. I think smaller models should be 8 so they can be powered off any receiver/AVR, maybe the bigger ones can be 4. But they make a lot of nice little amps that are 4 ohm stable now. So it's been a tough call for me.
Any thoughts on that?
Should the new smaller 5.5" dual Anarchy woofer model be an 8 ohm speaker?
18Hurts likes this.
Erich H is offline
post #23 of 137 Old 10-30-2017, 04:41 PM
Erich H's Avatar
Liked: 2706
Originally Posted by corradizo View Post
Which wavcor tweeter?
It's the one in their waveguide: TW030WA11
Erich H is offline
post #24 of 137 Old 10-30-2017, 05:04 PM
Liked: 2230
Tux,
Drivers:
No I hadn't seen that one. HTguide isn't a forum I visit often. Nothing wrong with it I just don't. But that is really a nice looking speaker. Something like that using a ribbon was exactly my thought. Not sure I'd spend that much money though! Though Motus woofers aren't cheap but the amount of bass they make is serious. I laugh everytime I hear them. So low and solid.
Gonna check out that build now
post #25 of 137 Old 10-30-2017, 05:12 PM - Thread Starter
Quoted: 906 Post(s)
Liked: 622
I'm personally fine with 4 ohm because my current receiver can power them and we are talking about a 2 channel setup. I can certainly see where the concern is though. It will be interesting to see what other people think about this.
post #26 of 137 Old 10-30-2017, 05:20 PM
Liked: 2230
So many commercial speakers dip down to 4ohms it would take a day to list them. Even cheap receivers can handle it ok they just start to become less efficient and heat up. Shutting down or clipping requires serious volume or less than 4ohms. I tested a "8ohm compatible" Klipsch speaker that dipped down to 3ohms.
post #27 of 137 Old 10-30-2017, 05:35 PM
pgwalsh's Avatar
Quoted: 581 Post(s)
Liked: 423
If you manage to read through the gist of the design I'd be interested in your thoughts.
When it comes to 2 channel, I don't mind spending quite a bit more for a pair of floor standers than I would for strictly home theater use. I do a lot more critical listening in a stereo setup.
openbaffled and mikeTRON250LM like this.
pgwalsh is offline
post #28 of 137 Old 10-30-2017, 08:47 PM
bgtighe23's Avatar
Liked: 1231
What I would like to see (personally) is a tower for the hi-fi group that uses a solid ribbon, but also a high power handling dome that could be capable for HT duty.
MTMWW dome tower would be sweet. or even WMTMW.
Really the 1099/1299 size is fine. but what I think would be cool is if you offered "tower stand" kits.
For example: take the 1099. but offer a "tower stand" flatpack (separate purchase) that turns the 1099 into a tower.
This would keep shipping large "tower" costs down.
I'm not super picky, but there just aren't any tower dome kits.
post #29 of 137 Old 10-30-2017, 09:17 PM
kennyandersen's Avatar
Quoted: 139 Post(s)
Liked: 103
virtual every modern amplifier is stable at 4 ohms. Unless someone is designing speakers for an esoteric tube amp with an 8 ohm tap, EVERY SPEAKER SHOULD BE 4 OHMS, PERIOD, otherwise you are leaving money on the table, so to speak.
Personally I long for a 4 ohm dual MTM 8 in speaker like the cinema 8s, with a matching dual 8" center chanel just like the fusion 8s but 4 ohm.
With everyone on the multi full marty bandwagon the LCR really need to be able to make the transition down to the 18s in groups of 4. I think the dual 8s can do that, but with an 8ohm load, mo hard.
kennyandersen is offline
post #30 of 137 Old 10-30-2017, 10:28 PM
Erich H's Avatar
Liked: 2706
I'm not sure about all of that. Very few people are buying Fusion-8 or Cinema-8 kits to be powered with external 4 ohm stable amps for home theater. Usually they'd use an AVR, so there was no real reason to make them 4 ohm.
If they only have enough room for the 8's, they probably don't have a huge room with four large ported 18's and they're likely sitting fairly close to the speakers. So if they did want to use an external amp, at a 12' seating distance any decent model would play them to uncomfortable levels whether the Cinema-8's were 4 or 8 ohm.
jcr159, nlpearman, 18Hurts and 1 others like this.
Erich H is offline
